I removed the screws from the top and at the bottom at the back, is there any hidden screws on the sides or at the bottom? I this the best way how to get to the pump?
You can't post conmments that contain an email address.
Re: How do I remove the back cover on the washing...
Removed screws from top / bottom and sides? then pull top pcover back slightly and lift at rar to clear back cover manouver the flex drain pipe as you remove panel ?
hi this is most practical access to pump rather than tip machine on its back to access from below? as for rear panel?? is panel not moving at all ? with what you have done so far ? may i suggest ? look at the rear panel for any ? screws that are still fitted and remove? other than this if you remove top panel as mentioned in prev post you will be able to see behind panel for any unseen security that is peventing removal out of curiosity ? is the problem you have waste water pump not working ie blocked ? slow? or something else ? be prepared /for what you may find in pipe when you remove from pump ? the missing sockbra under wire bone/ etc one of the mysteries of wash machines ?hi this is most practical access to pump rather than tip machine on its back to access from below? as for rear panel?? is panel not moving at all ? with what you have done so far ? may i suggest ? look at the rear panel for any ? screws that are still fitted and remove? other than this if you remove top panel as mentioned in prev post you will be able to see behind panel for any unseen security that is peventing removal out of curiosity ? is the problem you have waste water pump not working ie blocked ? slow? or something else ? be prepared /for what you may find in pipe when you remove from pump ? the missing sockbra under wire bone/ etc one of the mysteries of wash machines ?
Follow these procedures to remove the back access cover on an Indesit WIE 167 washing machine and replace the belt:
Disconnect the washer from the electrical outlet and turn off the water supply.
Move the washing machine away from the wall so that the back can be accessed.
Find the screws that secure the rear access cover. Often, they are positioned throughout the cover's perimeter.
Remove the screws using a screwdriver and store them in a secure location.
Carefully remove the washing machine's back access cover. Using a flat instrument, such as a putty knife or a scraper, to pull the cover away from the machine may be useful.
Once the cover is removed, the belt should be accessible. Remove the old belt from the machine with care.
Put the replacement belt on both the motor and drum pulleys.
Align the back access panel with the washing machine and secure the screws to reattach it.
Reconnect the washing machine and activate the water supply.
Verify that the replacement belt works properly by putting the washing machine through a series of tests.
When servicing a washing machine, it is essential to observe all safety precautions. If you are uncertain or uncomfortable with any of these processes, it may be better to call a skilled technician or service center for assistance.
take the top off,remove the soap bucket,take the screws off on the pc board/front cover. the top screws of the front pannel are usualy behind the display cover. the botom screws are behind the bottom plastic cover which you have to prey off with a screwdriver from the top side.
Remove back cover of the washing machine.There are two rubber hoses connected to water pump remove them.and careful detatch live wire from pump motor.There are either 3 or 4 screws connecting the pump onto the washing machine body unscrew them,and the pump should be removed easy then.
1)You have to tip the machine on it's back and remove all the screws from the bottom grey cover. 2)There are 4 screws securing the drain plug at the back. Remove these as well. Gently pry off the bottom of the machine. 3)The spin motor sits on four spring mounts. Undo the 4 screws from the top of the mounting plate.The motor shaft is not screwed to the drum. Slide the motor out of the drum shaft. 4) Once free, there are 2 X 10 mm bolts that lock in 2 grub screws on the shaft. Loosen these an remove the grub screws and remove this coupling off the drum shaft. The drum is now free to come out the top of the machine.
Open top cover of the machine. From the back on top there are 3 screws, remove them and slide back top cover to remove it. You will see a metal part with 2 thin red wires(sensors) atached. One is probably loose and the machine shows error code e11 and will not centrifuge. Make sure it holds and try to run the machine again.
This
article shows step by step photo instructions on how to replace the
door boot seal of a common GE brand front load washing machine.
The washing machine in this example is the GE and the door boot seal
j
Phillips head screw driver
small socket wrench
7mm socket
replacement door boot seal
lots and lots of patience
remove dispenser
Unplug washing machine and remove dispenser.
Remove lower front cover by removing 3 screws holding it on bottom.
Remove screws connecting top control panel to front of washer.
Completely remove control panel from front panel.
Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off. Completely remove control panel from front panel.
Use bungie cord to tie back control panel.
'Pop' off the tension spring being careful not to bend or break it.
Feel for the tension spring which tightens the door boot seal onto the front panel. 'Pop' off the tension spring being careful not to bend or break it.
pull the right-hand side of the seal tight to reveal the inner tension ring holding the seal onto the inner part of the washer.
With tension spring removed, pull door boot seal away from front panel. On
GE models, pull the right-hand side of the seal tight to reveal the
remove inner tension ring
IMPORTANT:
Use a short stem philips head (such as a Husky No. 2 x 1-1/2 In.
Phillips Screwdriver) to loosen the inner tension ring via its clamp
screw. NOTE: you may have to remove the front panel to gain access
to the tension ring. If that is the case, remove the front panel by
removing the screws positioned at each corner (four screws total). On
some models you may have to first remove a lower-front panel to gain
access to the bottom two screws of the main front panel.
This
j
small socket wrench
7mm socket
remove dispenser
IMPORTANT:
Sounds like a connection may have come loose in the move.
The top cover comes off fairly easily with the removal of some screws in the back. Once screws are removed, slide top cover toward back of washer and take a peek inside looking for loose/disconnected wires.
I've been looking too. And finally found it! john_in_erie Rank: Apprentice Rating: 98%, 12 votes
Replacing gasket is fairly simple - need 2 people. UNPLUG FIRST - 1. Remove the plastic cover on top of machine that is mounted to back of control panel. 2. remove dispenser - push down on tab at back and it will slide all the way out. 3. Remove lower front cover by removing 3 screws holding it on bottom. 4. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off. 5. Remove the 3 screws that hold the control panel on - note these are different type of screw so keep track of which screw goes where - one of the screws is next to dispenser opening. Once this is done you can reach in to machine and disengage locking tab on right side under "washer temp" - have someone hold this part aside if you do not want to disconnect the cables. 6. Remove spring loaded wire securing door seal to front cover. 7. Remove the the 4 screws holding the front cover on. This item is a bit heavy so be careful. Disconnect the three door latch wire harness and place this aside. 8. On the right side of the gasket you will find the clamp screw that holds the seal to the drum - loosen this screw almost all the way and remove this wire clamp. carefully remove the two tube connections and remove the gasket completely. Take note how these were installed before removing. Now you can carefully clean the gasket seats on the drown and door and replace the gasket and reverse the steps to put the machine together. While you have the covers off it would make sense to remove and clean the pump strainer mounted on the lower cross support - this can be messy with lots of water coming out so go slowly and have plenty of towels and a shallow pan to catch the water with. HOPE this helps.
