Question about Sanyo PLC-SW30 Multimedia Projector
My projector turns on then off
When i turn on my projector the green light comes on for a few secs the turns off and starts the fan up like its cooling it down
    President:
  • 1,073 Answers
Probably your projector filter is full of dust, and probably even the inside id full of dust. You need to clean the filter and you need to clean the inside. The fan starts coz the lemp inside cant get any air, as soon as you turn the projector on it gets overheated.
Go to a pro and let him/her clean your projector good, then it should work properly again. And make sure that you clean the filter at least 3-4 times per year.
Good luck
Posted on Dec 02, 2008
The projector turns on but won't project any light through the lens.
If this is a NEC VT series projector, Change the lamp. When if it continues to blink amber and not project and image after installing a new lamp check the lamp cover to see if the micro switch tab on the lamp cover broke off. Some models have a built in lens cover. If the cover is not slid over to open completely the light may not turn on.
May 19, 2014 | NEC VT800 LCD Projector
When the projector is turned on, the green light
Sir it seems air in out problem.Clean all air filter or open lamp cover and give air pressure using with air blower or vacuum cleaner
Feb 25, 2010 | Sony Cineza VPL HS2 Multimedia Projector
Panasonic PT-LB10SVU green light flashing,then orange,lamp light
i just replace the lamp, and don't have any light coming from lens,starting green (after a few seconds,green become to flash2_bing.gif), then turning on orange and lamp light flashing...please i need help, fan working perfect...i don't have a remote,is a problem, or not
Feb 25, 2009 | Panasonic PT-LB10SVU Multimedia Projector
I turn on the 4805,green led blinks & bulb does not come on?
After a few minuets does the green blinking light turn to a red blinking light?
If so the problem is the lamp did not strike.Either the lamp has failed (most likely) or there is a problem with the power supply (less likely)
Feb 12, 2009 | InFocus ScreenPlay 4805 Multimedia...
Panasonic pt ae900 wont fire up
First , start over and unplug it. Wait a few minutes. Turn on AV system that is connected to it but not video or dvd player. With remote, point at is corectly and push power 1 sec or as soon as you see green light come on. Be quick.
If this fails you can wait 4 hours and repeat. OR try only projector with out any feed.
Let me know if this worked.
Dec 14, 2008 | Panasonic PT-AE900U Multimedia Projector
Projector problem
I generally fix this by re-seating the bulb housing. Take it out and put it back in. Look for cracking at the base of the bulb on the mirrored surface. It could be a barely functioning bulb that isn't busted, but can't initialize. I would take it to a shop that has the same bub type in a housing and make a quick switch.
Jun 20, 2008 | InFocus ScreenPlay 4805 Multimedia...
Its not the lc-sb20 but the lc-nb3e
Hi there
This sounds like a common Ballast ( lamp's power supply ) problem.
Only way to rectify this is by replacing the faulty Ballast.
Sep 08, 2007 | Eiki LC-SB20 Projector Multimedia...
PLV-Z1 no longer powering up - Ready light is green and the Lamp light is red
I have a Sanyo XU35. Mine was starting up and showed a picture for about 15 - 30 seconds then shutting down. My lamp warning light was not coming on. When I put it in for repairs it turned out to be the lamp that needed replacing. The technician said it is not uncomman for the lamp to be gone and the lamp warning light not to come on. I got my lamp on e-bay from ping_ngo for a great price.
Aug 11, 2007 | Sanyo PLV Z1 Multimedia Projector
Sanyo PLC-SW30 Multimedia Projector Logo
523 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
