Question about ASUS Eee 4G Notebook
Keyboard problem - asus
I have asus notebook, I attached USB keyboard to use separately, when i remove this USB keayboard, some of the functions of my asus keyboard changes, like like letter U become 4, or letter P becomes -, how can i fix this
thanks
  • ronan1972 Nov 02, 2008
    thanks for your response but unfortunately it does not work, From system i went to harware then divice manager (beacause , i uninstalled the 2 itiems in keyboard but when i restarted the pc, the problem persist, the second solution you suggested, no keyboard installer seen in the whole package given to me.
    sorry to bother you, thanks
  • cybrsrch1 Mar 17, 2009
    as described by others I had the same problem when using a usb keyboard, when I unplugged it to go mobile my keys were mesed up, but using the #2 solution, Fn numberlock fixed it. Thanks... great website. :)
It seems to me that you have the NumLk activated, deactivate it by pressing Fn + NumLk, hope this works!
Posted on Dec 09, 2008
  • 33 Answers
Hi
This means th news keyboard driver has some effect on your laptop keboard.
try to go to the Panel Control and then System, then Hardware
uninstall your keybord driver & restrt your pc, then it will tell you you have a new device (keyboard) & then will automatically install the suitable driver.
try your latters again, if the problem still going on, try to get the keboard driver cd you got with the laptop when you first bought it.
I hope things go fine with you trying this. If not, let me know more about that plz.
Posted on Nov 01, 2008
  • Reda El AZGHARI
    Reda El AZGHARI Nov 03, 2008
    Hi again!
    well, look, the Computer can remember only one keybord, so when you plugged the USB keyboard the first time it could have probably replaced the old one, and yet even two keyboards are on together they function as one unit. Try clicking on the Caps Lock button, you see the green led on both keyborads at the same time.
    If you can provide me with your asus laptop version, I would be more helpful.
Thanks again for your reply,
When i try to go on safemode, may laptop keyboard is working perfectly but unfortunately when i goes back to normal mode, the problem goes back.
Its notebook ASUS S5N,
Posted on Nov 04, 2008
How to troubleshoot keys that are not responding?
if only the multimedia keys are not working try to find drivers for your keyboard.
1- try to clean your keyboard with a toothbrush.
2- try to remove your keyboard connector and then connect it again, it could be connection problem.
3- Get a new keayboard.
Apr 28, 2014 | Sony VAIO Y Series Notebook VPCY118GXBI
The keyboard of my MSI S260 PC NOTEBOOK is not functioning even if the touch pad..how will i repair it?
I have also MSI s270 laptop and its the successor of your laptop with the same parts, i open my laptop many time already changing its memory and cleaning its parts:
heres you need to do:
1. unscrew your latop at the bottom.
2. Remove the battery.
3. remove the plastic covering, the one where the power button is attached.
4. after removing it, you can now unscrew and remove the keyboard, try to clean its carbon head with an eraser.
5. remove also the plastic where the touchpad is attached. clean also its carbon head.
6. return it all back.
Alternatives:
Use external keyboard and mouse (USB).
Mar 30, 2011 | MSI S260 (S260100) PC Notebook
Water on the keyboard of my asus notebook eee PC4G- some keys not working. what can i do?
You could remove keyborad from notebook and use a humidity extractor but maybe the electrical contact keys got oxidized, if this is the case the whole keyboard should be replaced, a cheaper solution should be to get an external usb mini keyboard.
Feb 18, 2011 | ASUS Eee PC 900 PC Notebook
Problem: remove keyboard ASUS K72JK-TY043V.Thanks
The Asus K72JK-TY043V Notebook PC is one of the Asus K series of Notebook PC's.
This shows how to remove the Keyboard,
http://www.insidemylaptop.com/disassemble-asus-k-series-notebook/
Shown is a disassembly guide, and of course you do not need that.
What I am referencing to is midway down the page under the bold heading >
Removing Keyboard.
The Keyboard is held in, by plastic tabs that are on the Palm Rest Cover.
These tabs are spring loaded. You press against each spring loaded tab, and depress it.
This action unlocks the Keyboard from the spring loaded tab.
There are Five spring loaded tabs.
The spring loaded tabs are located above the following keys;
1) Esc key
2) F5 key
3) F9 key
4) Prt Scr
5) End
Use a small flat bladed screwdriver such as a Jewelers flat tipped screwdriver.
Carefully press the tab TOWARDS to LCD screen.
Once a tab is depressed it unlocks. Go to the next tab.
The back of the Keyboard is towards the LCD screen.
Lift up on the back of the Keyboard.
DO NOT try to remove it at this time, as there is a flat cable attached to the Keyboard.
The Keyboard cable is an FFC.
Flat Flex Cable.
The Keyboard FFC does NOT have a connector attached to it.
The connector is permanently mounted to the motherboard.
The Keyboard's FFC removes from the connector on the motherboard. Just a flat cable hanging from the Keyboard.
The connector on the motherboard is a ZIF connector.
Zero Insertion Force.
This particular ZIF connector has a Lock Clip on it, that is slid slightly to one side.
As you view the flat flex cable coming into the connector, and above the connector, the clip is slid to the Left to unlock.
NOT very far. Approximately 2 Millimeters, or close to 1/16th of an inch.
Have questions please post in a Comment.
Regards,
joecoolvette
Dec 18, 2010 | ASUS K50IJ-C1 Notebook
Need to replace broken key on keybord. plastic appartus on key underside broke
Remove sticky tape securing the keyboard cable to back of the keyboard.Part of the keyboard cable is glued to the keyboard. Carefully separate the cable from the keyboard.Start peeling off the aluminum protective film Remove the protective film. After the protective film is removed it's really hard to attach it back to the keyboard because it's deformed.Most laptop keyboards have some kind of plastic separators.
These separators secured on the back of the keyboard.
Plastic pins are melted on the back of the keyboard and retain separators in place.Push all plastic pins though wholes on the keyboard.Start removing the separator.The plastic separator has been removed.
Now you'll have to remove all key caps.
Before you start removing key caps, make a picture or xerocopy of the keyboard so you know the order in which keys are attached to the keyboard.In order to remove the key cap carefully lift it up with your fingers.Remove the key cap so the hinge underneath stays connected to the keyboard.
Some big keys have a different design.
In addition to the hinge, some big keys (Back space or Space bar for example) might have an additional support bracket.Remove the key cap with the support bracket. As you see, the key hinge stays connected to the keyboard.Some laptop keyboards might have blank covers on the left and right sides from the up arrow key.Lift up and remove the blank cover.All keyboard key caps and plastic separators have been removed.Now you can start removing key hinges - key lifting mechanisms.Carefully separate the key hinge from the keyboard.
Each key hinge has two parts - external and internal pieces.
When you remove the hinge, try to keep these parts connected to each other the same way they are connected on the keyboard.If the external and internal pieces got separated, you can assemble them together.If you following this guide to repair the keyboard, I would recommend to keep all hinges in the right order.
The keyboard has two sheets laying one on the top of another.
Remove the sheet with silicone (or rubber) nipples.Remove the second sheet with traces.Both sheets have been separated from the keyboard base.The sheet with traces has two layers and all traces are running between these layers.In order to access and repair traces you'll have to separate to layers from each other.The keyboard has been disassemble.
As you see it's not easy to disassemble a laptop keyboard and even harder to put it back together.
Is it worth repairing? Probably not. These days you can find a new laptop keyboard very cheap.
Oct 17, 2010 | HP Pavilion ZD7140US Notebook
Half of my keys arent working, some of these keys are w, t, e, a, s, p, r, i think there are a few more
try to use a USB external keyboard. if it works fine this proves that your problem is on your keyboard. If so try cleaning up your keyboard if u can remove it from your laptop but i suggest let experts do it. And if your notebook still has a warranty left you can always use that..
Feb 08, 2010 | ASUS Eee PC 1000H Laptop
I spoiled wine on the keyboard of acer 7520. How to remove the keayboard to clean up the sticking buttons. thanks !
You can remove the keyboard keys by dismantling your laptop totally. You need some of tools for it to do the task. I suggest you take your laptop to a service center to avoid damage of your laptop.
Dec 23, 2009 | Acer 91.63X07.001 Keyboard
ASUS 901XP. Keyboard. Right arrow does not function correctly
Perhaps you can check your manual. Many notebook keys do not function as expected. If you do not have the manual, you may download one here:
http://www.asus.com/product.aspx?P_ID=1sRO7tW9B0OdR9yz
Nov 27, 2009 | ASUS Eee PC 901 XP Notebook
Trouble seperating top cover from base/mobo / asus f3s notebook
Have you removed the keyboard, sometimes there is a screw under the keyboard that holds the top and bottom of the case together.
Most laptops have clips/indents that clips top and bottom half of the case together. Start on one side, preferrably at an opening where the CD/DVD drive is located and gently apply pressure to separate the case along that edge. Once you free a catch/clip start working along that edge and continuing around to each side of the case.
Mar 26, 2009 | ASUS F3SC-B1 Notebook
ASUS Eee 4G Notebook Logo
929 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
