Question about WYSE Winterm S30 Network Terminal
Wyse s30 dll error
We have a standard build for our Wyse s30 estate. After a device has been successfully in operation for a period of time. A user may try to launch the emulation program and is presented with a missing language.dll error. Any help, as Wyse aren't.
  • malt_vinegar May 11, 2010
    Is this a single terminal, or is it happening on many different terminals? What is the build of OS you are using, and the memory settings of the client in the control panel? When you say Wyse are not helping you, are you logging the problem correctly on the support site? I have logged calls on there, and they are pretty helpful!
SOURCE:
SOURCE: Hardware reset Wyse S30
hold down the g key on boot
Posted on Jun 13, 2007
Password should be Fireport, note the capital F.
Posted on Jul 06, 2007
Rubec
  • 42 Answers
SOURCE: Howto add a network printer on Wyse winterm S30 terminal?
The S30 terminal has the CE 5.0 operating system loaded as default. So you are limited by the operating system and not the hardware when it comes to network printing.
Here is a extract of the release notes for Windows CE 5.0:
"In Windows CE, TCP/IP supports network printing through the Server Message Block (SMB) protocol. It does not provide the Windows Line Printer Remote (LPR) Spooler. However, independent software vendors (ISVs) and original equipment manufacturers (OEMs) can add this support."
In short, you need a 3rd party software program or a (SMB) printer server setup to setup network printing on the S30 terminal..
Wyse also have add-on software to help, if you have CE 5.0 loaded then try the "Thinprint" add-on supplied as a free download by them.
Download Link:
http://www.wyse.com/supportdownload/3series/Addon_ThinPrint_B0010.exe
I haven't tried this, so let me know if it works.
Posted on May 07, 2008
SOURCE: Wyse PXE boot error
All Boot devices in BIOS may need to be set to "NONE". When shutting down, select "Shutdown and Restart the system, then hold the "Delete" key down while clicking the OK button. Keep holding the "Delete" key until system restarts in setup. Password that I was given is "Fireport". If that gets you access, then set all boot order configuration items to "NONE", then "Save Values and Exit". Hope it works for you as well as it did for me.
Posted on Dec 18, 2008
  • 38 Answers
SOURCE: WYSE S30 RESOLUTION SETTING TO HIGH
Buy a new monitor, or graphics card. If graphics are built into the motherboard, then the handbook for the motherboard tells you how to revert to factory setting.
Posted on Feb 11, 2009
Does the wyse sxo have a speaker
No, I do not believe the "S" series (S10, S30, S50 & S90) have any speakers.
Mar 01, 2013 | WYSE Winterm S30 Network Terminal
90 METER MIDDLEWARE, 3V cac, OMNI KEY 3121, wYSE S30 TERMINAL WINDOWS ce5... CAN'T READ CARD
It's not the middleware, it's the fact that 3v cards are not supported in wince.
Dec 15, 2010 | WYSE Winterm S30 Network Terminal
Wyse S30 power settings
You can check the settings in the bios (password will be "Fireport") I dont think there is anything in there that would trigger this.
Is there a screen-saver option in the control panel for the device? If so, see if it is set. If not, then try using the Wyse website to update the terminals OS to the latest. This will hopefully solve the problem. It might just be an incompatability with the older OS version.
Jun 22, 2009 | WYSE Winterm S30 Network Terminal
How can i reset S30 wyse box
Try a G-key reset.
Failing that use WSI and an S30 image from the wyse Website.
WDM also has the option to to re-image the client.
You may also be able to get into the control panel of the terminal, and download an FTP image and set the terminal to upgrade from the image when uploaded to your ftp site. From the control panel, you can initate the upgrade manually
Mar 24, 2009 | WYSE Winterm S30 Thin Client - Thin Client...
Try resetting with Control + g rather than just g
Turn on the Winterm and immediately hold control + g (at the same time)
The display should flicker for a bit then release the control + g
This will reset the device to factory defaults, (you'll lose your connection settings, network settings, etc) -- but you'll be able to use it again. :)
Feb 11, 2009 | WYSE Winterm S30 Network Terminal
Download Link:
May 02, 2008 | WYSE Winterm S30 Network Terminal
WYSE Winterm S30 Network Terminal Logo
91 people viewed this question
Top WYSE Computers & Internet Experts
Archie Ferrarini
Archie Ferrarini
Daniel
Daniel
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
