Question about Samsung Televison & Video
I have Samsung DLP TV 52",Model# HL-P5063W.I have it for four years .Few weeks ago started to make loud noise,the color changed to white and black .I ordered bran new color wheel and lamp. Following video instruction,I replaced the color wheel and the lamp step by step.It was very surprising that the old color wheel **** was completely smashed to small crystals.My work result was unsuccessful. The TV turned on but no picture, just black.No voice. I opened the back cover ,the two fans were working but the lamp was not on.No light from the lamp.I tried my two other lamp,again the same result.I think for some reason no power is coming to the lamp. Please help.
  • 1 more comment
  • keleshian Nov 02, 2008
    I thought about fuses. But I do not know which one? and where are the fuses been located? please provide fuses location with diagram or picture.Thanks
    would you provide me the diagram or the picture related to lamp's fuses .I would appreciated.
    I checked up again the lamp,color wheel,the wires and fuses;it seems to me every thing is fine.I turned the power on.The 3 signals on the TV power knob are blinking (Lamp,Timer,Standby/Temp).What is this to mean? Thank you for your assistance.
  • Samsung Master
  • 19,396 Answers
If the color wheel was smashed to pieces, than that may have had caused additional damage inside your TV.
If audio was intermittent that is either a broken cable/bad connector, or the sound card is faulty.
If pictures color was wrong and you had stains and lights that was probably the broken color wheel.
The lamp has probably nothing to do with all this and was probably fine. The lamp was fine for sure if you have some kind of picture coming out from the TV before. If you want you can put back the old lamp.
Posted on Nov 02, 2008
  • 2,071 Answers
Just cliick below for how they repair there DLP TV and a picture guide how to replaced the lamp,fan and color wheel ..
http://www.jangro.com/a/2006/08/15/samsung-dlp-frequent-questions/
how to change your Samsung DLP Lamp.
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Hope it may help you; Regards, VOTIT
    Genius:
  • 1,011 Answers
Dear Sir/madam,
Replacing the pico fuse will not fix this problem.if it is blown it is because the convergence circuit is bad and needs a repair. replacing the pico fuse without fixing the problem might damage your power supply.if you can solder good and use a meter? L
Thanks Good Luck
  • 728 Answers
Check the connection to the lamp to make sure it is giving power and picture to the lamp. You may have to re-solder the connection (if your good with electronics) or get it checked and fixed at a shop. You also might have a short that is giving it too much power that messed up the other lamp. If you take it to a shop, get that checked also to be sure.
Posted on Nov 01, 2008
    Master:
    Sergeant:
  • 449 Answers
Hi!!
try to ceheck the fuse!!
    Scholar:
  • 155 Answers
Please check on the main board from where the bulb is getting power that track might be faulty.
  • 1 more comment
  • fixexpert Nov 01, 2008
    the track must be getting cut some where.
    and also there is a allignment thing that the new bulb should be fit exactly how the company has fitted it orignally.
    wind the bulb little bit up side or down side and then check if it gets adjusted to the exact position it may work.
    thanks.
  • fixexpert Nov 02, 2008
    the fuse is located on the main power supply board of the tv.it looks like a mini tube light and made up of thin glass.and can be easily located on the main board and also will not be too costly if suppose to replace.
    you can get the fuses at
    www.radioshack.com
    thanks.
    http://fixyourdlp.com/blog/2007/02/12/sa...
    check out this link for doing it yourself with step by step directions and diagrams to locate the parts easily.
    feel free for further assistance.
    keep updated.
    thanks.
2 Suggested Answers
  • 10 Answers
SOURCE: samsung HL-P5063W DLP rear projection LCD red
Make sure that, obviously it's plugged in at both ends properly, but also that none of the pins are bent or broken.
Posted on Jul 23, 2009
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
TV started making a buzzing noise at start up which gradually got worse ovre time until it would not shut off unless unplugged.
This tv unit have a colors wheel design into it.This tv problems,having loud squeling,buzzing noises or colors pictures are flashes black&white with the pictures.The tv colors wheel it is worn out and it is dying.The tv have a loud buzzing noises because the tv colors wheel it is worn out and warping out of it axis and it is spinning and hitting it steal frame box.The tv colors wheel sit way back of the tv behind many mechanical parts.Have no experience in mechanical works like take things aparts and putting it back again.Hire a tv tech. to change the colors wheel.
May 03, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
Hi, I have a Samsung DLP Model HL-P6163W, approximately 5 years old. We replaced the lamp one year ago with no problems. In fact, we have had no other problems at all with the TV except recently. About...
Ur tv have a colors wheel design in it.Tv have buzzing,squiling or loud motor noises.Have colors turn in Black&White or flashes white within pictures.All these causes and problems are the effect of the colors wheel is dying and require repacement of the colors wheel,because it is woring out and not spinning correctly on it motor axis anymore.Have no machanical experience taking things aparts and putting it back together again.Don't atempt to change the colors wheel by ur self,bacuse the colors wheel sit way back on the tv,must take out many machanicals parts before u can even come to it to change it.Hire a Tv Tech. to change the colors wheel ok best solutions and no complication taking out the old one and putting in the new colors wheel,for it to functions correctly.
Jan 07, 2011 | Samsung HL-P6163W 61" TV
Picture is black and white
Does it sound like thin grinding noise?
The color wheel is very common problem. Color wheel for this model is about $100 to $150 plus labor.
Nour BMI
Feb 18, 2010 | Samsung HC-P4752W 47" Rear Projection...
Sansung DLP HL-P4674W Is making this loud humming noise and the oicture is now in black and white
sounds like a the color wheel blown. Call a local tv repair shop. Some Samsung models carry two different color wheels for same model depending on chassis version which can be seen only when the back is removed.
Dec 08, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HL-P5063W makes a whining sound and then goes off
The most common failure in the DLP that makes a whining sound would be the color wheel. They cost about $135 + labor because I wouldn't advise changing it by yourself.
Aug 02, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung dlp model hlp5067wx
the color wheel has to be replaced. (Technican Job) this device is inside the light engine,
Jan 06, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HL-R6167W DLP color problem/buzzing noise
My 3 yr old Samsung DLP has the same buzzing noise, had a tech out today and he said "color wheel". Thank goodness I purchased that expensive warranty, This is my 4th repair in 3 years.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
75 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
