Question about Akai PT4298HD Rear Projection Television
Blue Line Our TV is three years old. All of a sudden it has a fairly large blue line running vertically down the center. We have no idea what this is or how to go about fixing it. Is this a repairable problem? The only thing we know about projection tv is that we have heard bulbs got out. Does this problem sound like a bulb issue? Appreciate any and all information. Thanks.
  • gofastrack Oct 04, 2008
    I have the very same issue, except for me it is a red line. The line looks like a permanent magic marker line on the backside of my screen. There is also a small drop at the top of the screen above the line. The line is perfectly in the center from left to right. I have been told by others that it may be an "overlap" issue which can be adjusted. It was after replacing the convergence board that the problem came about. I have tried two new convergence boards and the problem still persists. Is this something that can be adjusted? Do I need to get a calibration DVD to help me through? Any ideas?
    President:
  • 3,130 Answers
Sorry no bulb issue here. theres a vertical sweep issue though. if your not a tech i wouls sugest that you find a good one as this is a solid state set and there are no user replaceable parts inside, so you cannot service yourselfs unless your trained to do so. please seek out a trained tech to assist you in this repair.
Posted on Sep 22, 2006
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
My Sony Bravia KDL 40WL 135 TV has been flashing strange colors for awhile; today screen is black with a thin blue line across the bottom. No sound. Any help appreciated.
The vertical output section circuit has the fault. Contact any experienced service technician. This is not a user repairable fault.
Aug 10, 2012 | Sony Televison & Video
Single Blue vertical line appeared on the sanyo 42'' LCD screen
vertical ic fult or vertical section supplys missing
Jun 12, 2009 | Sanyo Televison & Video
42inch LG plasma TV
well if you could please give out the model nuumber thank you
Sep 10, 2008 | LG RU-42PZ61 42 in. HD-Ready Plasma...
Blue shadows/ghosts
how old is the tv ??
if this tv is older than 5 years it may need to refill the liquid on the proyection bulbs and/or could have contaminats in the fluid causing the ghost and to fix that you will need a professional person to do it
Apr 03, 2008 | Toshiba TP55H60 55" Rear Projection...
I have a vertical blue line....left of center
If it is narrow you have a dead pixel problem. If so contact HP for advice. Three year warranty on screens and they usually swap out for failures. Very common problem.
Jan 23, 2008 | HP f1905 19" Flat Panel LCD Monitor
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
use menu and h/v then change then move to higher level and it will take it away.
Oct 09, 2007 | Vizio Gallevia GV42LF 42 in. LCD...
Blue Lines streaking in from left side of 70 inch Sony HD TV
okay my friend your tv vertical circuit is begining to get faulty you could be having some bad caps or the vertical ic is defected have a tech check your tv for repairs.if you are not a tech you cannot repair the set by your self.good luck.
Jun 25, 2007 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Vertical, pencil-thin blue line appears after 10 minutes of viewing (any source)
I would suspect a connection breaking down as the set heats up. A shop will probably have to put the set in a stand to hold it while they check for loose connections or defective components inside. Not a DIY job by any means. If this line went completely through the picture either vertically or horizontally and stayed there then this would have indicated a failure in the Panel itself. A thin Line any where on the screen consisting of one pixel in width is a Panel Failure according to Hitachi.
Jan 01, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Akai PT4298HD Rear Projection Television Logo
51 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
