Question about Nokia N95 Cellular Phone
Cant reset wlan key password
Right i managed to pick up my wireless router but with being new to the phone i entered the pass code to link up in lower caps and it was meant to go in upper caps now i cant connect it wont let me and i cant figure how u change it please help kind regards michelle xxx
    Brigadier General:
  • 7,752 Answers
Try a master reset of teh phone then try again
Posted on Nov 02, 2008
I cant access wlan connection using dlink router,im using nokia c3-00 .it always says wlan connection failed even if theres a strong signal
if the router is password protected, try reseting it to open and attempt to connect again. If it connects without security then there is a security log error between the two devices.( which is common for n-type routers and/or mobile operating systems.) you will need to select a security type that is listed within your phones settings.
May 13, 2011 | Cell Phones
Tip
Enabling Wireless security on Linksys routers.....
Encrypting the network blocks any unauthorized computer from accessing the network and using its broadband connection. To enable WEP on the router,
1. Open your default browser and enter the following IP address into the address bar: <http://192.168.1.1>
2. When prompted for a username and password type “admin” on password, unless you have previously changed the password of the router, and hit OK. This will bring you to the Setup page of the router.
3. Depending on the firmware of the router. Click on the WEP Key Settings button. Or you can click the Wireless tab and select Wireless Security. Or you can click the Security Tab and select Wireless.
4. From the WEP/Security Settings window, you may enable 64 or 128 bit WEP then enter your Password on the Passphrase field and click on Generate. Make sure to copy the characters on Key 1-4 on a piece of paper before you hit APPLY. You will be needing this once you enable WEP on the wireless PC’s. Also take note that if you enable 64 or 128 bit on the router, this should be the same WEP level that you will enable on the wireless cards.
To put in the network key in your wireless adapter follow the steps below:
WEP Encryption XP's Wireless Zero Configuration ( Advisable for XP PC's )
1. Go to start>Control Panel>Network Connections>Right click on the Wireless connection then click on Properties>Click on the Wireless Networks Tab
2. From the Wireless Network Connection properties window, under the Preferred network click on Add then type your SSID on the SSID field and check the box for Data Encryption then then unchecked “The Key is provided for me Automatically”
3. Type your WEP Keys on both the Network Key and Confirm Network Key field. (This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.) Then hit OK and then OK again.
4. After hitting OK a pop-up should appear on the lower right hand side saying “Connected”. Try pointing your mouse arrow on the lower double monitor icon.
5. Restart your PC
WEP Encryption using the Linksys WLAN Utility ( 98/Me/2000 )
Make sure that the WLAN utility of the Linksys adapter is already is installed. If not, you may follow follow the procedures below for "Installing the Linksys WLAN Utility"
1. Click on Start then Programs, then click on anything that says something about the Linksys Wireless Adapter. On the menu, select either WLAN Utility or Wireless Configuration Utility
2. On the lower right-hand side of your screen, double click on the Linksys Icon. This will bring up the WLAN Configuration Utility.
3. Click on the Profiles Tab. Make sure that the SSID that is set to default is your routers SSID. Highlight Default then hit Edit.
4. Select Profile Wizard. Continue to click the Next button, until you get to the Security Settings Window.
OR select Expert Mode then Next. Then click on Security Settings
5. Set the same WEP level that you have enabled on the router. ( ex. 64 or 128 )
6. Type your WEP Keys. This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.
7. Hit OK then Next. On Confirm New Settings click Yes. And then click “Activate New Settings Now”
If this is a Helpful tip Thumbs Up is appreciated. Thank you
on Jan 03, 2010 | Linksys Wireless-G WRT54G Router
I want to create a new user name and password.
  • Open a Command Prompt - hold the Windows Key (lower left corner of keyboard between Ctrl & Alt keys) and tap the letter R.
  • type "ipconfig" (sans quotes) and press the Enter key
  • Note the IP Address in the IP Gateway (probably 192.168.1.1)
  • Close the Command Prompt - click the X in the upper right corner
  • Open Internet Explorer and type the IP Address for the Default Gateway (again, probably 192.168.1.1) in the Address Bar and hit Enter (or click Go)
  • Enter your current credentials (Defaults: username={leave blank} / password=admin)
Once in the router screen, you'll want to browse to The Administration > Management screen.
  • Administration > Management > Router Access
  • To ensure the Router's security, you will be asked for your password when you access the Router's web-based utility. The default is admin.
  • Router Password: Enter a new password for the Router.
  • Re-enter to confirm Enter the password again to confirm.
Apr 15, 2011 | Linksys WRT160N Wireless Router
Pre-shared key for wlan
If you do not know the key, then you will have to reset the router and set a new key:
http://www.ehow.com/how_2091718_set-up-linksys-wireless-router.html
Linksys reset
Nov 11, 2010 | Linksys Wireless-G Broadband Router
Wie finde ich meine WLAN WPA CODE
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Oct 29, 2010 | D-Link AirPlus DI-524 Wireless Router
I cant remember the key/password to enable my wireless internet
you have to reset your router from the reset button in the back of the router
this will return it to the factory settings
i think its default username and password is admin admin
Jan 02, 2010 | D-Link DI 514 Wireless Router (DI-514)
Does not save wireless security settings
2. From the Wireless Network Connection properties window, under the Preferred network click on Add then type your SSID on the SSID field and check the box for Data Encryption then then uncheck “The Key is provided for me Automatically”
5. Restart your PC
Nov 15, 2009 | D-Link Vonage-enabled Wireless Router...
Need the security code for my network so i can add an other compu
Log into the router's setup page 192.168.0.1
Type in the password, the default password is admin.
Go to wireless Security and you will see your key there.
http://tinyurl.com/phexxc
http://www.ehow.com/how_2091715_obtain-lost-network-key-dlink.html
You can reset the router to default and set a new password and encryption key.
D-Link Router reset
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure. The default user name for most D-Link devices is admin and the password is left blank.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | D-Link DI 514 Wireless Router (DI-514)
I have a d-link router (dont remember the model #) and I cant remember my WEP code - I've looked up help online and everyone says to go to the admin interface - but that does NOTHING! It doesn't show you...
To reset your router, use the following steps:
  1. Press the reset button for 10 seconds. You can use a small object, such as a paper clip to hold down the button.
  2. Do not power off the unit while the router is being reset.
    The unit should now reboot, and once the WLAN light stops blinking the router should be reset.
  3. Open up your Web browser and enter 192.168.0.1 in the address bar.
  4. For the login, enter admin as the ID and leave the password blank.
  5. The reset button is just to the right of where the power cord plugs in to the router.
  6. Remember this resets everything so don't forget to set up your secure network again!
May 10, 2009 | D-Link AirPlus DI-524 Wireless Router
"security key/pass phrase"
Yes, it will set it all back to factory defaults
to set the security again on the router Support site for D-Link is here http://www.dlink.com/corporate/worldwideoffices/?redirect=/default.aspx In principle: Connect your PC to the router with a cable to one of the LAN connections - Now you need to Log into the setup of the router - to do that open a web browser, use Internet explorer (some routers setup pages do not work correctly with other browsers) In the browser address bar - http://192.168.0.1 Enter (admin) for the user name and also for the password. Now you can goto the wireless section or secruity section and set the type of encyption to WEP, WPA, WPA-PSK etc and then make up your own password
On the PC Double click on the wireless connection in the system tray (bottom right hand side of screen) and then connect manually to your wireless signal - you will be asked for the password you set in the router.
Now you are connected.
You may need to remove any old wireless profiles you have on the PC/Laptops
Wireless Profiles - Vista/Windows 7: http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm http://www.tp-link.com/support/showfaq.asp?id=214 - delete the wireless profiles Start> control Panel> classic view> network and sharing center> manage wireless networks Delete the profiles you will then have to enter the wireless security key for any networks you connect to --------------- Wireless Profiles - XP http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm http://www.tp-link.com/support/showfaq.asp?id=186 - delete the preferred networks start> control panel> network connections> right click on the wireless connection listed wireless networks tab in the preferred network list click on each one and - remove button
Dec 19, 2008 | D-Link Wireless
Nokia N95 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
