Question about Gateway (4000782) Motherboard
Gateway laptop battery does not charge , got a new power supply, but still does not charge. help
    Scholar:
  • 65 Answers
Ok, new battery may not always be the issue. If the jack plug that goes into the back or side of the laptop is damaged, then the only real way to get it to charge is to call the company and send it in. Had to do that with my laptop 3 months ago. but most companies that build laptop's will do this service for a bit of money but will have it back to you in a matter of days, not weeks.
Also, if the battery sat for too long without a charge, or caught a static hit, the batter could be toasted. Which means replacing that. That might be a first option before you go to send in the laptop, and if it works, then great, if not and you have to send the laptop in. then just think of it as having a secondary battery that you can keep charged for a quick swap
Posted on Nov 02, 2008
Gateway W350i won't charge new battery
1) the charger from power supply inside of the laptop is defective.some component is burn or open,or short.
2) Of course you must shure that the batteries new is o.k you must go where do you buy and test it in another computer for to see is charging.
God bless you
May 09, 2012 | Gateway Computers & Internet
My wife plugged in her lap top( gateway N58) with my son's plug-in for his notebook, the difference in power is 0.5A/imput ( less for the notebook), same 19 volts,but less output AMPs 1.5A notebook /...
The power receptors next to the battery sound like toast. Try running the computer off of just the charger (correct one) with no battery. If this works, you need a new battery. If this doesn't work, your computer needs a new power supply. Hope this helps =]
Mar 01, 2011 | Gateway Computers & Internet
My gateway mt6840 does not read my new battery
Have you tested your power supply to confirm it's sending out the right amount of current.A simple ac tester is all you need.On the back of your power brick it will tell you your in-put and out-put voltage requirements.If your ac adapter tests good your new battery is probally the problem.
Jun 02, 2010 | Gateway MT6840 Notebook
Put a new battery on still does not work
Note: do not plug your laptop if not using this. this will damage to your battery this the most common cause of battery problem due to over charged without unplugged. pls remove after charge. this can also damage to your main board from power supply section. thanks romsky79@yahoo.com
Jun 06, 2009 | Gateway M275 Tablet PC
Not charging
I found out how to solve this problem...first power down your computer. Then take out the battery, remove the power supply, and then hold down the power button for 30 secs. Put the power supply in only (not the battery). Start your computer after everything is done loading up put the battery back in. Give it a min. and then you should be able to roll your cursor over the battery life indicator in the lower right corner of you computer and is should say charging. I have found that other people have had this problem and it has worked for myself and for them.
Aug 26, 2008 | Computers & Internet
Computer gateway 700 xl
battery to plug switch is not set to except power to plug so battery can charge right now it still thinks its on the battery so no juice no comp
May 07, 2008 | Computers & Internet
Gateway 450rog does not power on
Sounds like a voltage regulator. Have the system diagnosed at a repair shop. Sorry I know this isn't what you wanted to hear, but is probably the correct answer.
Jan 19, 2008 | Gateway 450ROG Notebook
Won't Charge Any Battery--Even a New One
Check for loose solder connection in the power supply and the terminals that connects the battery to computer.
Sep 03, 2007 | Gateway 450ROG Notebook
Gateway (4000782) Motherboard Logo
100 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
