Question about Lexmark X75 All-In-One InkJet Printer
My Lexmark X75 will not print
It has been working perfectly but now will not print. I tried the Lexmark troubleshooter and disconnected and reconnected cables but this did not work.
    Problem Solver:
  • 13 Answers
Try deleting the driver and re installing. Make sure you have or can get the install program before deleting the old.
Posted on Nov 01, 2008
Printer has stopped printing blue
Make sure that you are inserting only genuine Lexmark cartridges in your printer. Removing then re-inserting the color cartridge into the printer is a quick to minor cartridge communication issues.
Make sure that your color cartridge still has substantial ink level for printing using the Lexmark Solution Center software on your computer.
Click Start > Programs > Lexmark X74-X75 > Lexmark X74-X75 Solution Center. Check the ink levels.
If color ink level is still good, then it probably just needs some cleaning. Print quality issues can be due to dirty or clogged print cartridge nozzles. From the Maintenance tab in the Lexmark X74-X75 Solution Center, click Clean print nozzles to fix horizontal streaks. Your printer will then print a test page. Try to print a color page again to verify that the problem with the blue color is fixed.
If the problem continues, try to insert a different known working color cartridge to identify if it's a faulty cartridge issue.
Oct 26, 2011 | Lexmark X75 All-In-One InkJet Printer
X75 My color won't work. Black is fine. I installed a new one at Xmas and it worked fine. I hardly printed anything.. Yesterday the test page with peacock showed no blue and everything came out yellow. ...
run the print head cleaner tool using the lexmark software. since you hardly used the color the print head nozzle is dried up and needs to be clean.
run the print head cleaner atleast 5-10 or more times as needed.
Mar 12, 2011 | Lexmark X75 All-In-One InkJet Printer
Black ink not printing even tho a new black ink cartridge was installed recently and working properly until I opened the unit to install a new color cartridge and now the black ink is not printing and the...
Try to reseat your cartridges. Unplug and replug your printer into the power source to reset itself. If that doesn't help, try to clean your cartridges and check if print quality improves. If you're using Windows, go to Start -> Programs -> Lexmark X74-X75 -> Lexmark X74-X75 Solution Center -> Maintenance -> Clean print nozzles to fix horizontal streaks.
Feb 17, 2011 | Lexmark X75 All-In-One InkJet Printer
Lexmark x75 all in one. Started with communications device error. could not print. went through troubleshooting-still wouldn't print. started printing randomly(not initiated by me). Couldn't clear print...
Hi. That's quite a problem you have there. Have your attention first on the power supply. It does get hot but it's unusual if it gets very hot. Take out the power supply (the black box behind the printer where the power cord is attached). Check the power specifications. Most of the Lexmark power supply has input ranging from 120-240 Volts and an output of 30 Volts. Make sure you're plugging it in the right voltage range. Check if you're using power surge protectors or power strip, disconnect it and plug directly into a properly grounded wall outlet. Power surge protectors can also draw power away from the printer. When everything's well, try printing again. Hope this helps.
Mar 18, 2010 | Lexmark X75 All-In-One InkJet Printer
Lexmark x75 won't work
Contact the dealer since this still under warranty.
Aug 13, 2009 | Lexmark X75 All-In-One InkJet Printer
Lexmark X75 won't print in colour anymore
When you print a color document do you get any color output ?. You may want to try to print a test color document, consisting of say Red, Green and Blue color blocks. If any of the blocks is missing you may want to replace your color cartridge.
Jun 01, 2009 | Lexmark X75 All-In-One InkJet Printer
My Lexmark X75 will print but not copy. When I
I have an X75 at home and I remember the computer has to be on to copy, so it's really just doing a scan and then an immediate print. Are you copying from the button on the X75 or from the All-In-One Center software on the computer? If the button, try it from the software.
Feb 24, 2009 | Lexmark X75 All-In-One InkJet Printer
Print Problem
free needed software for lexmark x75
Aug 03, 2008 | Lexmark X75 All-In-One InkJet Printer
Lexmark x75
I DONT HAVE CD PROGRAM THE MY LEXMARK X75 PRINTER
Jul 11, 2008 | Lexmark X75 All-In-One InkJet Printer
Lexmark X75 no color
even though you have ink coming out of the cartridge, if it's more than a few months since it's pumped any ink, it can be clogged internally, blotting with paper doesnt always work. Try a new cartridge, or buy a new printer, it's usually cheaper now to get a whole new printer than it is to replace a set of cartridges. consider it's a few years old now
Aug 16, 2007 | Lexmark X75 All-In-One InkJet Printer
Lexmark X75 All-In-One InkJet Printer Logo
49 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
