Need to add mac address to router form xbox 360 wireless connection
I have one xbox 360 connected to the kyocera 2 router via ethernet connection. I have an additonal xbox 360 that I would like to setup through a wireless internet adapter and was told that the mac address needed to be added. Is this something you can help me with?
  • 488 Answers
If its for the xbox then follow this:
. Navigate to the System area of the Xbox Dashboard.
2. Select Network Settings.
3. Select Edit Settings.
4. Select Additional Settings.
5. Select Advanced Settings.
The MAC address will be displayed toward the bottom of this page where it says Wired MAC Address.
hope it helps!
Posted on Nov 02, 2008
My xbox doesnt want to pickup the ethernet connection
There are two ways in which you can address this issue:
1) Attempt to connect wirelessly. You can access this feature via "Settings" on your XBox home page. After setting up your XBox to automatically connect to your internet router (by entering the password and name), you should be able to log into and play on XBox Live.
2) Connect via ethernet cable.
Although you've already tried this, it's possible there is an issue with your modem and not your XBox. Routers and modems usually have a shelf life of about 2-3 years-- if you have had yours for longer than that, it might be time to invest in a new one. Another issue could be a faulty ethernet cable-- they're usually pretty cheap (around ten bucks), so if the above fixes don't work go into a local electronics store, purchase one, try it out, and if it doesn't work return it immediately and you should get your money back.
Jan 31, 2012 | Microsoft Xbox 360 Console
How do i connect to live?
1. Make sure first no other devices connected to the modem at the same time as some modems has an Ethernet port along with a USB port so, you might think you can use both at the same time & connect the PC through USB with the console through Ethernet & that's incorrect so, we need to disconnect the PC first.
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live".
applysettings.jpg3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Edit Settings" then "Additional Settings" tab then select "Advanced settings" & put the Physical Address of your PC without the dashes on the "Alternate MAC Address" part and select "Done", when it asks you to Apply Settings choose "Test Xbox Live".
b. Wired connection to router:
1. Go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
c. Wireless connection to router:
2. Go on the Dashboard of your Xbox 360 console to the "system" area then "Network Settings" then "Edit Settings" then select your wireless settings part down there "Wireless Mode, Network Name,..." the console will automatically then search for your wireless network and when it find it and you select it, it will ask you to enter your wireless key which is called WEP or WPA key - you can find it written on your wireless router or then you need to contact your ISP (Internet Service Provider) to get it from them - when it ask you to apply settings select "Test Xbox Live". editbasic.jpg3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you'll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
4. If it's still not working, you can put the Xbox 360 console - as a trial - in a closer position to the router to see wither it's going to pick up an IP address or not.
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
d. ICS (Internet Connection Sharing):
1. Go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore to Factory Default" when it asks you to Apply Settings choose "Test Xbox Live".
2. Allow the ICS option on the PC as mentioned before, then test Xbox Live.
3. If it's still not working, set the IP Settings manually to be:
IP Address: 192.168.0.2
Subnet Mask: 255.255.255.0
Gateway: 192.168.0.1
Then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose "Test Xbox Live".
If you faced any other kind of troubles with this part failing even after you tried these steps please don't hesitate to leave a comment.
Read more: http://xbox360help.blogspot.com/2007/04/ip-failed-xbox-360-live-test.html#ixzz14pRocyB3
Nov 09, 2010 | Microsoft Premium System for Xbox 360
How do i connect my xbox 360 with my netgear router, plus be able to go on internet on the pc using ethernet cables? i unplugged everything and now cant do both at the same time
A. Determine the IP Address and MAC Address of the Xbox.
Note: You may find the IP address and MAC address of your Xbox on your Dashboard's Network Settings. Please refer to your Xbox manual for more information on this.
B. Reserve the IP address.
1. Please open any web browser like Internet Explorer or any Mozilla Firefox.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. For security reasons, the router has its own username and password. When prompted, enter admin for the Username and password for the Password, both in lower case letters.
Note: Username and password are case sensitive. If it does not take password as the password, you might have changed it when you ran the NETGEAR Setup CD so please try other passwords.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address, and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Forward the ports.
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced. For older firmware version, click on Port Triggering tab or just click Port Forwarding on Please select the service type.
2. Click Add and another window will pop up.
3. Type Xbox for Name. Set the radio button to Enable.
4. On Outgoing Port Range, set the Start Port and End Port to 3074.
5. On Incoming Port Range, you also have to indicate 3074 for Start Port and End Port. Save the settings by clicking on Apply.
6. Please repeat steps b to e and indicate 88 for Start Port and End Port. Then change the Name to Xbox2.
Note: If it still does not work, you may try these other options:
D. Lower down the MTU.
1. Access the Setup page of the router (refer to Step 2 above).
2. Click on the WAN Setup under Advanced tab.
3. Lower down the MTU size to 1492, 1400, 1358 or 1300.
4. Click on the Apply button.
E. Enable UPnP.
1. Go to UPnP tab of the router.
2. Enable UPnP and then save the settings by clicking on Apply. Some websites and devices require UPnP or Universal Plug and Play. Just make sure that it is enabled on the router.
F. Upgrade the firmware.
Note: Follow the steps below if the above troubleshooting still do not allow Xbox to connect using the router.
1. Please verify the router version and model either underneath or at its side panel.
2. Go to http://kbserver.NETGEAR.com/downloads_support.asp and please select the model of the router.
3. Click the appropriate version of the router.
4. Select the link of the latest firmware. Click the button Right-click and Save to Download. Save the file to the Desktop.
Note: Please perform firmware upgrade with Wired or Ethernet connection only.
5. Before upgrading, please write down all current settings since you need to enter them manually.
6. Using the computer hardwired on the router, please launch Internet Explorer and access the Setup page of the router (refer to Step 2).
7. Click on Maintenance and then Router Upgrade.
8. Click on Browse and locate the upgraded file in your Desktop. Then click on Upload.
9. Please wait for the router to reboot. After a successful firmware upgrade, you need to reset the router.
E. Reset the router.
1. Please push the reset button at the back of the router and release after 30 seconds.
2. Unplug the power adapter for 10 seconds and then plug it back in.
(this note should go before the step to Reset the router) Note: Resetting the router will erase all the settings so it needs to be reconfigured afterwards. The router can be reconfigured using the setup CD or by manual configuration.
Apr 02, 2010 | NetGear WGR614 Wireless Router
BT HomeHub wireless router which cannot connect to the XBox 360
your router may have incorect connection settings. what i mean is that your router may have security on that rejects connecting to adapter. check if the xbox can connect to the internet via ethernet cable. this will tell for sure if the 1 the adapter cannot read the signal or 2 the adapter is not able read any signals. to test if its the adapter, try searching for other signals.if you find any other signal it means your router. is rejecting to send the signal to the xbox.
Feb 01, 2010 | Microsoft Wireless Network Adapter Xbox...
I have a wireless router hooked to my computer & my son recently got a wireless-G USB adapter so that he can play his xbox 360 online. Will this work, or will we have to put the router on the xbox...
XBOX 360 will only work properly with a 'genuine' USB WIFI adapter designed specifically for it (and at an over inflated price IMO!).
One popular way to play 'network' via the internet is to connect the XBOX 360 to your PC via Ethernet cable and have the PC connecting to the internet either via another ethernet connection or more likely via a Wifi connection which could be via your USB adapter connected to your PC and talking to your Wifi Router)
Dec 26, 2009 | Computers & Internet
Trying to connect to xbox via my fonero+ router but with no luck, can you help?
If the xbox is hooked up with ethernet cable then make sure all settings are set to automatic. If your xbox is hooked up with a wireless device that is set up to router then, make sure all your mac addresses are correct and mae sure you set your IP's and DNS codes.
Feb 01, 2009 | Microsoft Xbox 360 Console
XBOX 360 not connected to wireless connection on Linskys WAG54G2
You should enter the "Wireless MAC Address" of the XBOX and not just the "MAC Address". You can see it on the system info of the XBOX settings.
Jan 06, 2009 | Computers & Internet
Xbox live dont work please help
the reason for this part to fail differs along with the difference of the type of connection you are using to connect your Xbox 360 console as follows:
a. Direct connection to modem:
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live". 3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Edit Settings” then “Additional Settings” tab then select “Advanced settings” & put the Physical Address of your PC without the dashes on the “Alternate MAC Address” part and select "Done", when it asks you to Apply Settings choose “Test Xbox Live”.
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you’ll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore to Factory Default" when it asks you to Apply Settings choose “Test Xbox Live”.
Then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose “Test Xbox Live”.
If you faced any other kind of troubles with this part failing even after you tried these steps please check me
Jan 03, 2009 | Microsoft LIVE ONECARE 2.0 XP/Vista for PC
My xbox live doesnt work
If you faced any other kind of troubles with this part failing even after you tried these steps please check me man
Xbox 360 to wireless laptop
Make sure ethernet cable from XBOX 360 is connected to one of the 4 access ports on the back of the router.
Mar 16, 2008 | Microsoft Xbox 360 Console
Computers & Internet Logo
2,571 people viewed this question
David Payne
David Payne
