Question about GE JES1039 Microwave Oven
Painting the inside
Moisture had made the paint come off the floor of my micro.Is there a paint that i can safely repair with.
  • Anonymous Jul 01, 2008
    I have a Kitchenaid KCM8145j 99-1 Microwave Oven with rust increasing in the bottom. Is this a health concern to use the microwave?
  • Anonymous Apr 28, 2009
    can i use radiator paint on inside floor of microwave. if not what can i use
  • GE Master
  • 9,156 Answers
Local home centers and appliance parts stores (and online suppliers) sell appliance touch-up paint. It's designed for higher temperatures. You can usually get it in spray cans or small bottles. But if you have some regular enamel paint (spray-on on brush-on), I've found it works fine on a small area if the area is not subject to high temperatures. First you need to lightly sand away any rust or debris. Then be sure the area is clean & dry so the paint will stick.
Posted on Sep 22, 2006
    President:
  • 3,130 Answers
Yes there is!. At http://www.repairclinic.com it is item number 277 and is a spray paint for the microwave cavitys. You can call them at the 800 number on that page or order right there..
SOURCE:
Why is the inside painting cracking & rust is oosing out?
Hello Miriam;
My name is peter. I am a retired field service appliance technician.
The reason your micro wave liner is cracking is the way you place the food in the microwave.
The rust is coming from the steel frame where the liner is cracked.
Go into the following video on how to repair the cracked liner. You can do this.
How to Repair Microwave Arc and Burn Marks Touch Up Paint
Apr 04, 2016 | Magic Chef Microwave Ovens
Need to paint the inside of my 2001/240 v. Ge advanium what do you recommed
I wouldn't recommend painting it. The inside of the microwave is a box that allows microwaves to bounce around off those walls. If you paint the inside of your box you could have a serious fire hazard. I would send and e-mail to GE and see if they recommend anything that is microwave safe.
Mar 26, 2015 | GE Microwave Ovens
I have a whirlpool microwave which has a small burn mark ( a chip of the front of the inside of the microwave) i was wondering is it still safe to use? would radiation be leaking through if it isn't...
Yes it is safe to use. The microwaves are about the diameter of a pencil, so it takes a pretty big gap to create problems. The chip can be repaired using a fine sandpaper (wet/dry type) and then painting with a microwave touch up paint available at any appliance repair shop. The paint is pricey, so don't be surprised, but it is made just for microwaves.
Hope this helps you.
fil
Mar 04, 2011 | Whirlpool GH7155XHS Microwave Oven
My sisters has a Sharp microwave r-403hw was manufactured july 2003 my question is how long are you allowd to keep a microwave for and if the inside chips from the paint is still ok to cook food in it or...
As long as the microwave oven is working to heat or cook according to the program set , the micro wave can be used safely. Now if there is any chipping of the paint within the oven chamber, then you can re-coat the inside with non conducting ceramic paint.
However if there is no issue if there is no damage to the inside or to the working of the microwave as you can use the oven till it fails to heat.
Jan 25, 2011 | Sharp R-403HW Microwave Oven
Magnetron antena metal cap hole due to spark
it is not safe to use this, DO NOT USE, repalace immediately, no need to repaint
Mar 22, 2009 | Sharp R-820B Convection/Microwave Oven
Paint has chipped off bottom of MW
Moisture accumulation can sometimes be caused if the cooling fan is not running properly or if the vents in the back are blocked or there is not enough free space around the sides and back of the microwave.
One thing that helps is to keep the door open a few minutes after using it and to wipe down the inside after use.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Nov 22, 2008 | Panasonic NN-T990SA Microwave Oven
PAINT IN MICRO WAVE OVEN
It will have to be sanded smooth and clean and dried thoroughly.
Then you can apply high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 21, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Peeling paint
Here is a link to buy the paint.
If the microwave is not creating a spark inside when in use, It's OK to use.
Mar 09, 2008 | Rival MT660 Microwave Oven
Peeling paint
You need to thoroughly clean it, then sand it smooth to removew all the loose paint.
Once it's squeaky clean and dry, you can apply high-temperature appliance paint, which is available in brush-on or spray-on form at big box stores like Wal-Mart, home improvement centers like Lowe's and appliance parts stores.
Nov 02, 2007 | Rival MT660 Microwave Oven
GE JES1039 Microwave Oven Logo
651 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
