Question about Kicker DX350 Car Audio Amplifier
Kicker DX350 I have this amp and the power light lights up and no sound comes out. I was rewiring my sounds and the speaker wire fell out and the amp went to protection. I touched the speaker wire to the amp and no sound comes out I removed the crossover mod and pushed it back in and my speakers give one loud bump and then no sound comes out again. do I need a new crossover mod??? my amp lights up and no sound I have double checked all my wires and my amp is powered grounded and all the fuses are good pls help robert
  • Anonymous Mar 22, 2014
    amp speaker wires touched, the green light is on, but no sound
    Problem Solver:
  • 15 Answers
It sounds like you pop the power Reg. transistor or one of the Amp. chips instide. Some Amps has a pic fuse inside on the main board its green very small shape like a tear drop with a wire comeing out both ends it would in a socket some times white or black.
Posted on Sep 22, 2006
I hooked up a dual radio to my 1987 dodge ram the radio comes on but no sound and the dash lights went out
Sounds like you have the stereo ground wired into the wire that dims the light on the factory stereo when the headlights turn on. Rewire stereo with proper ground, check all other wiring to insure it's done properly,replace blown fuses for lights & stereo. Should be good to go.
Nov 05, 2012 | Cars & Trucks
I have a pioneer gm-354 amp and the power indicater light on the front has changed from solid to flashing and no sound from the amp to the subwoofer it used to power any idea's
If it is flashing it went into the protect mode.Check that a speaker wire hasn,t come off, Or that the ground cable conection is good end all other hook up wires to it.
Oct 27, 2012 | Pioneer GM-X354 Car Audio Amplifier
My mrp m650 alpine amp power light is on but no sound. it works if i hook it to other vehicles but not in mine.
Check your speakers and speaker wires to make sure you have no shorts or grounds. Not knowing what vehicle you are putting the amp in, there is also a possibility that there may be a stock amp in the vehicle. If this is the case, you may have to rewire the speakers and bypass the stock amp.
Feb 27, 2012 | Alpine MRP-M650 Car Audio Amplifier
My daughter has a 90 Thunderbird that had an original premium sound package. The stereo went kaput and she bought an after market replacement. I went to install it for her and unfortunately opened up a...
These cars have a factory amp system that will not operate correctly with an aftermarket stereo. You have two choices. You can either run new wires to the speakers your self which would bypass the factory amp. Or you can order the premium sound system Interface here http://www.myinstallkit.com/FORD/1990%20(90)%20FORD%20THUNDERBIRD%20Radio%20-%20Stereo%20Installation%20Kit.htm scroll about half way down the page.
Jan 25, 2011 | 1990 Ford Thunderbird
I want to turn the sound off on my peg perego train (thomas) it scares my child. Can I rewire?
yes you should be able to just clip the speaker wires and it will still work but if you want to be on the safer side just hook up a LED (light emiting diode) from the wires the speakers went to. LEDs are everywhere you can just go to your local electtronic store. i hope this has helped you if you have more questions about it fell free to e-mail me cstmundrgrndart@yahoo.com
SabiousOne
Nov 08, 2010 | Peg Perego IGED1084 Santa Fe Train
My 2006 12" L7 kicker sub isn't working like it should. It simply sounds like an extra speaker and produces minimal bass. All the wires are correct, I have checked and rewired it several times just to make...
On the amp there should be High pass and a low pass setting. Put it on low pass cause if its on high pass or in between it produces normal noted like a speaker. Low pass will filter out all the high frequencies.
Jun 10, 2010 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
I've got 2 blaupunkt amps pushing 2 10" kicker cvr. the only problem im having is that when i start my truck the "protect" lights comes on for about 2 min then it switchs to the "power" light, it that just...
The wiring could be wrong, it sounds like you have taken the live feed from ignition, the main feed should be direct from the battery with an inline fuse as close to the + terminal as you can, the earth lead should be as short as you can from the amp to the chassis, and the remote lead comes from the head unit.
Feb 06, 2010 | Kicker Solo-Baric L7 10'' Car Speaker
Kicker zx 1000.1 green light flickers and no sound
The first thing I would suggest is to check all connections to the amp and speakers, especially the ground. A loose ground can cause the problem listed. You can test this by temporarly running a ground from the amp to the battery neg. . If the amp fires up ok then that means your grounding point for the amp should be checked and cleaned and reattached firmly. If you have a meter(multitester) set it to ohms and check the impedances of the voice coils in the woofers. If one is cooked it may be shorted and tripping the amps protection. Always hook thing up with the sys off and then turn on and test.
Jul 21, 2009 | Kicker ZX10001 Car Audio Amplifier
Kicker DX350 Car Audio Amplifier Logo
282 people viewed this question
Top Kicker Car Audio & Video Experts
Morne Olivier
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
