Question about Kenmore 17382 / 17384 / 17389 Built-in Dishwasher
Knife Holder and tine adjuster fall off
When you push in the lower basket the knife holder and tine adjuster are knocked off by a plumbing fitting on the left wall.
  • Anonymous Mar 20, 2009
    I have the same problem
This problem would be so easy for Kenmore to correct by simply redesigning and replacing these knife holders....but Until such time as Kenmore responsibly reacts, I recommend remounting the holder to the side of the basket at a better angle using your knife with the longest handle as a guide) usng plastic ties such as used as handcuffs and cable ties. (Not pretty, but effective).
Posted on Jul 15, 2009
How to install a new "upper knife"
First make sure the lower knife edge is the same height as the needle plate.
Then
- Insert the new upper knife into it's holder, tighten the screw slightly
- Turn the hand-wheel until the upper knife is at it's lowest position.
- Move the knife up or down in it's holder so that the cutting edge passes by the lower knife by around an 8th of an inch.
- Tighten the upper knife locking screw well.
May 03, 2014 | Singer 14SH654
How to change blade on lenox gold utility knife. I've looked all over and cannot find instructions on product home page or anywhere online. HELLLLLLP! Thank you, Barbara
Open the knife to the middle position (don't open it fully) and push the small button on the blade holder. The blade will pull out easily..
Aug 05, 2011 | Garden
Can't figure out where the screws are on the control panel and how to get it off the lid
You can raise the washer top using a flat knife type of tool to move springs thru the gap between the washer top & the lower front piece. Pull upward on the top and peer into the small gap. At each side you should see the springy top holder. Just push on it with the knife or flat putty knife
Jun 26, 2011 | Kenmore 24032\24036 Top Load Washer
How to remove the rack holder from a GE JMV1340WW002 microwave.
Hi best way is to remove the outer case and cut the back of the clip off, alternativly you can just lift the old clip from inside the oven cooking cavity with a flat knife or spreader untill the plastic clip on the rearside breaks off, it'l just fall down and sit in a void in the bottom of the oven and wont cause any damage. The new clip is just installed using an upward motion whilst pushing inward untill it clicks into place.
Hope this helps
Jan 07, 2010 | Microwave Ovens
Stanley 10-777 utility knife: I need to reinsert the retractable blade slide back into the knife body. I try but the knife won't close.
I had the same trouble. The blade holder was out of the knife and would not go back in. I fixed it this way: open the screw knob all the way to the least tension. Slide the two parts open but not all the way- there is a tab on the blade holder that gets in the way if you try to drop it in at the fully open position. With the two halves SLIGHTLY open- slide the blade holder in making sure that the tab is seated in it's slot. Depress the thumb tab and bring it to the most forward position and the two halves should be able to be seated together again.
Oct 27, 2009 | Stanley Hand Tools
Thickness planer
I was able to make a knife setting jig for the Delta planer using magnets and measuring the old knife setting height abouve the knife holder before I removed the knives.
Mar 23, 2009 | Delta Tools & Hardware - Others
No running manual 4 summasign pro D610 vynal cutter
You can get assistance and possibly a manual for your Vinyl Cutter from a Summagraphics Repair facility such as
ADVANCED GRAPHICS
1027 N. MAIN STREET
TEL: 210-227-9393
SAN ANTONIO, TX 78212
I hope this helps. Toni Gallucci, Glass Act
Mar 17, 2009 | Computers & Internet
Cutting knife adjustment
I have found this info...it mentions both threading and changing the knife width. I hope it is useful.
http://www.singerco.com/pdf/14SH654_threading.pdf
Mar 17, 2008 | Singer 14SH654
Upper Knife
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Euro-Pro 534DX Mechanical Sewing Machine
Open Questions:
See all Kenmore 17382 / 17384 / 17389 Built-in Dishwasher Questions
Kenmore 17382 / 17384 / 17389 Built-in Dishwasher Logo
126 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
