Question about ASUS P4S800D-X Motherboard
How can I setup sata drivers using cd or dvd
I am puting up my old motherbooard with fresh HDD but when I load the installatio cd for Windows it doesnt work. Then I check the internet about and found out it needs a driver for SATA, but I do not have floppy disk drive in my laptop. How can I load the drivers using a cd?
GET THE RAID DRIVERS FROM ASUS SITE,,THEN MAKE A FLOPPY DISK FROM IT USING IT MAKE A DDD USING A MAKE DISK PROGRAMME.THEN START INSTALLING WIN XP WITH A BOOTABLE XP CD AND PRESS F6 TO INSTALL RAID DRIVERS.AFTER THAT DO ACCORDING TO THE MENU..THEN U WILL SE THE SATA HARD DRIVE AND INSATLL XP
ASITHA WANIGARATNE
SRI LANKA
Posted on Dec 13, 2008
    Scholar:
  • 124 Answers
Hi, I think the problem lies with your bios setting. Set the POST to first boot from the CD/DVD drive. If it is set to first boot from the CD/DVD drive, then the problem comes from the disk. It might not be a bootable disk. If you have any questions, please feel free to contact me. Thanks, Mike H
Posted on Nov 02, 2008
While trying to format my notebook and installing a fresh copy of windows vista i am encountering this error: I cant see my storage drives. Why this is happening? Thank you in advance.
More than likely you will need sata drivers for the hdd from the manufacturers website. Load them on a USB stick and during setup, it will ask you if you need to load additional drivers, then have it load up the drivers for the sata hdd off of your usb stick.
Best of luck
Kevin
Nov 10, 2010 | Computers & Internet
DVD burner will not recognize blank DVD's now since I installed a new HD and Windows. I have removed the windows drivers multiple times and I am getting nowhere. I have never run into this before. Does...
Did you try using Nero or Roxio? Don't only rely on the standard Windows support for CD/DVD writing.
Did you connect the new hdd the same way as the old hdd, or did you add it to the same cable as the CD/DVD writer perhaps? If multiple IDE devices are on the same cable, the master slave setting can cause problems. If you are using SATA devices, that should not be a problem.
Drivers are not required for IDE devices, including most CD/DVD writers, so don't bother with that.
Nov 11, 2009 | LG GSA-H22N DVD±RW Dual Layer Burner
HDD not recognized whe installing fresh Windows XP!
Hi...
If your HDD will not recognized during installation you need to check if your HDD is detected. Try to look at your BIOS if it is detected. IF the HDD will not detected you need to replace the cable, try to use the other slot of your SATA or IDE ports.
Regards
ICmanServer
Jul 31, 2009 | Dell Vostro 1400 Intel Core 2 Duo T5270...
SAMSUNG SATA DVDRW on MSI K8MM-V MB
try going into setup; choose boot options and place your HDD in first boot position. Also you may have to designate your new DVDRW as a slave if you have another CD/DVD in the system
Apr 16, 2009 | Computers & Internet
Failing install of PCI SATA Drive
You need to load the SATA Controller driver for the XP install to access the HDD.
The driver will need to be downloaded and extracted to a floppy diskette, then loaded during the XP install.
If your system doesn't have a floppy drive, you'll either need a USB floppy drive or create a slipstreamed XP CD with the driver added to the CD.
Aug 12, 2008 | Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop
Xp professional installation on hp pavilion dv6700 cto notebook
The original Windows XP Installation CD, a freeware application named NLite and a blank CD.
we need the drivers for the SATA controller provided by the manufacturer.
When you start the Nlite application, you will be asked to provide the location for the Windows installation package. Insert the genuine Windows Installation CD into the CD drive and, inside the application, select the CD drive letter.
To insert the SATA drivers within the installation package, you need to have it saved on the HDD. Hence, when the warning window appears click OK and select the destination folder for the files to be saved. Make sure that the destination partition / HDD has enough space to store the contents of the installation CD.
Immediately after you have chosen the destination folder, the application will start copying the Windows installation files. When finished, it will display some version information regarding the newly copied Windows Installation Package.
Now, click next twice until you get to a screen where you get options sorted in 4 categories: Integrate, Remove, Setup, Create. We are interested in the integration procedure, therefore select the Drivers button and click next. From the next menu window, click Import and select multiple drive folder option from the drop down menu. This option permits you to browse to the location where the downloaded drivers are found.
Select the containing directory and click next. You will get a list with the available drivers (in case there are more than one) or simply one driver. Select it (them) and click next. Now the application will ask for the permission to start the integration procedure. Choose Yes and wait for the drivers to be inserted into the installation package.
With problematic driver being included in the installation package you can install Windows XP on your SATA HDD...but...the installation package is on the HDD. You need a bootable CD in order to start an installation. Don't worry, once the installation package has been adorned with additional user selected drivers it can be transformed into a bootable disk image and later burned on a CD. To encapsulate the installation into a ISO image use the same Nlite application.
Open it, make sure the HDD installation folder is selected and click next. Select "Last session" preset and click next again. Now from the options menu choose Bootable ISO and click next. In the following window, make sure that the mode is set to "Create Image" and click Make ISO. A destination folder is required where the resulting ISO image will be saved. Once the image saving process finished you have the freedom to burn it on a blank CD with whatever you favorite CD burner software may be.
The new CD will be the twin copy of the Windows Installation CD but with one difference, it includes the SATA driver
Mar 17, 2008 | Microsoft Windows XP Professional With...
I can't use HDD sata on mainboard ASUS P5RD1-VM
Things need to be turned on in your bios patrohi. This is why windows didn't boot to the SATA. You need to use your manual & make sure the, Serial ATA Controller is [Enabled]
Within the Advanved menue under SouthBridge Configuration.
At the Main menue the SATA drive should be listed.
Boot settings need to change as well. At Boot Settings Configurations. Make sure your SATA drive is listed.
Boot order should list like, Floppy 1st, CDROM 2nd, SATA 3rd. The SATA will not list as a SATA but the model number of the SATA drive. Once all these settings are set save & exit. Your drive should show up for work & the windows CD should load.
Feb 20, 2008 | ASUS P5RD1-VM Motherboard
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
ASUS P4S800D-X Motherboard Logo
274 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
