Question about Polycom Computers & Internet
Polycom IP501 and SPA2102 Router
In a SMB with four incoming lines, two operate off of the ATA side of the 2102 (never drops calls). The cable modem is plugged into the WAN side of the 2102. The Polycom phone into the LAN side (two lines aare assigned). A cable runs from phone to a wireless router. The phone regularly drops calls. Suggestions?
    Sergeant:
  • 306 Answers
If you know how eo access your configuration control panel then assign a Static IP address or place that assigned address on the other side of the firewall (DMZ). Steve Medley
Posted on Nov 07, 2008
I cant configure my ata phon adopter
Yes you can but you may need a SIP accoount along with SIP settings from your service provider.
May 03, 2012 | Linksys SPA-2102 NA Analog VoIP Adapter...
I am using SPA2012 with TG585v7 ADSL on PPPoE, i am not getting any incoming calls, my out going calls are ok. I have done port forwarding still no solution. When i run same SPA2102 on linksys ADSL it...
You may need to reset your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first.
May 10, 2011 | Linksys SPA-2102 NA Analog VoIP Adapter...
I have problem with my spa2102 such as when incoming call there is no ring on my analog phone other than that everything is fine. Thanks.
You may need to reset your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first. Good Luck
Apr 17, 2011 | Linksys SPA-2102 NA Analog VoIP Adapter...
Can a linksys router support voip and vpn?
It depends which model and which device because all devices differs in nature and the best way is to check each model`s manual or datasheet.
Jul 20, 2010 | Linksys SPA-2102 NA Analog VoIP Adapter...
Need to add Linksys WRT54G-TM wireless router with Linksys SPA 2102 phone adapter
your SPA2102-R seems to have one ethernet connection and one internet connection.
your WRT54G-TM seems to have one internet connection and 4 ethernet connections.
What you are trying to achive is; plug a ethernet cable into the ethernet connection on your SPA2102-R then plug the other end into the internet port of the WRT54G-TM
hope this helps, I have assumed that you intend to use a DSL broadband supplier not ADSL.
if you are changing service from DSL to ADSL then your WRT54G-TM needs to be first in line configured and working. then plug the internet port from the SPA2102-R into any of the WRT54G-TM ethernet ports.
Nov 06, 2008 | Linksys Wireless-G WRT54G Router
No more incoming calls
first i use voip card now i want to change ee-zee phone card how?
Sep 10, 2008 | Linksys SPA-2102 NA Analog VoIP Adapter...
Linksys SPA2102 conflicts with my Router
I have the same problem and I configure my router in PPPoe with my username and password provided by my ISP and now my router is working...
Sep 04, 2008 | Linksys SPA-2102 NA Analog VoIP Adapter...
Computers & Internet Logo
131 people viewed this question
Top Polycom Computers & Internet Experts
Michael Vincent Cruz
Joe Lane
Darren  Means
Darren Means
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
