SanDisk Sansa e260 MP3 Player Logo
Posted on Nov 01, 2008
Sansa 260 I need to reload the software for my 260 sansa
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 04, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
97
Points
0
I want to erase the things on my sansa but can't..I found it and I want to erase the pictures, music, and recordings but don't know how!
2helpful
2answers
My computer doesn't recognise my sansa 260.
Sansa Not Recognized: Try connecting it to another computer the back straight to the motherboard ths should be USB 2.0 and see if it will recognize it as sansa or Drive/removable drive. if it does then download the sansa update software and install it. Make sure you disconnect the sansa and connect it when asked. This will update your sansas firmware and add the Usb Mode. Try to connect it to your computer at home it should recognize.... link for update software (http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) download to a flash drive much easier. Make sure USB mode is MSC
Recovery Mode may also allow your computer to recognize the sansa
lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Start the update software when finished disconnect
My desktop won't recognize my sansa 260
Its a problem with your USB cord...you need to replace the cord.
2helpful
2answers
Sansa e260 firmware
Mine was a bit more FUBAR I guess. I have a Sansa e260. I had rockbox on it, went to switch back to the firmware. Uninstalled rockbox and on reboot... the e260 was refreshing the database and then came to a frozen green screen.
My e260 was already in MSC mode. I did the steps above but was still stuck.
The solution that worked was one posted by "Slaughter" on anythingbutipod.
The ultimate fix for all e2xx v1 problems - Format, enter recovery mode, downgrade firmware Link (you'll need to format the drive), reinstall newest firmware via newest Sansa Updater, reload tunes.
4answers
Driver
hi i need driver for sansa e 260 mp3 player
2answers
How can I format my sansa 260
you dont need to format your sansa you just should go to your my computer then click on sansa icon then just drop your music into the music folder
Unable to install software for sansa e 260 R mp3 player
Go to settings on your sansa and scroll down to USB Mode.
Change it to MSC.
Sansa e 260
u can also use the itunes riper to put videos on ur sansa cuz i did it to mine
Sansa media player 260
is itr synced? Do you have all the software downloaded?
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
