Question about Philips TV Tuner Video Capture PCI Card - Phillips Digital (652101138177)
Phillips tv when i push the power button it just flashes red and then nothing only comes on sometimes
  • 5 more comments
  • mmccutcheon2 Nov 22, 2008
    When I push the power button , the red light flashes, but the tv do not come on
  • Anonymous Mar 29, 2009
    Smae red light issue,consumer report.com is littered with this issue. Everyones (consumer report.com) best advise is to scrap the unit,as repair is expensive and short term,the boycott phills.Seems to be the same model just different screen sizes, model PF9631d/37,,the ones with ambi-lite seem to be particularly prone.
    Welcome to the 2000.00+ paper weight club.
  • Anonymous Apr 10, 2009
    I have the same problem. Red light comes on but tv is dead. I will sue Phillips. There should be a recall on this tv.
  • connieabadie Apr 10, 2009
    I will sue phillips. I have the same problem. Red light comes on and tv is dead. there should be a recall on these tv's.
  • nedyard01 Apr 20, 2009
    While watch my set, it will remain on for about an hour when it hasn't been watched that day, then it goes dead. I can't even turn the set off with the remote of my DirecTV control or the remote that goes with the set. The only way I can stop the red lite from flashing is to unplug the set, when I plug it back again after several minutes, the set will come on again but it will only stay on for about 15 or 20 minutes.
  • AmyHairArtis Apr 25, 2009
    well sometimes we turn it on and its fine for hour and then when we are really into something it will go blank with red light flashing, or it will go small to the center and black and white with no sound , or it will have little red stars all over the screen, oh and my personal favorite when it just goes hay-wire and spazzes uncontrolably1 I have model #32pt81s127 37 inch phillips piece of $%@! Please contact me at 843-452-4208 or @ AmyHairArtist4You@sc.rr.com
  • Anonymous May 09, 2009
    Same issue just happened to me. Phillips LCD with ambilight just went dead. Red light is flashing but no picture. This TV is less then 2 years old. Please tell me this is covered under some sort of insurance plan. Otherwise, Phillips will be getting sued.
    Sniper:
  • 63 Answers
Well depending on your manu date check to see if you are here on the list...
http://www.cpsc.gov/cpscpub/prerel/prhtml06/06536.html
Posted on May 13, 2009
My Phillips 42PF7320/79 Flat Panel TV won't turn on, screen stays black but green pwr light is on, after a lil while the green light flashes a couple of times then goes off itself completely
This idea may be worth a try. Look at the buttons on your remote. If you see a button that is marked "TV" give that button a push and then give the "Power" button a push. Wait for a while! sometimes this takes a while to turn the TV on or off. You may have to do this a couple of times depending if the power was off or on when you started doing this. If you started with the set off, sometimes it takes a while for the set to turn on.
Jan 04, 2015 | Televison & Video
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
When the power button the red button flashes but nothing else hap
the red light flashing means the set is in auto shut down, could be a power supply problem or a convergence IC problem. tech should first check all diodes and caps in power supply then replace convergence IC's
Jan 11, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Phillips plasma
Five blinks is a severe hardware failure supplys not working. Viper is down. You have atleast a bad power supply board could have taken out your sustain boards. If you are good with a meter you can measure voltages and see if just your power supply is dead. If you have never handled a multimeter you will need a tech and a power supply is not cheap..Power supply is about a 600 dollar board.
Feb 05, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Black screen no sound
What is the model or chassel number it be a few thing H.O.T Resistor Caps etc..most likely horizontal output transistor.
Nov 12, 2007 | Televison & Video
Televison & Video Logo
576 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
