Question about Dryers
Can you connect a ele and a gas dryer in the same place with a t to the outside
We have both ele and gas driers and we dont wont to put to vents in so we was wontican you connect a ele and a gas dryer in the same place with a t to the outsideng to see if you can
  • betzy boop Nov 02, 2008
    Novelist:
  • 208 Answers
THIS IS UNSAFE AND DANGEROUS BECAUSE OF THE POSSIBILITY OF CARBON MONOXIDE FUMES CROSSING INTO TO TEE AND THROUGH THE ELECTRICAL DRYER AND INTO THE HOUSE. GAS DRYERS MUST BE VENTED WITH ONLY APPROVED GAS DUCTS TO PREVENT FUMES ESCAPING INTO THE HOUSE. THESE CAN KILL! PLEASE RECONSIDER AND DON'T DO THIS. IT IS DANGEROUS. A ELECTRICAL DRYER CAN BE VENTED TO AN INSIDE FILTER TYPE BUCKET WITH WATER IN THE BOTTOM. IT DOESN'T HAVE TO GO OUTSIDE BECAUSE THERE ARE NO POISONIOUS FUMES. SO, VENT THE GAS DRYER AND USE AN INSIDE LINT CATCHER TYPE FILTER ON THE ELECTRIC AND YOU SHOULDN'T HAVE ANY PROBLEMS. OK?
NEED MORE INFO, JUST REPLY.
ARCLIGHT1217
Posted on Nov 02, 2008
Theres a problem with the drier as dof theres never any water in the tray anymore , and the drier is filling with fluff, takes ages too dry anything , what do you recommend plerase angela
Check your exhaust line and lint filter. Go outside and locate on the wall where the dryer exits the house. If you can, feel around the inside and clear the exhaust of any lint or debris. Next, check the lint filter. If it's packed, remove all lint from it and clean with mild soap and water. Put the filter back in it's place. Turn on dryer's normal setting that you most commmonly use and star dryer. Go back outside to where the dryer vent exits the house. Place your hand over the vent. You should feel hot air coming out at a pretty decent rate.
Jul 09, 2011 | Hotpoint Dryers
My dryer is taking three cycles to dry clothes and its only 2 yrs old. Air flow looks good and lint has been cleaned out. Any suggestions?
Yes, check the hose behind the machine. Pull the drier out away from the wall pull the vent hose off and make sure it is clear, then look at the connection on the back of the drier and the vent at the wall, go outside and look at it for birds nest or kids putting tennis balls in it.
Oct 18, 2010 | Whirlpool Dryers
No heat when drying cloths
Check the vent that goes outside it may be blocked.
Jul 23, 2010 | Maytag Neptune MDG9700A Gas Dryer
AFTER DISCONECTING THE GAS FOR TILE WORK IT NEVER WOULD REHEAT
So long as its heating a little, try removing the venting, and see if there an improvement. a clogged vent will greatly reduce if not stop all heat . dont forget to check where venting exits the home outside also becomes clogged.
Now restart it - it should work.
Jul 21, 2010 | Whirlpool LER4634J Electric Dryer
Dryer taking to long to dry cloths, all vents are clear
sometimes a element that heats the dryer breaks giving it only power till were it broke /then will cause no or very little heat these run about 30-34$ depending on what type of brand of dryer you have
Apr 10, 2010 | Maytag PYE2300AY Electric Dryer
We have just purchased a Lg Dryer #DLE1310W which which is yet to be delivered. I have 2 questions: 1. The electrician needs to know if the dryer cord is a 3-prong or 4-prong cord. He is installing the...
lg driers are a 3 prong drier cord receptical he shouldn't have to purchase any other venting as long as the location of the dryer is not in an oddball place The parts included are for basic installation in an area such as the garage or room connected to the garage where the access to the outside is just through a outer wall. Mrs. Leonard good luck on your repairs and hope I helped you some.
Dave
Sep 16, 2009 | Dryers
My drier is a Maytag, it is not heating up the way it should be.
There is a chamber that the air blows down before hitting the vent pipe. It may need to be cleaned. But you want to make sure when you push your dryer back, that the vent doesn't kink. good luck. Overall you drier works, your just having a venting issue.
Apr 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
GE profile dryer not drying completley
Check that the vent outside (especially in northern climates this time of the year). Then check the hose that goes from the drier to the outside vent. Finally, check the drier itself, that there is no obstructions getting to the hose. Check the lint trap. Is it full or is it installed properly? If all this checks out, then try replacing the heating element. These are usually inexpensive, and fairly easy to replace. The manual for the drier should have diagrams on how to access it.
Jan 12, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Kenmore gas drier does not heat up
HI .Thanks for the question. the problem you have is with a thermal fuse, located at the ,of the dryer. pull away from the .remove the back panel. clean all the lint in the dryer. and the vent to the outside. the thermal fuse is located on the air duct. on the left bottom. of air vent a small plastic piece with 2 small blue wires. replace this part. thanks the appliance doc. please rate my answer. thanks.
Oct 07, 2008 | Dryers
Kenmore dryer
this promblem is about always a vent promblem or not cleaning the drier filter if your using the plastic vent check if its mashed behind the drier you must have 4inch of vent all the way throuch if its mashed or folded over its cut down to 2inches if it hangs under your house then comes up to the outside vent housing it can fill with water if the outside hood door isnt oping that will do it too its in your vent some where what i tell cust to do is run 4inch pvc from out side hood up through floor then run short metel vent to pvg attach with clamp to confirm vent restriction take vent loose for one load and see if it dries in right amount of time
Dec 28, 2007 | Dryers
Dryers Logo
90 people viewed this question
Top Dryers Experts
