Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
H400 Heater won't ignite
All my connections look good, when i turn ignition switch on, heater does not light or come on, What should I check for? Do these heaters have a pilot light i need to relight?
  • 2 more comments
  • Jonfer44 Nov 28, 2008
    I have the same problem, I filled up the tank with gas but no go. Could it be that there is air in the pipe. How do I bleed the air out?
  • Brichardsont Jan 31, 2009
    I have the eletric igniter,  the gas comes on and the system lights then it shuts down, I git low and could see the flames through the little hole they have.
  • WadeRash Feb 16, 2009
    My H400IDL2 will not ignite. I have gas, the igniter is glowing red, pressure is OK, filter is clean, gas comes on and the unit will not ignite. After three tries the unit goes into safe mode with a code of IF. I have talked to the Hayward techs and have had two service companies check the unit I have also had the propane supplier come out and check the regulators . I am frustrated! The unit was placed in service on March 3, 2006.
  • uksoccer107 May 11, 2010
    What is the model number. All H-series Hayward heaters have a pilot except for the newer ones. Ones with a pilot will be called h200 h250 etc. up to 400 or so. Those have a pilot. The electronic ignition ones dont have a pilot and are called h200ED2 h250ED2 etc., or h200ED1, h250ED1, etc.
    Problem Solver:
  • 7 Answers
Especially if this is the first time the heater has been used in a while you may need to call a sevice tech. I just had a H400 that did exactly what yo described. I had to shut off the gas, pull the burner tray, remove all the soot and debris, remove the burners from the burner tray and soak in a 3 parts water one part muriatic acid solution for about 10-15 minutes, also check the gap on the pilot ignitor if the gap is too small or too wide you will not generate a spark, also check the orifices on the gas manifold mine were wull of spider webs. after reassembly the heater went on and has worked fine since
Posted on Jun 25, 2009
Replace igniter on h400
Open the main door, locate the 2 white fabric coated wires, they go down towards the base of the heater. This is your igniter, usually a 5/16 nut driver will be the tool you need to remove it.
Jul 04, 2014 | Hayward H-series Electronic Gas Pool...
Hi I have an H400 hayward. when heater is activated, it stays on for 5 seconds then shuts down eventually reading ignition failure code or IF on screen. the ignitor is new, the heat sensor is new, the gas...
When you say it stays on, Does the main burner actually light? If the burner never lights, then I'd look closely at the igniter, as it also acts as the flame sensor. Possibly you have a good enough ground to get a spark, but not good enough to sense the flame. If the main flame is starting, look and see if it is blowing off of the igniter. If this is the case, perhaps it isn't in the correct position, or there are still a few dirty passageways in the main burner. You can download a manual for your heater here:
Aug 10, 2010 | Hayward H400 High Wind Stack
Blower runs but no ignition then AO error code
Your problem then would be the pick up tubing and/or switch attached to the blower that closes once the blower is on to allow the heater to ignite. Pull the tubing and check it for dust or other debris clogging it and check inside the blower housing for the same. If you can test the switch under operation, you should see it remains open during start up which is why the burners won’t fire. If you do not find any obstruction (if you can, blow some compressed air thru too just to be sure) then you will need to replace the switch.
Jan 04, 2010 | Hayward H Series Pool & Spa Heater 400k...
Hayward H400 heater won't light and service light comes on. Also gives a code on screen "AO". I can't find in the owner's manual what that means. It is the electronic ignition model.
This is a code for what is called a prover switch. What it is a circut for the air pressures. Depending on model you can have one or two of these. Their will always be one for the exaust perssure and this will often be the culpret. If the sensor is good a sooted exchanger, rat nests on the exchanger or in the exaust can cause this. If you have a second switch it will be for burner air pressure and you will look for the same problems only inside the burner cabnet. Good luck, I'm sorry I can't be more help. But at least you know to look to the vent system.
Sep 27, 2009 | Hayward H-series Electronic Gas Pool...
Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Hauward H400 heater won't turn on
check pressure switch operation most heaters will not operate without sufficient water flow/pressure. You can use a multimeter to troubleshoot the wiring using the schematic. If its induced draft milivolt ignition verify there is suffiecient gas flow to the unit
May 25, 2009 | Hayward H - Series 400 Heater Top for In -...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
503 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
