Question about Bernina Artista 180
Bernina 180 - winding thread onto bobbin spool
I have a Bernina 180 and was using it for 8 hrs straight yesterday. I had no problems winding tread onto the bobbin spool then it stopped winding it. I get the message that the bobbin winding is activated and I hear the 2 beeps but nothing happens not even a noise.
Please can you help me
    Problem Solver:
  • 13 Answers
If the bobbin winder spindle turns freely by hand and the macine runs fine with the foot controller then it may be the small motor that runs the bobbin winder that is at fault. If this is the case then your local service tech should be able to relace it. It is not a very costly part so don't be to worried.
Posted on Nov 02, 2008
  • 202 Answers
Also it is quite possible that the small circuit board (P-print) just below the bobbinwinder that the motor plugs into has gone bad.
Posted on Nov 27, 2008
Bobbin won't wind/fill. Post does not spin
Pop an empty bobbin on the thread spool. You need to disengage the motor from the presser foot so that the motor no longer makes the presser foot go up and down, but sends the power to wind a bobbin on the thread spool. Check with your machine's manual, but this is usually done be either pushing in, or popping out a button on the hand wheel. Begin a new thread on the bobbin following the directions either from your manual or as printed on the machine. On my Bernina, I have to push the thread spindle sideways to engage the bobbin winder. Use your foot pedal now and the bobbin will automatically fill up. It should stop when full, then you reverse your actions. eg: push the thread spool back, pop in the button on your hand wheel, insert the bobbin (check with your user manual as to clockwise-anticlockwise, and yes it DOES make a difference!) Re-thread your machine (always with the presser foot up) and make a test stich.
I hope this helps and happy sewing.
Mar 27, 2015 | Juki TL-98Q
Tip
Winding a bobbin correctly
The heart of sewing is producing a well tensioned seam and achieving this with any sewing machine will be difficult if you don't wind a bobbin smoothly and with even tension onto the thread. If you look at your bobbin and the thread on it looks all lumpy and uneven, then this tip is for you.
Each time you wind a bobbin, whatever sewing machine it is on, it is really important to keep even tension on the thread as it winds onto the bobbin. Many machines will have a little tension disc you take the thread around but your technique is important too.
Usually you take the thread from your spool of cotton on the right, across to the left on the top of the machine and around a tension disc, or through a thread eye, then back to the right to your bobbin winding spindle, if your bobbin has holes in it, then pull the thread tail up through a hole and pop it onto the spindle. Engage the spindle by pushing across against the stop. Now start winding SLOWLY while holding the thread tail up in the air until the core of the bobbin has been covered in fully and your thread has covered up the starting point to hold the beginning tail. Stop winding, and trim the tail off against the bobbin with a pair of snips. Now resume winding at 1/2 to 3/4 speed and do two things, one with each hand. With one hand put tension onto the top of the spool you are winding thread off - use the curve of your scissors handle into the indent on top. And with your other hand, give the thread a nudge as it winds onto the bobbin to ensure you wind fully across the whole bobbin evenly. Watch it carefully to ensure that you get a smooth even wind.
An analagy: if you wind the garden hose onto the hose reel really fast and let it go anywhich way, the hose will kink and wind mostly in the middle then the reel's full and you've still got half the hose to put away. Thread is the same, its been wound onto a spool by a machine in a very precise way; you want the same smooth evenly tensioned winding onto your bobbin so that when you stitch out the seam the thread is consistently fed off the bobbin.
Don't be tempted to wind flat out and just let it take its own path as you won't get good smooth bobbins of thread. And if you let the thread come off the spool at a fast pace the spool may bounce around, causing fluctuations in the tension on the thread. When you stich a seam, the thread will relax unevenly in your seam causing puckers and ho hum stitching.
Simple stuff but it makes a difference!
on Oct 02, 2011 | Sewing Machines
Winding bobbin on old elna lotus
I can help you with this, the Elna Lotus has a pretty simple bobbin winding system, the bobbin winder is top right of the machine, drop bobbin with holes to the top onto the spindle. Now Lotus have a dial on the right side which switches between bobbin winding, stitching and locked for transport, turn it to Bobbin symbol. Take the thread from the spool pin at the back across to the metal eyelet at top front (it sits inside the accessory tray when transporting so you may need to pop open the tray lid and flip this eyelet out)
24421001-h4211ohbpts0t3j0sbmab0vm-2-0.jpg Now take thread across and through a hole on top of the bobbin and holding the tail, put your foot onto the foot control to get a couple of winds onto the bobbin to hold the thread. Now place your finger or the handle of a pair of scissors onto the top of the thread spool to apply tension so that the thread winds evenly and slowly wind the bobbin until about 3/4 full, making sure it winds evenly. Tension onto the spool is the key here, Lotus doesn't have a tension device to control the thread tension as it winds so you need to do this, critical to getting a good stitch out of these lovely machines.
Hope this helps you out.
May 14, 2014 | Elna Sewing Machines
Bernina 820 Tension Error Message
You need to take your machine in for service. The 8 series machines have new upper tension parts that can be installed under manufacturer warranty and MAKE SURE your Bernina dealer is well trained on the 820 and 830 or they'll never get it adjusted right. The 8 series are just all around buggars when they're out of whack.
May 20, 2012 | Bernina Sewing Machines
I have a new Bernina 350 and the bobbin doesn't wind on evenly. If left to do it automatically it ends up wrapped around the bobbin spool. Is this normal?
the thread has to be pretty tight around the bobbin tension guide
but I would suggest if you can't get it to wind correctly to have it check to see if there is a problem with it
May 12, 2012 | Bernina Sewing Machines
Bernina 135 bobbin winds unevenly
If you are finding that the bobbin is winding with more thread towards one edge of the bobbin than the other, the bobbin winder motor needs to be adjusted so that the angle of the winder shaft is properly aligned with the tension disc next to the head cover. Unfortunately, unlike many of the other models, you have to remove the covers on the Activa range to get at the adjuster. There is a spring-tensioned screw just to the left of the bobbin winder motor that adjusts the angle of the motor and therefore how it loads the bobbin. If the winder is loading the bobbin with most of the thread towards the bottom edge, the screw should be turned clockwise and if most towards the top, it should be turned anticlockise. Make adjustments until the thread is winding evenly or, at least, towards the centre of the bobbin.
If you are finding that your bobbin is being loaded somewhat randomly, make sure you are using the vertical spool holder to hold the spool and that you've got a foam pad under the thread spool. Route the thread through the thread guide before winding around the tension disc in the correct direction (see the arrow on the case) and ensure that the spool and thread do not vibrate unduly when the bobbin is being wound. If you let the spool vibrate whilst the bobbin is loading, it may result in varying tension on the thread and uneven winding onto the bobbin.
Oct 02, 2011 | Bernina Activa 130
How to fill a bobbin on Virtuosa 150
Put the thread spool on the vertical spool holder with a sponge pad underneath. Wind the thread off the spool and through the small wire thread guide next to the spool holder. Take the thread across the top of the sewing arm to the tension unit just next to the gap in the case through which the thread is normally threaded - the tension unit looks like the top of a shiny screw without the slots in it. Wind the thread in a clockwise direction around the tension unit once and pull the thread with a bit of tension until it slips into the sprung gap around the underside of the shiny part. Slip the end of the thread through one of the holes in the bobbin and, preferably, wind a few turns on, then push the bobbin onto the bobbin winder shaft at the right-hand end of the top of the machine. Turn the bobbin clockwise by hand a few more times to make sure the thread is 'locked' onto the bobbin and then just push the lever adjacent to the bobbin winder to the left. To wind the bobbin, you then press the foot controller and either stop when you've got enough thread on the bobbin or let it stop automatically when full. Make sure you dont go so fast that the spool rattles-around on the spool holder otherwise this could spoil the way the bobbin gets filled.
Sep 28, 2011 | Bernina Virtuosa 150
The bobbin winds really loose and uneven and then gets caught up when I'm sewing. I've checked I'm threading it correctly when winding... seems to be worse with polyester and embroidery thread. Help!
You need to keep tension on the thread spool as you wind the bobbin to avoid this from happening. Also, is there a little tension device to take the thread around between the spool and the bobbin winder? Some machines have a little silver button tensioner purely for bobbin winding to keep the thread flowing smoothly.
But I always do the following anyway just to ensure a smooth bobbin. Take the thread from your spool, through the eyelet or tensioner, then back to the bobbin and put the tail end up through a hole in the top of the bobbin. Now put the bobbin onto the winder and click it against the stop. Place the curved handle of a pair of scissors onto the top of the thread spool and apply some gentle pressure to stop the spool from bouncing and jumping while winding off. Keep doing this through the winding process.
Start the bobbin winding mechanisim, its a button on my Janome 6500, yours might be a little different. HOLD the thread tail until you've got coverage over the whole bobbin area catching the starting point. Stop, trim the thread tail off top of the bobbin with scissors, then restart winding again. Watch as the thread winds and give it a nudge with your finger tip to the top or bottom so the bobbin winds evenly across the whole spool's width.
Best analogy here is when you wind the garden hose onto the reel, if it goes on all over the place you never get the whole length on neatly, but if you wind it on neatly in an even tight coil across the spool, then back again, then repeat, you get a tidy hose. But just wind madly, it all builds up in the middle, you can't get it all onto the reel, and it won't pull out nicely next time you need it. Same thing with your SM thread.
Polyester and silky embroidery threads will be worse too as they are silky, so if the thread hasn't been wound on smoothly and under tension, then it will "collapse" with gravity, then when you use the bobbin, the thread is going to be caught on itself, will feed unevenly and be stretched, then loose, giving you less than perfect stitch tension.
My other bobbin tip is store the bobbins in a plastic bobbin tray so they are lying on their edges and under a cover. Keeps them neater and they are less likely to unwind stray threads around your sewing cabinet if you store them on the spool pins build onto the cabinet door - and it keeps the thread dust free. But I do not keep thread on bobbins for long, prefer to wind a fresh one off a new spool when I start a project and can usually complete a garment with a 3/4 filled bobbin, use the remaining few metres for handsewing, then junk the rest. Then I put the thread spool that is left back into a sealed takeway container to keep it away from UV, dust and moisture.
I hope this assists you with your machine and certainly if this doesn't resolve the bobbin issues, then I'd suggest you visit your dealer and ask them to demonstrate the technique on your machine to see if there is a technical issue with it.
Apr 10, 2011 | Elna Xplore 8600 Computerized Sewing...
HOW TO THREAD THE BOBBIN
Take the thread-end from the thread spool to the left, around the bottom of the "silver" "button"; across the top of the button and back to the right to the bobbin winder.
Run the thread-end through a hole in the side of the bobbin spool, hold onto the thread (pull through about 5" of thread) and place the bobbin spool onto the the bobbin winding pin.
You may have to turn a bit to the left or right to get the spool in place. Push the bobbin spool to the right; against the bobbin winding wheel.
Press on the power pedal - keeping hold of the thread-end.
As the bobbin fills, the thead end will twist.
When you can not longer hold on. Stop the machine and clip the thread end then continue to wind the bobbin.
You can view and download a manual here (free) - http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=XL2230
Mar 25, 2010 | Brother XL-2230 Mechanical Sewing Machine
After following instructions on winding the bobbin for the fast bobbin winding system, the bobbin is not threading
If the bobbin spool is spinning, it will thread.
Take the end of the thread through one of the little holes in the side of the bobbin spool and pull out about 8" of thread. Hold onto it as the bobbin begins to spin.
After the thread has wound 5 - 6 turns, stop the machine and cut off the thread end. Continue the winding process.
Mar 14, 2010 | Brother CS-6000
Sewing Machines Logo
541 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
