Question about Miele H398BP2 / H398B2 Electric Double Oven
Why does my Miele double electric oven keep beeping and why is there no self cleaning on the keypad?
Miele double oven keeps beeping even after the electronic control board was replaced 4 months ago. Now the self cleaning tab has vanished from the keyboard. The oven is one year old.
  • 878 Answers
SOURCE: Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. back.
Posted on Dec 27, 2006
SOURCE: Double Oven says "F0" and beeps continuously
The fault code "F0" is indicating a possible stuck or shorted key pad or oven control board failure.
Determine if the problem is with the key panel or the oven control board by:
1. Pushing Clear/Off pad.
2. Disconnecting the Ribbon Cable Connector from the control board and waiting at least 32 seconds to see if the Code recurs.
If the code recurs, problem is in the control. Replace control.
If the code does not recur the problem is the Key panel and it would need replaced.
This test is normally done by an experienced service technician to avoid any possibility of getting shocked. This has to be done with voltage applied to the wall oven. Extreme caution should be exercised while testing.
I recommend calling a service technician to diagnose and repair your oven.
Posted on Jun 17, 2008
  • 15 Answers
SOURCE: fault 23 is displayed on the control panel after
F23 means that the required pyrolitic temperature was not reached during the self-clean cycle. If the other half of the oven does not do this, then it could be a problem with a door lock switch or one of the overtemp sensors.
Posted on Feb 27, 2010
Testimonial: "Thanks - I am sure there is a temperature problem as this oven is cooking much slower all round."
  • 43501 Answers
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Jul 30, 2010
  • 177 Answers
SOURCE: Replacement Door Hinges Miele Oven
hi the only place to purchase Miele spare parts is through Miele directly or from a Miele authorised service agent
Posted on Sep 02, 2010
Frigidaire Gallery series model GLEB30T8CBA key pad not working
Hello Dana, thank you for your post!
From my understanding your Frigidaire oven is displaying an error code of "F8" and your keypad is not working properly. An "F8" error stands for runaway temperature (overheating). I would recommend performing a reset on your oven and you can do that by disconnecting the power cord for at least ten minutes.
If that does not help correct your issue then you could have a problem with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would suggest having a professional technician out to perform a proper diagnosis and repair. I hope this information is helpful. -Matt
Jan 10, 2016 | Frigidaire 30 in. Electric Gallery Series...
Tried to do self cleaning on oven, about 10 minutes in got "f2 locked door" and it won't clean. what is that all about?
Error code F2 on clean cycle is indicating that the maximum permissable cleaning temperature has been exceeded. (or it's got too hot!)
However it seems unlikely that that would happen in just 10 mins. more likely it is a problem with the oven temperature sensor which should be checked over as should the lock switches..
Dec 14, 2010 | GE JRP24 Electric Double Oven
Cannot use self cleaning feature on Meile double wall oven. Get the same error message on the top and bottom oven. A giant F and fault 09.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Oct 28, 2010 | Miele H398BP2 / H398B2 Electric Double...
Was cleaning oven other night...wouldn't unlock when done...beeping f-3 f-2...trying to cook now in oven and it just keeps shutting off and beeping out of the blue f-3 f-2 again...cake in oven...HELP...
The only thing that I can suggest to you is to locate the breaker for the stove in the breaker box and turn off the power. Leave the power off for at least a minute. This will reset the oven to factory defaults.
Once you turn your breaker back on you should be able to open the oven.
Aug 07, 2010 | Frigidaire 30 in. Electric Gallery Series...
The F7 alert keeps flashing/beeping on my JKP27 GE electric double oven even after clearing it or cutting the power to the oven for a period of time. Any suggestions? Thanks!
Ya either have a stuck keypad or a bad oven control. To see what it is you push the clear/off pad, disconnect the ribbon from the control and wait 32 seconds, to see if the if the F-7 code occurs again, If it don't then bad keypad, if it does then bad control.
Jan 28, 2010 | GE JKP28 Electric Double Oven
Fault 23 is displayed on the control panel after using teh self clean function on our miele double OVEN H398 BP2. IT IS NOT LISTED ON THE MANUAL WAHT DOES IT MEAN?
Dec 12, 2009 | Miele DG 4080 Stainless Steel Electric...
I have Fridigaire double oven part# PLEB27T8ACA with F8 code prob
wow, that is so weird...i was just getting ready to write the exact same thing. this last time mine beeped, i just kept letting it beep for several minutes. if kept on. i then went in and pressed all the buttons except for cancel and nothing happened. then i pressed the oven light button. the beeping stopped. not sure if it's coincidence or if that was what i was supposed to press. i will keep messing with the buttons and let you know if i figure it out. i will dread if it beeps all night long.
Feb 14, 2009 | Frigidaire PLEB27T9DC Electric Double Oven
Oven lock will not open
my self cleaning oven door will not unlock what do I need to do?
Jan 01, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Miele H398BP2 / H398B2 Electric Double Oven Logo
3,799 people viewed this question
Top Miele Ovens Experts
Paul Bade
Dan Webster
Dan Webster
Are you a Miele Oven Expert? Answer questions, earn points and help others
