Question about Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher water comes in and goes stright out of drain
My dishwasher decided to stop all of a sudden hal way through a cycle, It had had some water as the dishesd had been rinsed, but not actually washed. I pulled unit from housing to see the back, emptied appliance and then turned on to see what happens. I noticed that the water inlet became vibrating indicating to me that water flowing in, Also noticed that the water was going straight back out of drain pipe and getting hotter as it went.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 62 Answers
Is the drain upto specifaction? sounds like its siphoning. should be in your manual
Posted on Jan 03, 2008
Whirlpool dishwasher F8 E1 error
You have a blockage in the drain line someplace. If you have a garbage disposer, check to see that it is clear where the dishwasher connects to it. Also check and make sure that the drain hose is higher then the inlet to the disposer to prevent water draining back into the drain line from the disposer. If that's clear you have a blockage somewhere in the drainline. Best to unit from cabinet and check it
Apr 05, 2014 | Whirlpool Dishwashers
The dishwasher will not drain.
Check your main drain system. Remove the drain hose from that end and discharge them in a bucket. Try a new wash an if the m/c drain system is ok, it will discharge water in the bucket.
Check the house main drain for clogging at the hose connecting end.
May 25, 2010 | Bosch SHU5315UC Dishwasher
DWF 415 Ikea Whirlpool Dishwasher as constant
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after thre is no more water to pump. Any ideas on how to fix?
Oct 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Water keeps coming back into dishwasher after cycle is done
sounds like maybe one of your check valve is not working right.
Jun 03, 2009 | Dishwashers
Dishwasher keeps tripping electric
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwash
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Jan 04, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
BOSH won't stop draining
take your dishwasher out and look for a water at the base of your dishwasher.
If that is a water at the botton base, just dry the water and its ok.
if you dont find water at the botton base inside replace the water level system PN= 263834 at repairclinic.com, item# 935595 for 41.00 and that part goes in the left side of your dishwasher
May 24, 2008 | Bosch 24 in. SHX46A05 Stainless Steel...
Bosch dishwasher
Good news is, this is unlikely to be expensive.
Need to sort out where it's coming from first.
Find a stopvalve you can use to shut off the water supply to the machine - there's probably one where the dishwasher is connected to the domestic plumbing. If turning this off stops the water coming in, you probably need a new inlet valve. The ones on dishwashers are generally pretty cheap to replace.
If shutting the water off doesn't stop the inflow, then the only place it can be coming from is siphoning back in from the drain. There's supposed to be either an air gap or an anti-siphon valve where the dishwasher's drain hose goes into the domestic drain. If this gets blocked/stuck, then it can cause dirty water to siphon back into the machine. Check and clear as necessary, then run the machine through on the hottest, longest cycle it's got (in the expectation that not all the water that was sucked in from the drain necessarily started out in the dishwasher).
A.
Apr 02, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
198 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
