Question about Karcher 1750 psi Electric Pressure Washer
Motor/pump pulses--like a rapid on/off rather than a steady hum
The last time I used my sprayer, it wouldn't spray at all, and the user manual led me to believe that there was air in the pump. I followed manufacturer's instructions, and now it's spraying. But, the motor and/or pump seems to be malfunctioning when the sprayer arm is not activated. It's a "rum - rum - rum" pulsing sound with "beats" about a second apart, rather than a steady hum of a motor. It draws down the electricity in my garage with each pulse--the lights dim. When I'm actually spraying, the motor seems to level out--and the lights are okay. I'll appreciate your advice. I'm a widow, and I can't afford to call a repairman every time I would have ordinarily turned to my dear husband. Thanks.
BLM
  • 2 more comments
  • patrickferg Nov 05, 2008
    I have a 3 year old, lightly used KB9030 doing this pulse trick. It's ok when spraying, though I think pressure is a bit less than it used to be. In addition, after about 10-15 minutes minutes use the motor cuts out completely, and won't start for about 15 minutes. Now I'm a reasonably skilled DIY-er, and have stripped the machine down several times to investigate, but with no luck. One suggestion from the web was that it was the control head, which I've dismantled,examined and cleaned......no result.! Also, I've tried changing the inlet pressure. Do I look for a new one?
    Thanks, Ferg
  • lou20227 Nov 12, 2008
    Same problem as above,spray ok no external leakage,motor is 100%,I replaced,cylinder head k 200,valve cage and spring, its still doing the same problem.I electrician/Refrigeration Mechanic by trade,and spill valve where about is that the valve cage or something else,and i got the manuel right in front me i couldn`t see the name of spill valve.believe me not even a spit of water dry as a bone easy to know that is loosing pressure the suction chemical valve keep going in and out.because is the on that when it fill with pressure it goes off and you hit the rigger it release and switch back on.
    thanks a lot
    regards
  • Anonymous Apr 22, 2009
    Hi "Its alive",
    It looks like that you know what you are talking about, but I cannot figure it out:
    What is the "control head"? HP side I assume stands for high pressure?
    I removed the yellow cover, and the rho pipes. I found a small metal thing with a red plastic attached. The red plastic has four holes on it... looks like some kind of filter... I tried cleaning it out, it didn't help
  • Anonymous May 12, 2009
    intermediate pumping and low pressure
I had the same problem,and I replace the spare part set control head parts,Same problem when it goes hum hum,if you look inside it with a magnified glass you`ll be able to see hair crack line.
Posted on Mar 17, 2009
Replace the control head. Water leaks from the HP side,through the o-ring on the piston to LP side. This then triggers the machine to start since it's lost the 120bar pressure which is required to keep the machine off. If you can source the correct size of o-ring just change it out. If not use E-spares for the part which costs £12
Posted on Mar 16, 2009
Good morning to all
I am an Italian and working in a repair Karcher. After reading your post I can say with certainty that your problem is the breaking of a component of the pump called collector. The breaking of this component leads to a continuing power of the machine for 10 minutes and the loss of pressure during the operation. To repair should consult your local Karcher.
Regards
Posted on Dec 07, 2008
  • CanAmSteve Jun 11, 2011
    I suppose it is to Karcher's benefit that repairs require a Karcher repair shop to complete them?
    Be careful of freezing, the design of these machines is poor and any residual water inside will freeze and break components. In Italy it obviously never gets cold, but if you live anywhere it freezes, take the machine inside for the winter, I guess, Yes, inconvenient and messy, but parts are expensive!
  • 92 Answers
Dear Brainpicker,
I think..(with all respect)...that the last time you used your sprayer, you swwitched it off and left it with pressure in the system. When one finishes using such machines, it is important that the pressure is released by pressing the gun. If these machines are stored with pressure still in the system, damage will be done to various parts, especially the spill valve. This is also more importantant for SAFETY reasons. The fault you have is most probably from the spill valve. In this case it should be changed with a new one. This job can only be carried out by a specialised technician. I wish to add, that this problem could also be caused by leakage. Check if the gun is leaking when it is closed. Also check if you see any water under the machine. This means the head is leaking. Very sorry but this problem requires a qualified technician or a person with expirience.
Regards,
MG.
Posted on Nov 05, 2008
Washer fluid not spraying
Does the motor make a noise like its trying to pump when you press the water button? Best way to check is when the car is off and you turn the key to accessories, then try the water. If you hear a humming noise, your fuse and motor are working and you have a blocked spray unit. Just use a pin to unblock it.
If you dont hear a humming noise, locate the fuse and see if it is faulty. If the fuse is fine, your motor is bad so replace it. Hope this helps
Jun 17, 2013 | Toyota Avalon Cars & Trucks
Washer fluid not spraying out onto windows
when you push the button to spray the window "do you hear the sprayer pump motor"?
If no, your sprayer pump motor could have failed or come diconnected. now if you do hear the sprayer pump kick in then> check your lines "the small rubber hoses that lead to the actual sprayer nossels. make sure the small hoses are not damaged and leaking and not pinched or restricked.. in rare cases the sprayer pump could have failed and still make a sound like its working but not pump out any fluid.. also in some cases BUT RARE you could have a line or filter screen plugged inside the washer resivor.. Good Luck!
Sep 13, 2011 | 2003 Chrysler Voyager
I have a wagner hvlp control sprayer and it will not spray out the paint from nozzle? why? it is not clogged???
On my Wagoner sprayer, it is possible to turn the nozzle 180 degrees to clear it. Does yours have this feature? I thought my sprayer was faulty (being very cool myself, I didn't read the instructions) maybe due to non use or age as it has sat on the shelf for two years since last use. I bran out and bought another one. After about 10 minutes of use, the new one stopped. I cleaned and cleared and still had no luck. I bought pipe cleaner and little brushes ... you wouldn't believe all the trouble I went to to make sure the nozzle was clear. I was convinced the trouble was with the motor and not the nozzle. Then, I read the instructions ... they said to turn my nozzle 180 degrees and pull the trigger - IT WORKED!)
If yours will not spray, there is a motor trouble or there is a clog somewhere between where the paint is and the nozzle. Believe this and believe that the sprayer was made to work and it was not made to not work and you will discover your trouble.
Thanks for your question ... I hope I have provided some insight for you.
Jun 20, 2011 | Garden
I need the owners manual for the ortho dial n spray hose end sprayer.
From forums.gardenweb.com
"The instructions on Ortho Garden Disease Control (Daconil) give directions for use in the dial and spray. Set dial at 4 Oz. Add 1 TBS Daconil and 7 TBS water for each gallon you want. I am using the dial and spray and don't see as much residue as when I was using a pump spray.
Jul 03, 2010 | Ortho Dial N Spray Hose End Sprayer
I have to initate the spinning of the sprayer arm.
uasally it isnt the spinning of the spary arm that does the fill it is controlled or a timed fill then the motor comes on if there isnt enough water in the unit it will not have enough pressure really need more info though
Jun 02, 2010 | Dishwashers
The spray stream is not consistent. After 2 - 3
The pump cycles to keep the pressure constant. It could be the impeller---they sell special ones to use with nonaqueous sprays--ie petroleum based. If petro was used at some time, the impeller might be bad.
Mar 01, 2010 | Northstar ATV Broadcast Spot Sprayer 16...
I have a 1998 chrysler concord and i can get windsheild washer fluid to spray the resevoir is full no fluid is leaking out the wipers activate upon initiating the spray sequence but no fluid comes out
Pull out the small tube connected to the jet the fluid comes out of and check for any kind of debris, after blowing out the tube try and activate washer before you connect the hose again if no fluid comes out of the tube than that replace the small pump connected to the resivoir thay are about $15.00
Nov 29, 2009 | 1998 Chrysler Concorde
Karcher 1750 psi Electric Pressure Washer Logo
2,109 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
