Question about Biostar K8M800 Micro AM2 Motherboard
I can't boot from CD. Can't boot previously installed OS
I jus purchased a Biostar K8M800 Micro A2 motherboard combo with an AMD Sempron Processor LE-1100. I setup evertything and power up, it goes though the POST shows that I have a HDD and an optical drive etc. When I try to boot from the OS to install the OS, it goes to the boot from CD prompt, then the cursor jumps down a line then, it says "NTLDR missing. CTRL+ALT+DEL to restart". How do I overcome this and install the OS or boot from a previously installed OS?
  • 2 more comments
  • deetood Nov 02, 2008
    Hi Mike. I did set it to first boot from CD. And I'm using the OS setup disc, but it still does not work. When I start the machine, I see the drive light flashing, but when I select boot from CD, it stops and does not blink after that. IT seems to be skipping the boot from CD part and keeps looking to the HD from the OS, cause it keeps saying "NTLDR missing". The HD is formatted already. I just want to install the OS and setup the machine.
    Thanks Mike. I'd try that in the morning. However, I noticed that the RAM I have installed is DDR2 800. Looking on the Biostar website, they had DDR2 533/667. I don't know if that would make some differnece.
    Good morning Mike,
    thanks for your time and effort last night. I've gotten past my 'non-booting' problems. It was just as you thought, the OS cd was a copy. I'm using an original DVD now and the OS is proceeding to install.
    Thanks again for your time and effort. If anything else comes up, I'd be sure to let you know!! :-)
  • AMIT BABU Mar 02, 2009
    YES
    Scholar:
  • 124 Answers
Hi, Make sure that you set the POST first boot to CD. If the disk is a bootable disc, you should be able to boot from the CD. If you have any questions, please feel free to contact me ASAP. Thanks, Mike
Posted on Nov 02, 2008
  • 1 more comment
  • Mike H. Nov 02, 2008
    Hi Again,
    There could be four things that has to be checked.
    1- Is the OS disc an original disc or a copy? If orginal then proceed to step 2.
    2- Go back into the BIOS and set it to the default setting. Make sure you hit save settings before you reboot. Reboot and lets see if the system will boot from the CD/DVD drive.
    If not, Go back into the BIOS and confirm that the first boot is set to the "correct" CD/DVD drive ( just in case you have two disk drive).
    3- If the BIOS settings are correct then power the system off. Remove the HDD and replace it with the CD/DVD drive. Boot the system and see if it will boot from the OS CD. If not, go back into the BIOS and set it to first boot from the HDD (since now we have the CD/DVD drive connected to the IDE line and cable.
    If the system starts to boot with the OS disc, then the problem lies with a defective IDE cable.
    4- If so far the system does not boot with the OS CD, then the problem lies with the CD. Clean it, it might be dirty or scratched.
    Let me know the outcome.
    Thanks,
    Mike
    If it was a ram issue, you would not be able to get into the BIOS.
    Instead you will hear a continues beep, or the system will appear dead, or you will receive a message that indicate unsupported memory module.
    Good Night,
    Mike
    Hi There,
    I am glad to hear that we were able to isolate the booting problem.
    You are more then welcome to contact me if you need additional help.
    Enjoy your day.
    Thanks, Mike
Dont know the ram that it use. wat is the number on the battery
  • K8M800-M7A
  • Support DDR 333/400 MHz
  • 2 x DDR DIMM Memory Slot
  • Max. Supports up to 2GB Memory
  • the battery i dont no
  • hope it helps
  • Biostar K8M800-M7A - motherboard - micro ATX - Socket 754 - K8M800 specifications
    • General
    • Product Type Motherboard - Micro ATX
    • Cache Memory None
    • Chipset Type VIA K8M800 / VIA VT8237R
    • Max Bus Speed 800.0 MHz
    • Processor Socket Socket 754
    • Max Processors Qty 1.0
    • Compatible Processors Athlon 64 , Sempron
    • Memory
    • Max Supported Memory 2.0 GB
    • Supported RAM Technology DDR SDRAM
    • Supported RAM Speed 400 MHz , 333 MHz , 266 MHz
    • Graphics
    • Graphics Controller VIA UniChrome Pro
    • Memory Allocation Technology Shared video memory (UMA)
  • Jul 20, 2011 | Biostar K8M800-M7A Motherboard
    Matharbord drivars
    http://www.biostar.com.tw/app/en/mb/driver.php?S_ID=209
    Nov 18, 2010 | Biostar K8M800 Micro AM2 VIA K8M800 uATX...
    I have a biostar board A740G M2L, I want to know if the sempron processor will work?
    Hello
    A740G M2L+
    Click here this is the specification sheet for your Mainboard.
    Yes, Sempron AM2/AM3 processor will work.
    Best of luck building your PC it is very exciting.
    Oct 24, 2010 | AMD Computers & Internet
    What is the best procesors(powerfull) for motherboard NF 61S MICRO AM2 SE..?
    AMD Athlon™ X2 Dual-Core Processor
    AMD Athlon™ 64 X2 Dual-Core Processor
    are the best processors for this motherboard
    Nov 28, 2009 | Biostar NF61S MICRO AM2 SE...
    Gigabyte k8m800-8237 won't boot with 2nd gig ram installed.
    Could have been dusty. Find a copy of Memtest and run it to check things out. Errors could mean a bad stick or bad slot.
    May 03, 2009 | Gigabyte GA-K8VM800M Motherboard
    IS MCP61S THE SAME AS NF61S MICRO 754
    Biostar offers NF61S MICRO 754 Motherboard + AMD Mobile Athlon 3200+ (COMBO56), NF61S MICRO 754 Motherboard + AMD Mobile Sempron 3300+ (COMBO56A),NF61S MICRO
    Motherboard Processor:
    Socket 754
    Supports AMD Athlon 64/Sempron Processor
    Support AMD HyperTransport up to 1.6G
    Supports AMD Cool'nQuiet Technology
    • Chipset:
    NVIDIA MCP61S(GeForce 6100/nForce 405)
    they are the same motherboard .hope this helps pls appreciate by rating it as fixyaa
    Oct 10, 2008 | Computers & Internet
    Biostar K8M800 Micro AM2 Motherboard Logo
    380 people viewed this question
    Top Biostar Computers & Internet Experts
    Jayburt
    David
    David
    Jerry Umali
    Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
