Question about Tricity Bendix TM310W Electric Dryer
Tank full light stays lit.
After emptying the water tank and replacing it into the machine the tank full light still remains lit and the dryer will not run. I have went through all the steps in the trouble shooting guide. Turn the machine off for several hours, clean all the filters, removed and cleaned the condensor unit, and the light still is on. Any suggestions please?
  • DEDE23 Jan 03, 2008
    i have the same problem full light tank stays on tryed the stopper at rear of machine and emptyed tank
  • lorraine1810 Jan 02, 2009
    we have the top, left hand side and back of the machine off, we've cleaned the white stopper at the bottom at the back - where is this black float - the machine is in bits right now!
Under the water bottle is a drain hole,when the bottle overflows water runs down this hole through a pipe to a reservoir behind the condensor unit, there is a float in this reservoir that rises and clicks a switch that activates the full tank light and stops the machine working,
removing the stopper at the rear and emptying the reservior should do the trick,If the float does not go back down due to dirt in the machine the left hand side panel can be removed by taking off the top then the retaining screws,one inside at the top the rest in the back panel,remove the one screw holding the float switch unit and clean the black float.(Make sure it's not plugged in)
Posted on Jan 21, 2008
  • Cavershamlad Sep 25, 2010
    Fantastic solution - solved my problem [which was the dirty float] - Thanks a million!
Fixed it. Thanks a mill.
Posted on Mar 07, 2009
I'm having exactly the same problem. Have you resolved it? If so what did you do?
Posted on May 27, 2007
Just fixed mine. it has a plug at the bottom rear of the machine. you undo the circlip and take off small white rubber stopper, then water comes out and hey presto. Then put it all back as you found it.
Posted on Nov 16, 2007
The full tank light remains on even though the tank is empty. Is there a sensor which stops the dryer from restarting
The warm and cold air circuits cross inside the heat exchanger, which results in a thermal exchange which condenses the humidity contained in the warm air. The condensation which forms in the heat exchanger is collected in a sump, from which it falls by gravity into a tank. When the water in the tank reaches the max. level, the level of the water in the sump increases, which causes the float to move upwards, thus actioning a microswitch; The microswitch for dryers with electronic board sends a signal to the electronic circuit when the tank has been filled, switches off the appliance and lights a pilot lamp which indicates to the user that the tank is full. The microswitch with electromechanical control switches off the dryer (the timer motor is powered and ends its cycle) and lights a pilot lamp which indicates to the user that the tank is full.
The tank capacity is about 3.5 lt., enough for a drying cycle.
- Remove the screw (1) which secures the support micro and use a screwdriver for the two hooks which secure it to the sump.
- Lift them simultaneously and unthread the micro support towards outside
Putting upside down the support you can access the floating microswitch.
25069013-hcssld2gpo2sm22yg24xoxcy-3-9.jpg Inside the sump there is the float.
To extract it rotate the float 90° clockwise as shown.
Lift it up, rotate it towards outside and extract it.
While reassembling the pump, the float and the tank microswitch, repeat the same operations backwards, paying attention that when the micro support is remounted it is necessary to use a screwdriver in the fissure (indicated by the arrow), to lift the micro lever and lean it over the float (if this operation is not carried out the lever of the micro comes up alongside the float (it deforms) and the two components do not function anymore.
25069013-hcssld2gpo2sm22yg24xoxcy-3-20.jpg Dado
Sep 06, 2014 | Zanussi Dryers
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
Why does my water container fill up even though my machine is plumbed in?
This looks like a fault. The plastic tank has two reed switches that measure 'tank empty' and 'tank half full'. When the tank is empty the inlet solenoids (there are 2 for safety) open and water enters the tank but not so much to fill the tank to the half way level. In normal operation the level water in the tank will drop and then more water is allowed in. In your case it appears the 'half full' reed switch is being activated because the solenoids are not closing off properly and water is leaking in and filling the tank. If you do not empty it then eventually it will fill and leak into the leak. The problem can be caused by either low water pressure (below 145 psi) or sticky solenoid. If is the solenoid then the Miele solution will be to replace both solenoids. Alternately you may be able to remove, take apart and clean. Also check that you have a mesh filter at connection to tap. Also you can temporarily fix the problem by turning off the water at the tap and re-programming machine to 'turn off' the plumed water line. regards
May 31, 2014 | Miele Coffee System
Will not stay lit,I have a new gas tank and it light the first burner but will not light others and will not stay lit
Turn off the propane tank and disconnect the hose from the tank. Wait 5 minutes, reconnect the hose and turn the tank valve on very, very slowly, until it's completely open.
Now light each burner one a time and turn it to high. If the burners all light and the flames remain burning on high for more than a few minutes, you're back in business. Just remember to turn the tank valve on very, very slowly after turning it off each time.
If the above didn't solve the problem, are you sure you tank gas a significant amount of gas in it?
If that's the case (empty tank), when you replace it, do exactly what I said above when you connect a full tank to the grill hose.
Hope that solved your problem. Happy Grilling!
Feb 12, 2011 | Kenmore 882 sq. in. Cooking Area Gas Grill...
Empty water light flashing on hotpoint ctd40 dryer even with no water in it can you help
this could be just a sticky switch staying stuck on, telling the dryer it has a full tank try soaking the switch in switch cleaner or wd40 may work
Jul 23, 2010 | Hotpoint Dryers
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
Hotpoint dryer TDC32
check the switch where you remove the tank towards he bottom
Dec 30, 2007 | Hotpoint TDC32 Electric Dryer
Tricity Bendix TM310W Electric Dryer Logo
1,292 people viewed this question
Top Tricity Bendix Dryers Experts
jimorris77
Marvin
Marvin
Donni Steen
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
