Question about Equity Time USA Sky Scan 44100 Clock Radio
Set time How do you set the time?
To adjust this clock's time: Press and hold the Alarm
Set button for 5-7 seconds, and the year will
begin to blink, then press the "UP" or "DOWN"
button to set the year. Press the Alarm Set
button again to set the month by pressing the
"UP" or "DOWN" button. Press the Alarm Set
button again to set the day, again to set the hour
(be sure the AM/PM is correct), again to set the
minute, and once more to secure all in the
memory
Posted on Nov 02, 2008
Setting an ultronic touch screen alarm clock
TD00552: 12 hr--military time toggle= tap time set button. Set time= hold down time set button till up & down arrows show on r & l sides; set hour, tap time set button, then set minutes, repeat, seconds, repeat. Date change= tap hour if needed to show day & month; then hold set button on left till up & down buttons show at edges of screen. Up/down buttons to set year on lower right screen, tap set again to change # day of month, tap set again to change month, and the day will correct itself. Change temp c° -- f°= tap alarm button if needed to display temp b them tap set button next to it to change temp scale. Alarm- off/on= tap screen button if needed to show alarm time; tap alarm set button next to it- it will toggle on/off. To set= with alarm time showering, hold down alarm set button till up/down buttons show; follow same process as above.
You are all welcome ??
Jul 01, 2017 | Televison & Video
How do i set the time on my kindle fire?
Tap the little gear icon in the upper-right, tap "More...", then tap "Date & Time".
If you want the Kindle to automatically set the correct date and time from the internet, make sure "Automatic" is set ON, tap "Select Time Zone" then set your time zone. Otherwise set "Automatic" to Off" then tap "Set Time", set the time, then tap "Set Date" and set the date.
May 02, 2014 | GPS
Can not change time zone on sharper image model lm521 projection clock
I got to liking the Sharper Image LM521 Digital Clock so much that I finally took the time to figure out how to manually set it-it was that or toss it! The instructions are as follows:
NOTE!!!
AFTER installing fresh batteries, or removing and reinstalling the batteries:
Successively pressing the "SET" button results in steps 1.) to 11.) below, each of which describes the particular/specific LM521 clock function you you can manually set.
HOWEVER, pressing the "SET" button after the clock had been previous set and running, will start the manual clock settings from step "2.)," "SET Offset Hours..." To start from step 1.), remove and reinstall the batteries.
PROGRAM/MANUAL SETTING MODE
After inserting the batteries:
The whole LCD screen lights up showing the different settings, etc.
After several seconds, the LCD screen clears and displays:
A flashing antenna
Upper left hand side of the LCD display. USA Time Zone Map
Middle right side of the LCD display (if necessary, to see, remove and reinsert batteries).
WAIT FOR AUTO TIME SET
A flashing antenna
> This indicates the clock is trying to auto set the time according to the WWVB radio/satellite time signal. Set on windowsill for best chance of success.
If it can't detect the signal, mannual setting is required, starting with the time zone.
> Manually set time ONLY if you are absolutely certain the WWVB signal cannot be found. Otherwise any manual time setting will be auto set to the WWVB time when its signal is detected, which may be many hours later.
SET USA Time Zone
1.) Press "SET" -- US time zone
> press "MODE" repeatedly until the desired time zone is reached.
5 = Eastern standard time (default setting)
6 = Central standard time
7 = Mountain standard time
8 = Pacific standard time
9 = Alaskan standard time
SET Offset Hours to Compensate for Satellite Signal
2.) After step 1.) above, press "SET"
A flashing "-7h" (minus 7 hours, default) and flashing USA Time Zone map appear.
This default setting worked just fine in New Mexico, MST, and may also work for your time zone as well.
> Press "MODE" to set from "-0" to "-12h" (minus 0 to 12 hours).
> Set to "-0h" if the satellite time signal set your clock to the correct time for the US time zone you live in.
> Set from "-1h" to "-12" to offset the time set by the satellite signal in case it does not match the time in your time zone. (E.g., 3pm -1h = 2pm.)
> NOTE: The default setting is -7h. If the satellite signal resets the time, say to 9pm, the time displayed will be 2pm (9pm-7h)--but if it should display 5pm instead to match your time zone, then set offset to -4h. Hence, the need to correctly set the offset hours if the -7h default value does not work for you.
SET Daylight Savings Time (DST)
3.) Press "SET" -- DST (Daylight Savings Time)
> Press "MODE" to set ON/OFF
SET Time
4.) Press "SET" (5no = seconds)
"5no" displays, plus flashing bars for seconds (not minutes as it falsely seems).
> Press "MODE" to set from 0 to 60 seconds
5.) Press "SET" (set hours)
> hour bars flash > press "MODE" to set hours
6.) Press "SET" (set minutes)
> minute bars flash > press "MODE" to set minutes
SET Date
7.) Press "SET"
> press "MODE" set year
8.) Press "SET"
> press "MODE" set month
9.) Press "SET"
> press "MODE" set day
SET Week Day
10.) Press "SET"
> press "MODE" set week day, Mom through Sun (Mo is default)
SET Standard (12) / Military (24) Time
11.) Press "SET"
> Press "MODE" set 12/24
CEILING DISPLAY:
SET/ROTATE Ceiling Projected Time/Temp Position
12.) Repeatedly press button with four tiny arrows pointing opposite each other (rightside of "DSPL" button) until the Time/Temperature display on the ceiling is oriented how you want it.
SET Ceiling Projection Brightness, or turn off
13.) Pressing button with sun symbol (leftside of "DSPL" button) cycles ceiling display from off, to brightness levels 1, 2, and 3.
SELECT between Ceiling Projected Time, Temp or Both
14.) Pressing "DISPL" repeatedly cycles between M0 (time), M1 (temperature), M2 (time & temperature auto switch every second or so).
Jan 23, 2012 | Audio Players & Recorders
How do I change the time on my TIMEX T307S clock?
Hello
To adjust time follow this.
Auto-Set Time and Date Settings
This model is equipped with the Auto-Set feature, meaning that the time and date have been programmed at the factory
and will already be set when you first plug the model in. Auto-Set will automatically adjust the time and date settings for
daylight-saving time and leap years. Auto-Set is programmed for Eastern Standard Time; if you do not live in this time zone,
you can easily switch the setting to one of six other time zones.
1. To change your time zone setting, press and hold the 8 Time Zone Button. The current Auto-Set Time Zone in the
lower-right-hand corner of the display will flash for approximately ten seconds, after which the display will revert to the
standard clock display.
2. While the Auto-Set Time Zone is flashing, press the 1 Reverse and 6 Forward Buttons to select your time zone.
The display will show each zone's current time setting. There are seven zones to choose from:
Auto-Set Time Zones
Z-01 Atlantic Standard Time
Z-02 Eastern Standard Time
Z-03 Central Standard Time
Z-04 Mountain Standard Time
Z-05 Pacific Standard Time
Z-06 Alaskan Standard Time
Z-07 Hawaiian Standard Time
3. Find your time zone, then press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the
setting to lock into place.
Manual Time and Date Settings
1. To change your time setting, press and hold the J Time Set Button so that the clock display begins flashing.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, shown by the PM Indicator.
3. After setting the time, press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the setting
to lock into place.
4. To change the calendar, press and hold the 9 Date/7-5-2 Button until the display shows the flashing year.
5. Press the 1 Reverse and 6 Forward Buttons to set the current year. When you have selected the year, press the
4 Enter Button, then use the 1 Reverse and 6 Forward Buttons to set the month/day.
6. After you have set the date, press the 4 Enter Button or wait for the display to beep twice and lock into place.
Mar 15, 2011 | Timex (T307S) Clock Radio
How do i change the time
Hold the [time] button and hold it, while pressing down on [time] press [set +] or [set -] . [Set +] will move the time forward and [set -] will adjust the time back. If you hold down [set +] or [set -] the time will move faster.
Mar 04, 2011 | Emerson Smartset Clock Radio
Tipsy clock programming lost leaflet. would like to down load leaflet. bought this inexpensive clock at BB&B.
Hi I was having a hard time with this too, but luckily I found my leaflet.
To set time:
Press Mode 1 time
Press Set 2 times/ press up or down for hour
Press Set again for minute
Continue Pressing Set (up to 6 times) until everything is set
Back to normal mode- Press Mode 4 times
To toggle between 12 hr and 24 hr, press Mode 1 time
To Set an Alarm:
Press Mode 2 times
Press Set 1 times for hour, continue pressing set like you did for the clock.
Back to normal mode Press Mode 3 times
To cancel Alarm Press Mode 2 times and Set 5 times
Jan 16, 2010 | Watches
How to set time on the southwestern bell answer machine FA982B
I went to the southwesten bell freedom phone site on the web. Found answering machines.  My old machine was not listed, so I found instructions for a later machine.
The method for setting time was similar.  I tried it and it worked fine.
Your high prices prompted me to be less lazy.
Jun 10, 2009 | Southwestern Bell Lands Phones
I have a Zenith ZG120M alarm clock radio. I can't set it.
Here is how I set my ZENITH ZG120M radio alarm clock.
1) PRESS AND HOLD DOWN the HOUR BUTTON and then PRESS the TIME BUTTON to set the correct hour.
2) PRESS AND HOLD DOWN the MINUTE BUTTON and then PRESS the TIME BUTTON to set the correct minute.
To Set The Wake Up Time
1) PRESS and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the HOUR BUTTON to set the desired hour.
2) Press and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the MINUTE BUTTON to set the desired minute.
There are two light indicators that light up on the left side of the LED display...the top light indicator will come
on once the time turns to PM. The bottom light indicates the alarm is set.
Mar 25, 2009 | Timex T309TT Clock Radio
What does set point time and set point temperature mean
set point time time when the set point temp activates
say i want my house to be 70 degrees while i sleep
i'll set the set point time to 11 when i go to bed, and the set point temp at 70
so to do what youwould like set the set point time for midnight and the thempature fore 55 or lowest seting with will keep the heater off. for the second time setting set point time at 5 am and set point tempature at desired temp
Jan 17, 2009 | Hunter Fan Company 5/1/1 Programmable...
Equity Time USA Sky Scan 44100 Clock Radio Logo
1,078 people viewed this question
Top Equity Time USA Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Equity Time USA Audio Player and Recorder Expert? Answer questions, earn points and help others
