Question about Apple iPhone Smartphone
Iphone bluetooth hi.i am having a hard time with my blue tooth device. why cant i connect to other devices? help
Dear Sir,
iPhone does not support Bluetooth to transfer data between iPhones or computers, the only usage for Bluetooth for Syncing the iPhone with Bluetooth headset, so its not an error only you need to connect it with Bluetooth headset, by searching for headset and set the passkey to authnticate the phone with the headset
Posted on Nov 03, 2008
How do I get the blue tooth to cancel the "in use" signal"?" The phone or car functions do not respond to any prompts.
Maybe i don't get it, but you can simply turn off bluetooth on your iphone to cancel all bluetooth connections immediately. Re-Enable bluetooth to re-engage your connections.
If you wan't your iPhone to "forget" a paired bluetooth device just go into the bluetooth settings and tap on the little info badge for the device you want to remove. From there you can delete this pairing.
Apr 24, 2014 | Apple iPhone4 4G iPhone 4
How do I fix iPhone microphone Problems with headset and Bluetooth?
Go to the settings on your I phone select search for blue tooth device and at the same time hold down the large button on your blue tooth device until it flashes blue and red keep it pressed until it stays blue then your phone will be pared to you're blue tooth device.
Mar 15, 2013 | iPhone Apps
Why cant i blue tooth with my new iphone 3
  1. Turn off the headset.
  2. Press and hold the headset button for about eight seconds, until you hear the startup tone and then five quick high beeps.
    The headset is now discoverable and will remain so for about five minutes. The status light blinks while the headset is discoverable.
Step 2: Turn on Bluetooth on the other device and search for devices
  1. On the device, turn Bluetooth on and set the device to search for other Bluetooth devices.
  2. On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000.
Feb 27, 2011 | Apple iPhone 3G
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
Need password to connect to my phone. Motorola bluetooth H371
Hi,it all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hope it helps..
Thanks for using fixya...
Oct 27, 2010 | Motorola Mobility H371 Bluetooth Headset
I just bought a samsung soltice phone and I have a scala-600 bluetooth but I cant seem to get them to connect have any suggestions and I have used a bluetooth befor.
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Take care.
Sep 12, 2010 | Cell Phones
IPhone 3G bluetooth problem
the iphone 3g bluetooth is at present for headsets/handsfree devices only and cannot link/pair with anything else (phones/pc etc) it has been deliberately crippled to force file transfer etc to be done exclusively through itunes
Jul 15, 2008 | Apple iPhone 3G
Blue tooth device is not working
hi,
check if your device is enabled, you can do this by ---
right click my computer..-> properties--> hardware tab--> device manager --> right click on the blue tooth icon and clcik properties. --> check if enabled..
if it is enabled check if bluetooth is enabled at startup { type msconfig in RUN in start menu, click startup tab..check if it is enbaled in startup}... or else you have to manually switch on bluetooth each time u intend to use... hope it helps.
hope to get rated as helpful...
regards
bzoy
Dec 31, 2007 | Computers & Internet
Blue tooth
The iPhone is supporting Bluetooth v2.0, but for headset support only.
See the iphone specification here:
http://www.gsmarena.com/apple_iphone-1827.php
That's mean it can use the bluetooth to connect only, with bluetooth headset.
Dec 28, 2007 | Apple iPhone Smartphone
Apple ifone bluetooth
you have to make sure that bluetooth is turned on.
go to your home screen, touch settings, then general, then bluetooth, make sure the bluetooth switch is set to on.
Then follow your directions for the your headset for pairing, usually it involves holding the power button down for so many seconds, then it will enter a "pairing" mode where the headset is able to be seen by phones.
Once that happens it should pop up on the bluetooth page of the iPhone and it will ask for the devices password. Most devices the default password is 1111.
Hope this helps and enjoy your Iphone, I know I do ;)
Dec 10, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
372 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
