Question about Panasonic SC-HT740 System
SA-HT740 Broken gear
We have a broken gear that opperates the drawer. How do we get a new service manual and the parts?
    Champion:
  • 279 Answers
Posted on Sep 20, 2009
  • 21 Answers
You probably can get the parts from Tritronics, but as far as I know, there aren't hard-copy manuals normally made for any of the newer products. The only paper available nowadays are the users manuals... The service manuals are on-line at Panasonic and available only to authorized repair centers. Sorry.
I'm curious - how in the heck did a gear break in the thing??? There's nothing strong enough in the drive system to do that (either the motors would sieze or belts slip).
Bugman Mark
Posted on Nov 12, 2008
3 Suggested Answers
SOURCE: Panasonic SA-HT740
The F61 fault means the fan needs to be replaced. My system had the same problem and the fan was making a terrible noise. I had this repaired and the system is as good as new. Although I have the SA-HT995 system, it sounds like the same fault.
Still under warranty? Get it fixed for free....
Posted on Aug 23, 2008
I get this error usually once during a movie. Sometimes it is 10 minutes into it, sometimes it is an hour, and the only thing I have ever been able to do to get it to work, is to unplug the black power cord from the unit, for 20 seconds, and then reconnect it, and it usually works for the remainder of the movie. Would like to see a better fix, however!!
Posted on Oct 09, 2008
125cc Kawasaki dirt bike, cranks on first kick, idles but won't run in any gear, doesn't die out but doesn't seem to engage gear, possible problems?
Does it jerk forward when you put it into gear and die? Or you put it into gear and the bike doesn't move when you let the clutch out? Badly adjusted clutch in both cases. Worst case, you need new clutch plates and springs.
Mar 25, 2017 | kawasaki Motorcycles
1986 yamaha rt 180 stuck in first gear
Hi, B and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.vitalmx.com/forums/Race-Shop,42/Bike-stuck-in-1st-geat,450813
First dirt bike Yamaha RT 180 issue Page 2
1990 1998 YAMAHA RT180 Service Manual Repair Manuals AND Owners Manual... $10
OEM parts for Yamaha
Yamaha RT180K Owner Manual
Jan 30, 2012 | Yamaha Motorcycles
I have a pananosic sa-ht740 theatre system and my remote control wont work. maybe it's broken, but how do I get my receiver to reset? I'm trying to lower the high base. Secondly, how do i get my...
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Sep 05, 2011 | Audio Players & Recorders
Hello, my Panasonic SA-HT70 has a problem with the DVD tray. The drawer opens and closes on its own and then it just says ERROR. There is no way to eject, play or change discs, I have tried all the...
This sounds like the timing for the drawer has beed knocked out of alignment...usually when someone pushes door in instead of pressing eject buttton...you can take top off to remove the discs...the timing can be realigned( assuming there are no broken parts). The best way to re-align the timing is top obtain the service manual. Here, it will give you detailed instructions on what marks to line up....you may be able to get a service manual from UED.net...They are a panasonic parts dist.
Jan 04, 2011 | Panasonic Home Theater System System
Want to use Panasonic SA-HT740 for TV sound
Get the TV audio from the Dish box directly to the receiver.
Feb 16, 2010 | Audio Players & Recorders
Drawer won't open for dvd, makes sound but wont open, panasonic sa-pt760
Hi
The small belt inside the drive is most likely out of place or broken.
That is the most likely cause, you will have to open the dvd player in any case to find out the issue and to replace the belt if that is the issue.
You can eject the drive manually to find the fault by rotating the gears once you get inside.
Jan 19, 2010 | Televison & Video
My Home Theater System is displaying F61,it's a panasonic SA - HT740
The problem is not the fan but either the amp pac or the regulator. If you can update this with the model number of your unit (SA-xxx), I can get you the probable part and cost.
Thanks,
Dan
Jan 04, 2009 | Televison & Video
5CD changer SA-Ak640 will not open disc trays just diplays "CHGR ERR" is locked on disc 5
The loading mechanism has jammed somehow. When powered on, the unit attempts to get to a known position. If that fails, the message you indicate is displayed. The only way to resolve this is to dis-assemble the unit and rebuild the mechainsm. This should NOT be attempted without the service manual. There is a particular way to re-assemble these so that the gearing is correct. There are small gears and levers that need to be aligned properly. Also, there may be a broken lever or gear that needs to be replaced. I have rbuilt a number of these and the parts (if needed) are cheap (<$4 total).
I wold suggest that you bring this to an authorized Panasonic service center.
Dan
Oct 16, 2008 | Panasonic Audio Players & Recorders
Broken tray Panasonic SA-HT820V
You should note that u will not be able to order that particular alone, rather you can only get the entire mechanism.
Thanks........!!!!!!!!
Feb 08, 2008 | Audio Players & Recorders
Sa-ht740 power problem
I have same problems please If you know anything help me
my email adress
rifatsahin@hotmail.com
thanks
Nov 08, 2007 | Panasonic SC-HT740 System
Panasonic SC-HT740 System Logo
125 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
