Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Poor cleaning with Hotpoint NDA300Y 73BA dishwasher
Dishwasher does not clean like it used to. Many things come out with specs of food stuck to them. The dishes are quickly rinced before putting in dishwasher which used to clean but no longer does anywhere as well as it used to. Is there a recirculation water pump that has a filter that would plug? or does this sound like a warn impeller? Something else?
    Genius:
  • 1,028 Answers
Be sure rinse aid dispenser is full ..also ck water level after fill should be almost to bottom of float
Posted on Nov 02, 2008
Dirty glasses dishwasher
1st thing is make sure the dishwasher is heating up the water.
if it is heating... you spray arms may be blocked up with food particals.
Mar 21, 2014 | Hotpoint Dishwashers
Poor cleaning, food residue
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Oct 07, 2010 | Maytag MDB7100AWB Dishwasher
GE GSD500X-73BA great for 12 years; 2 weeks ago starts leaving film on all items; things don't seem clean; glasses foggy. Pumps in and out fine; water seems plenty hot; no air vent that I can see. What's...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 05, 2010 | GE 24 in. GSD500X Built-in Dishwasher
Dishwasher no longer clean dishes as well as it use to
Hello there
There are several reasons why a dishwasher will start performing poorly and dishes are not getting cleaned here is a list of things to check
It cleans poorly If your dishwasher is cleaning poorly, check these: things that i have listed below by clicking on each one and it will give a description ok? Water-inlet valve Internal filters Drain valve Spray arms Water temperature Detergent cup
I
Apr 02, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher water draining????
Make sure the odor is coming from the dishwasher.
Pull the bottom basket out and check for food that might be stuck in it. And check for food particles in the bottom of the dishwasher.
Then pour some baking soda into the dish liquid compatment. Run it through a complete cycle. This should deodorize and clean the dishwasher. i hope it helps. Please remember to leave rating.
Jul 19, 2009 | GE 24 in. GLD5860LSS Stainless Still...
Where to clean the food out
A dishwasher cleaner may help. It usually is for lime deposits but it still may break the stuff down enough to flush it out. Wal-Mart or an appliance store should have it.
Jul 01, 2009 | Whirlpool 24 in. DU920PW Built-In...
Premature drain on Hotpoint HDA 3400 dishwasher
hello my name is gilles the problem you have their is something stuck in your drain valve causing the valve to stay open remove the valve clean out reintall every thing should be fine thanks
Mar 15, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Hotpoint Aquarius DF61 Dishwasher & Food residue remaining
i have cleaned the filter on my hotpoint aquarius DF61 on cant put it back together.
Nov 17, 2008 | Dishwashers
Hotpoint DWT10 Dishwasher error codes/lights
food stuck in drain pump remove and clean out or scoop out - soak up all water then fill with 3 or 4 hot litres of water . cancel programme , start new one ( first thing unit does is switch to drain cycle ).
Then rock machine back and forth - this sometimes frees jammed debris thus pumping out of machine.
This works for me i have done it several times and it works
Jan 26, 2008 | Dishwashers
Dishwasher kenmore 16789
It sounds like your wash pump impeller might be clogged. The first symptom of this problem is poor cleaning capabilities and food left on dishes. You will need to remove the spray arm assembly to access the reservoir below the spray arm. More than likely, you will find debris clogging the the wash pump impeller area. As a general rule of thumb, you should not put anything into dishwasher that still has to be chewed. You don't have to prewash your dishes, just scrape them real well. Most detergents still need to oils and residue from food to activate the cleaning agents. If you prewash, you simply defeat this purpose. Some things that should NOT go into a dishwasher are lemon seeds, orange seeds, pistachio seeds, popcorn kernels, chunks of meat, bacon, tooth picks, chicken bones, match sticks, bottle cap liners, jar labels, etc. These are a small example of SOME of the things I have personally found in the wash pump. It doesn't take much to clog the pump, and the chopper assembly is not to be considered a disposal. I hope this helps you. Let me know if you need any further assistance.
Jul 25, 2007 | Kenmore 16879 Built-in Dishwasher
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
94 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
