Question about Dometic RM2652 Refrigerator
Fridge freezing everything
The fridge section freezes everything since we had the recall performed. How is the thermistat supposed to be clipped to the plastic slide adjustment? Wire came out of plastic holder and not sure how it hooks up.
  • 2 more comments
  • Anonymous Nov 12, 2008
    I just replaced with dinosaur board and the whole Dometic fridge acts as a freezer. I have turned the board down as far as it will go and turned the fridge setting to 1.
  • sandhill2349 Nov 20, 2008
    after about 48 hours the refer freezes on both ac and gas. when placed in an ice bath, 32 degrees, the thermistor reads 8.85k ohms. replaced the board with a new one and the same thing happens. where can I get a replacement thermistor even though it appears to be good?
  • harold_hammo Dec 20, 2008
    my frig is acting like a freezer
  • Quietriver03 Feb 01, 2009
    my refer is the 2652 model
    Habit-Forming:
  • 20 Answers
If your fridge is freezing to much put the thermistor closer to the fins (it will make it colder so it shuts off sooner)
Posted on Feb 02, 2009
  • RV REFER LLC Feb 02, 2009
    Here is a picture of how the factory has it looking up from below the fins
    Problem Solver:
  • 19 Answers
Check the mode not on manual
Posted on Nov 18, 2008
Why the heat exchanger between the freezer section and the fridge section freezes up around the second element closer to the door and makes ice on the roof of the fridge section.
If your freezer is icing up it is the defrost mechanism consisting of the timer, heating element, and defrost thermostat.
When you unplug unit everything melts and it runs fine for a few days till it freezes up again.
Usually it is the heating element that just burns out and has to be replaced.
Sep 14, 2015 | GE Refrigerators
Everything on top shelf of fridge freezes even on lowest temperature
you should send model number,if you have a damper control in your model most likely this is the problem,all that happens is cold air blows over from the freezer from the evaporator fan and blows through the top section of the fridge side,if the damper door isn't closing all the way it will cause freezing in the fridge section.
Nov 25, 2013 | Hotpoint Refrigerators
The freezer section of our Danby DFF8200W freezes well. However, periodically the refrigerator section freezes everything in it with the temp control turned as low as it will turn for me. The dial does not...
Make sure you clean the backside of refrigerator at bottom from dust. Make sure you have the recommended clearance from wall. Also make sure the food in freezer and frige have clearance to allow air to circulate around food. Keep playing with your controlls...The dails might be on wrong
Aug 11, 2013 | Danby Refrigerators
I have a whirlpool s20brsb21 and all to often everything freezes in the fridge compartment for no reason
Make sure that the fin tubes on the back are not loaded with dust, clean off and don't over load the freezer section. If there is no room for air flow the temperature will keep getting colder to compensate for low air circulation, thus freezing items in the lower section.
Feb 07, 2012 | Refrigerators
The fridge area or of my Maytag fridge is freezing everything in it. Just started to happen yesterday.
At the back of the refrigerator section, near the bottom behind the crispers, is a small opening that is an air return. There is a little plastic flapper that is supposed to close the hole off when the unit is not running. Check to be sure the little plastic flapper is not hung up or twisted and remaining open allowing cold air to flood the fresh food section.
Jan 13, 2011 | Maytag MSD2756G Side by Side Refrigerator
The bottom crisper in my refrige freezes my veggies
To repair this problem I dont think just toggling a lever is going to work. You need to locate what is suppose to sense the temp in the fridge section and how it stops the air flow to the fridge section. Basically most refrigerators cool in the freezer using the freon coils and transfer the cold to the fridge section using the fan in the freezer. Then your thermostat (temp sensor) stops the air flow by either turning off the fan or closing a small door going to the fridge section. This door is called the baffle and if you put your hand up to it and can still feel air coming thru when the temperature is 39 degrees or lower its not doing its job. With a model number I could help better but my guess is if its not freezing everything only the veggies your thermostat is off or the baffle is unable to close all the way and may have ice or debris in it. Either way I hope this helps.
Jan 24, 2010 | Refrigerators
Bottom of fridge section freezing, rest fine.
maybe fridge fan not working when door is closed could also be iced up air ducts between fridge and freezer
Oct 09, 2009 | Fisher Refrigerators
Food in fridge is freezing.
I need your model number, you may have a problem with your thermistat. Sears uses a different model number system than everyone. The model number will look like this 231.0564879 for example. Or yours may have electronic vents. Let me know, Thanks, Sea Breeze
You may need to contact me because Fixya has a problem letting me know if you respond.
appliancepartsse@yahoo.com
Jul 20, 2009 | Kenmore 53082 / 53084 Side by Side...
Dometic RM2652 Refrigerator Logo
926 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
