Question about LG Flatron L1952TX Monitor
Monitor Display for Flatron L1952T
The monitor has big images and fonts and looks like in safe mode, but it is not. Have set resolution to 1290 X 800. Still looks wonkie! Also seeing waves running through. Is there a driver we should download?
Any advise?
  • Anonymous Feb 10, 2009
    L1952T LG MONITOR JUST STOPPED WORKING , NO LITES NOTHING
  • 33 Answers
Hi
I think the problem is with your Graphic Card driver. You just need to install the correct driver and everything will be just fine.
I will be here if you need any further help.
Posted on Nov 02, 2008
Font to big
to use another type of font look into:
start -> settings -> control panel -> Fonts
other solution is to adjust your display to use another higher resolution:
right click on empty space on the screen and select property
a window title "display property" should pop out
select the tab "setting"
on the middle of the left side there is a bar for increasing / decreasing
the resolution
hope it helps
Mar 10, 2011 | LG 22" FLATRON LCD Monitor
How do I reset the monitor to correct font size
Hello Lawrie,
You don't actually adjust fonts or resolution on the monitor, you do adjust them in the control panel of the computer. To do this, open your start menu, select Control panel. When the control panel is open check the top left corner to see if it is in Classic or Category view, if it says Category, click the switch to classic mode link. If you don't see this in the top left look at the top right and look for Category or Large Icon View, if Category is selected select Large Icon by clicking on Category and then clicking Large Icon View in the list that appears.
Once in the proper view, click on Display and depending which version of windows you have select Settings on the top of the properties window(XP or older) or adjust resolution from the left column(Vista/7), now find the slider bar for resolution and slide it higher if you want the font smaller or lower if you want the fonts larger. This will set the number of pixels on the screen.
The default and best resolution for this monitor is 1280x1024, if that makes the fonts too small try 1024x768 next and 800x600 last. If the resolution is set too low to see the Ok and Apply button simply set the slider bar then press the enter button the first time, then you will be able to see the Ok and Apply if you need to continue adjusting.
Hope this helps Fixya,
Chris
Reply back with your version of windows if you require more specific instructions or pictures of any of the steps.
Jan 01, 2011 | LG Flatron L1750S 17" LCD Monitor
We understand that your problem is: Dell Inspiron 570 with monitor(?) issues. Start the computer, get to log in, the screen goes gray, then blue with wording and shuts down. In safe mode, many times it...
Your monitor does not support the resolution of 1900x1080. The ideal resolution for your monitor is 1024x768. To change the refresh rate(hz setting). Open display properties\If you are using Windows XP click on settings ->Advanced-> Click on monitor and click on the refresh rate drop down list and choose 60Hz
If you are using vista, Once the display properties window opens, click on the icon named "Display". Then click on Advanced settings-> Click monitor Tab(as shown in the images below)
Aug 27, 2010 | Dell Inspiron 1525 Laptop
I changed the screen resolution from 1024 768. while booting the monitor goes to power saver mode and displays "Out of Range 53.7KHZ to 60Hz. My OS is Win XP sp 3,
If the monitor is able to display the video after the computer boots, it may be something that you will have to live with.
But, you may be able to specify a different refresh rate based on the ability of your video card. Right click on the desktop, choose properties, then settings, and advanced button. On the new window, click on Adapter, then click on the Display All Modes button. The default for 1024x768 resolution is 60Hz, but your video card may offer another frequency which may be compatible with the monitor.
If you are unable to see anything after the computer boots, restart in safemode, then make the changes.
Is this an older monitor? 1024x768 is an industry default mode / setting. I am surprised that the monitor doesn't like it.
Jun 22, 2010 | LG Flatron L1515S 15" LCD Monitor
I have upto now been using my LG Flatron L1919S monitor as a tv with a separate tuner. today i replaced it with an LCD tv and was going to use the monitor for my computer. however when i connected it up...
It means your PC video output resolution is too high for the LG monitor to display (your old monitor (CRT) can handle higher resolution than this LG LCD monitor), you need to set the PC video resolution to native resolutionof this monitor which is 1280 x 1024 @60Hz. You may have to use the old monitor (CRT) to set the resolution to 1280 x 1024@60Hz, then hook up the LCD monitor.
Mar 27, 2010 | LG Flatron L1919S LCD Monitor
How can I make fonts look good in an LCD monitor ?
The VGA connection should be fine; I have DVI and when I switched from analog, the difference was pretty minimal, to my eyes.
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
If that doesn't work, I'm probably out of ideas, unless you have further information.
Mar 08, 2009 | LG Flatron L1750S 17" LCD Monitor
Analog- out of range
boot PC into safe mode, (pressing f8 on startup) then go to display settings and switch resolution to 640x480 (basic setting)
then reboot into normal mode, and then go to display settings and then choose an appropriate display resolution
this is caused when you replace a monitor as the old monitor ma have had different capabilities from the new
Feb 25, 2009 | LG Flatron L1951S-SN 19" LCD Flat Panel...
My new 22" monitor won't come on
restrat your computer then press continue F8 key untill u get menu
then go to enable vga mode or safe mode or last known god configuration. set your display resolution in display properties to 1024*768 pixel then try.
Oct 05, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Everything is big
Probably it's your resolution.... (or get a smaller monitor / joking)...
1.go to your control panel, and look for Display Options / properties. you should get a window that says 'display propierties'...
2.select the 'Settings' tab. and on the 'Resolution' section move the arrow to the right. the rule is: the highe the resolution the smaller the fonts.
3. your monitor should flick for a couple seconds, after that you should get smaller fonts. you must click on the OK button to confirm the changes.
Jun 28, 2008 | Acer Computers & Internet
Monitor not work
Try starting your computer in VGA mode (one of the options available from the menu you get if you keep tapping F8 as the computer starts up). In this mode the monitor should work well enough to get to the right resolution. Go to the display settings dialog (right click background and choose Properties, then the Settings tab), and pick the native resolution for your monitor (1280 x1024). Might be worth checking the refresh rate is ok as well before switching to the new resolution (press the Advanced button and the Monitor tab to check this).
Oct 28, 2006 | LG Flatron 995FT 19" CRT Monitor
Computers & Internet Logo
548 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
