Question about Akira PK-8401 84 in. HD-Ready Plasma Television
ORION PK-8401 ONE OF THE PANEL HAVE PIXEL BURING , HOW TO REMOVE, HOW TO ADJUST COLOR, IF POSSBILE SEND SERVICE MANUAL.
    President:
  • 3,130 Answers
WOW expensive set! Sorry to inform you that you do not replace separate pixels in this set. It comes as a whole assy. There are 4 of them and last time I saw one or the price it was around 4 to 5 grand I think. Or the driver board is bad. I would disconnect one panel and connect it to one of the good panels to see if it is the panel or the driver board. That would be one heck of an expensive mistake.
Posted on Sep 22, 2006
SOURCE:
Monitor will rotate but the screen won't switch from horizontal to verticle position
control panel,display,appearance color scheme you can change your colour scheme there also you can change other settings
settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range
control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right
click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
control panel,display,settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range or
troubleshoot also select advanced then general
dpi normal size,larger size or custom settings
hope this helps
Dec 11, 2010 | Computers & Internet
When i put the computer to max resolution, i get blue pixels flying around in the left of the screen!
control panel,display,settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general
hope this helps
Nov 01, 2010 | Acer 22" X223w LCD Monitor
How to perfectly color match the projectors?
go into settings and adjust to likeness. or project colorbars and adjust to that.
Jun 22, 2009 | Akira PK-8401 84 in. HD-Ready Plasma...
Black line half way down the center of the screen,about 1.5 inche
There's a 'data control' and/or 'address' problem that's developed. Pixels depend on voltage, control, and data coming too their designated address.
A digital circuit feature called a 'DATA_ADDRESS_ BUS" are responsible for 3 criteria: Delivering voltage, control, and data to each pixel in less than a second.
1) If voltage fails the pixels don't light up. They appear black in color (their 'off 'state)....numerous pixels that don't light up look like a black line. But their actually individual pixels with no voltage.
2) If control fails then all pixels are white in color (their 'on' state). Without control the pixels can't adjust properly to high or low 'state', meaning brightness and dimness. This looks like a white line vertically on the screen.
3) If data fails then the pixels can't adjust to the proper color at the proper time.
This appears as a line that changes color out of sync with the entire picture.
Have a technician look at the pixel address registry circuits. As well as control and linear circuits....the problem is somewhere in there!
Jun 13, 2009 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Pixels aren't refreshing correctly in upper right hand side of screen
You might have a Service Co. come out and look at it. It sounds like the Z module is not doing it's job of erasing all prior images after a scene change. Some models there are adjustments for that internally. ( only for a tech ) Start a paper trail now.
Apr 28, 2009 | Televison & Video
I have a problem in 84" orion plasma tv. in which one qudrand picture is comming like vertical lines
84" tv wow. You must be rich! Modern televisions are controlled in sections. If you are having trouble with just one quadrant on your tv, then the video driver board responsible for that spot has gone out. I would expect you will have to pay a tech to replace the board for you. That should cost at least 500-1000 minimum I would guess.
Jan 08, 2009 | Akira PK-8401 84 in. HD-Ready Plasma...
Red pixels on the Srceen
Dead or stuck pixels are not uncommon in LCD displays, and the less you pay, the more likely it is to happen (as a general rule) Most manufacturers will a dead pixel warranty, ranging from 7 days to lifetime.
Read your warranty carefully, and speak to the place where you bought your display.
I hope that helps, if you have any further problems, please add them ass comments to this question. If I have been able to answer your question (or not) please click on one of the ratings buttons to let everyone know how I did.
Thanks for your feedback, and good luck.
Jan 14, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
On the Screen Red pixels comes in the background
hi
if you are see red pixels then your monitor haveing LCD Panel problume.
thanks
Ashok
Orion 1934
RGB circuit trouble?? crt should be ok,get it checked anyway.May be adjustible in servicer menu.
Aug 22, 2007 | Orion1934 19" TV
Video wall color matching
WHAT KIND OF VIDEO WALL IS THIS,IS IT ORION
Jun 27, 2006 | Akira PK-8401 84 in. HD-Ready Plasma...
Akira PK-8401 84 in. HD-Ready Plasma Television Logo
371 people viewed this question
Top Akira Televison & Video Experts
Greg Bernett
Greg Bernett
ray gallant
ray gallant
Are you an Akira Televison and Video Expert? Answer questions, earn points and help others
