Question about Sony KV-XJ29M50 29" TV
KV-XJ29M50 29" TV-Loud thumping sound on startup
I bought this Sony 29" TV Brand Nw about 2.5 years back and it has been working fine. Recently, it has started to give this thumping noise that comes from inside the cabinet and it comes whenever I turn it ON. Also, the picture sometimes becomes grainy and i thought it was some interference but now I have discovered that when picture becomes grainy, if i restart the TV it becomes clear again. This noise is really annoying and the technicians here in NZ thinks normal,though no one has physically inspected the unit, I have spoken to them on the fone. Please advise.
  • SAGAR CHOPRA Sep 23, 2006
    thanks jomaru, but why is is that it has suddenly started giving this problem and why don't other sets that i went and saw in stores give the same nows, is there a way to get rid of it. I have just found the manual and noticed this in the troubleshooting section - 'A boom sound is heard when the tv is turned on."
    Possible Cause - "The TV's demagnetizing function is working. This does not indicate a malfunction."
    Thanks
    Sergeant:
  • 337 Answers
Symptoms are not related,what you hear is the high voltage turning on and that is normal if it only does it for less than a second,the grainy picture might be intermitant,dont turn it off,when the picture is grainy tap the side of the set to see if it racts and if it does you know you have a loose conection.This could be outside because of a loose ground on tha cable or inside in the tuner.
Posted on Sep 23, 2006
  • Omar Urrutia
    Omar Urrutia Sep 24, 2006
    You are correct,the noise is noticeable more in Sony sets tha any other brand but is still consider normal,the description the manufacture gave you is their way to tell is not a problem.Is good it only happens when is turn on because is really no way to get rid of it.There is a way by disconecting the dimagnetizer but that will give you color problems and that is not good.
Sony trinitron kv-32fs10 component color problem
check the av in puts of your tv, this sounds that your av jack has a loose joint on the connection under.
May 24, 2010 | Sony KV-32FS10 32" TV
Sony KV-32S45 turns on at first, than blinks out, still sound
I would look for intermitent solder connections on the small horizonal driver transformer as well as other HV Componets.(HV Transformer etc.) Also solder up the Vetical output IC. These have been common causes of failures. I would not use the set until these have been checked and soldered. If you don't, a massive failure of the hoizonal circuit and powersupply will occur.
Hope this helps,
Skyassoc
Jun 18, 2009 | Sony KV-32S45 32" TV
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony KV-36FS120 No Pic/No Sound 4 blinks
You need to have the flyback on the main board replaced (a very comen problem)
This should fix ya!
Dec 12, 2008 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Moved tv from 1 location to another
hi there, it may need some fine tune for the sony kv-27fs12 to be connected directly to cable jack wall. do some test. ty
Jan 10, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
Sony KV-32FV15 TY
I have had my Sony KV-32FV15 for about 2 years now and nothing has ever gone wrong(even going through several moves.) I recently moved again and when I plugged in the TV, you can hear the sound perfectly but the screen just stays black. You can not even hear the squeal that the TV makes when comming on. Is there anything that I should initially look at to troubleshoot. I cannot afford at this time the $250 fee to repair my TV. I look forward to your input and hopefully I can get this TV working again.
Oct 24, 2007 | Sony KV-32FV15 32" TV
Re: Sony KV-24FS120
your problem in system control ic section related to stand by pin check ckt related to stand by section in remote ic check power to system ic loose coniact in remote or system ic thanks
Sep 09, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony KV-32S40 32" TV problem
intermittent problems can usuall be liked to bad solder connections. And sony typically has some that will develop after a few years in the power supply. so check for bad sodler connections throught the main board & give a close look to the power supply & check you work after to make sure you have no shorted pins. good luck.
Dec 27, 2006 | Sony KV-32S40 32" TV
Picture and sound go away after 2 minutes
Protection circuit fault kicks in. No vertical Deflection (V STOP),B+ over voltage protection (OVP), This is about a $150 -$200 to fix.
Nov 04, 2006 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KV-XJ29M50 29" TV Logo
200 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
