Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
MPI kerosene Monitor Heater
I am trying to start the heater. The burner light comes on, flickers, makes a "purring" or light "thumping" noise and shuts down. Help ! Mike
  • sconnell633 Nov 02, 2008
    my burner will not stay lit, and does not seem to be getting muck propane gas even though the tank is full?
  • Dawn003 Dec 13, 2008
    I am having the same problem. It starts to light, then you hear a thumbing noise then the lights start flashing and it goes off. Can anyone help me?
  • 4 Answers
Need to bleed air out of filter at oil tank crack open the screw on top it will bleed out air wait until oil starts to run out then tighten back and bleed at heater on right side lever inside hole push and let off slow 4-5 times and restart
Posted on Dec 31, 2009
  • J_T_B1986 Sep 12, 2010
    loosen the screw on the tank filter let oil flow then go to your heater and loosen the screw on the right side not the 2 but the single 1 screw for what looks like a decent flow then prime your button 4 or 5 times then start your heater up that worked for me i replaced a broken line hope this helps you guys
  • greg Dec 05, 2012
    WHER IS THIS FILTER?
    Novelist:
  • 126 Answers
When your Monitor makes that thumping noise you are not getting fuel to the pump. Either no fuel, low fuel, or dirty filter on tank and stove.
Posted on Jan 06, 2009
    New Friend:
E 13 COD
Posted on Jan 30, 2013
No fuel is getting to the pump clean pump filter and line filters hope this helps.
Posted on Jul 21, 2012
    Problem Solver:
  • 3 Answers
Monitor 41 reads E-01 what does it mean?
Posted on Nov 03, 2008
Flickering dashboard lights and gauges with noise thu speakers
difficult to answer ,suspect either alternator or battery or both ? would realy need to see car to know the problem .
Nov 03, 2017 | 2003 Chevrolet Monte Carlo
My eclipse spyder 03 started making that noise like a week ago on the drivers side ? Anybody help plz!!!!
There are many possibilities that can cause car to make noise.
It's actually from where the noise is coming from. Front end or rear end. From engine area or from inside the steering or from brakes.
There is N-number of possibilities for the car to make whining noise or any other kind of noise.
For step by step troubleshooting this problem, I suggest you to refer the help links mentioned below. Its a complete solution with proper explanation to identify the cause of problem: ------
Click the link below: -----
Car makes clicking noise?
http://howtobyme.blogspot.com/2011/11/car-makes-clicking-noise.html
Car makes whining noise like driving on rough pavement?
http://howtobyme.blogspot.com/2011/12/car-makes-whining-noise-like-driving-on.html
Chirping Noise From Car?
http://technoanswers.blogspot.com/2011/11/chirping-noise-from-car.html
What are the possibilities for Clicking noise in car?
http://technoanswers.blogspot.com/2011/11/what-are-possibilities-for-clicking.html
Squealing at start up on car?
http://technoanswers.blogspot.com/2012/01/squealing-at-start-up-on-car.html
Chirping sound coming from engine?
http://technoanswers.blogspot.in/2012/01/chirping-sound-coming-from-engine.html
Vehicle making Clunk Thump Thud noise?
http://howtobyme.blogspot.in/2012/03/vehicle-making-clunk-thump-thud-noise.html
4X4 Truck makes roaring noise in the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Heater makes clicking noise under dash on Ford Explorer?
http://technoanswers.blogspot.in/2012/01/heater-makes-clicking-noise-under-dash.html
Clicking noise under dash and front defroster not working?
http://technoanswers.blogspot.com/2012/01/clicking-noise-under-dash-and-front.html
Car Brakes Making Noise?
http://repairhelpcenter.blogspot.com/2011/12/car-brakes-making-noise.html
Car Alternator making noise?
http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
Car Alternator Bearing Makes Grinding noise?
http://repairhelpcenter.blogspot.com/2011/12/car-alternator-bearing-makes-grinding.html
Engine makes noise and Cooling Fan belt Breaks?
http://howtobyme.blogspot.com/2011/12/engine-makes-noise-and-cooling-fan-belt.html
Vehicle Makes Clicking Sound While Taking turns?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-makes-clicking-sound-while.html
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
When the burners ignite, within one minute it starts making a loud banging noise and then the HS code comes on and it shuts down. the noise continues for about 15 to 30 seconds after the burners shut...
This sounds like a low water flow situation. The heater is telling you that the high limit sensor is curring heater operation. The noises are the heat exchangers boiling the water either due to a blockage in the exchanger , a bad mixing vlve, or most likely poor water flow. This is tough to troubleshoot through a posting like this, but 1st thing is 1st. Check your water flow and make sure it is minimum 50 Gallons per minute.
Jul 18, 2011 | Hayward H-series Electronic Gas Pool...
I need to know how to get to the blend door in the heater area of my '92 chevy c1500. I was told that is what makes a thumping noise when the key is on or off.
this is some what normal, as long as it just once that you hear the noise (ie. you turn the truck on and thump, turn the truck of and thump) the doors operate off of vacuum lines in the engine. When you shut the engine off the vacuum goes away and *thump* the blend door snaps back to its normal resting position. then when you turn the truck on the vacuum then comes back and *thump* the door snaps back to its adjusted place.
If you feel that this is not what is going on, this diagnostic technique can help eliminate this condition
set the blend door to the hot side and start the truck and it should thump when the engine is on or off.
if you didn't get a thumping noise that is good it just means that the blend door is set to the hot side normally open.
Apr 18, 2011 | 1999 Chevrolet Silverado 1500
I have a 50 gal rheem water heater, its making a clicking noise i have discovered if i shut off the cold water supply it stops, when i turn it back on then the clicking starts again, my t&p has popped...
sediment build up is usually causes thumping and noises from tank. it needs flushed out. models, where the heat source is beneath the tank. The burner heats the water under the sediment, leading to a build of steam. The steam finally escapes as bubbles, which can cause the sounds.
have a good day !
Mar 14, 2011 | Rheem Water Heaters
It makes a thumping noise when it stops running.
As the manufacture says to us techs, get used to it, sorry thought I would throw that in there. This is a common complaint, it thumps once or twice shortly after it shuts down. What is going on here is this, your frig will run til it either reaches the temp you have set or til it's time to go into "defrost" mode (does this about every 8-12 hours of actual run time)", then it will shut down, turn a "heater" on inside the evap area. The sudden change of temp causes a "thump" noise. They have changed these boxes up due to energy requirments, so the have to make the heater a little hotter so that it does its job quickly and then shuts off. Now, you need to make sure that the thump is not right after it restarts, if it is then you have a "dryer" that needs to be covered and the screw removed from the side of the cabinet where it mounts. Sudden expansion of the cold freon in the dryer causes a thump also, removing the clamp, sliding the dryer over a little will normally cure thump.
Oct 09, 2009 | Maytag MTB1891AR Top Freezer Refrigerator
I have a monitor 441 and it will not ignite! I cleaned the strainer, and the igniter is getting warm. But, no flame? help anyone??
Lane,
Do you hear a thumping noise on the lower right side of the unit just before it starts flashing the light bars? If so you have a fuel supply problem. If there is no thumping noise I would check the flue pipe on the outside to be sure it is clear. Lastly I would remove the copper fuel pipe from the burner and try to start the stove. If fuel comes out the pipe the pump is good. If fuel comes out I would stick a paper clip down the fuel nozzle about 3 inches, it could be blocked with carbon. If no fuel comes out the pipe, you will need to get a manual or a tech to help you out. The choices would now be fuel pump or main board, both of which are pricey so you don't want to make a mistake.
That being said, when was the last time you had the burner serviced? Mat, ring and all the gaskets involved? A Monitor 441 needs to be looked at about every 3 years to be sure you get through the heating season.
Good luck,
Tom Hawkins
hawkins111@gci.net
Mar 03, 2009 | Heating & Cooling
Coolant light keeps coming back on
yes these issues could be related ... if you have a bad thermostat the steam will thump inside the plastic coolante tank. also if you do not bleed the cooling system it will cause the same issue. there is usually a bleeder screw on the tube coming up from the water pump.
Feb 28, 2009 | 1996 Chevrolet Cavalier
We have a monitor 2400 kerosene heater, it will start up and after a few minutes at most it shuts down and starts beeping and many times has a message "error 13"
Next time you try to start the unit listen to the pump on the lower right side of the unit. Just before the E13 message if you hear a thumping noise, you have a fuel problem. If you don't hear a thumping and there is a flame you have a problem with the inside of the burner. I would say since it's a 2400 you have a fuel problem. Low fuel, no fuel, dirty filter or blocked flue pipe.
Tom Hawkins
hawkins111@gci.net
Jan 19, 2009 | Heating & Cooling
Thumping sound under dash when start or shut down.
I take a shoot here you can try this. try pulling the fuse or fuses that go to your heater blower and heater controls. If it stops check your heater blower it may be going bad, if you find nothing there, leave the blower unplugged and try turning your key on and see if you still hear it. If so I would think that the heater control is mess up and open and close the air blend door or you may have a wire shorted out under the dash some where.
Nov 27, 2008 | 1994 Chevrolet C1500
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
6,136 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
