Question about Apple iMac G4 Desktop
My imac g4 isn't reading the dvd/cd drive at all
Hi, my imac g4 isn't reading the dvd cd drive. I was going to do a clean install, wipe the hard drive and start over but the drive won't read the disk. I am so getting a message that my drive is full, so need to free up some memory, or add memory.
First order of business however, is to figure out what to do with the dvd/cd drive.
  • rd stuck Nov 24, 2008
    Imac g4 will only read apple software cd
  • jinsop Mar 25, 2009
    i also had a similar problem but i recntl instaled a new dvd drive please help
It won't read it because the new os disk is double layered and the g4 drive you have probably won't read double layered dvds.  best solution is to buy or borrow an usb external dvd drive.  i did this last week and it worked fine.
Posted on Mar 14, 2009
I have  a Powerbook G4 17in laptop. I cannot get sound from the speakers, on setup there is no sound, I have tried various troubleshooting....still no sound.
Help!
Posted on Nov 06, 2008
IMac G4 Mac Desktop: i have a IMac G4 that when i start it a folder wit...
It can not find the hard drive or the startup folder on the hard drive. Try and fix that by putting in the original boot cd/dvd and repair and choose your hard drive start up folde as boot device. If you can not your hard drive may have died.
May 16, 2010 | Apple iMac G4 Desktop
When my imac g4 tries to bootup it shows a folder icon
It sounds like the system is corrupted. What I would do is to get your instal disk and boot up holding down the c key on your keyboard. Once you have booted up go to the file menu and run disk utility to verify and repair the hard drive. Then go to the instal menu and instal a fresh system remembering to preserve the users data so you do not wipe anything. Hopefully this will work.
Oct 03, 2009 | Apple iMac G4 Desktop
My imac G4 with OS 10.3.9 is not reading a DVD-R disk
That is not a problem, all DVD drives read CD's.
Apr 04, 2009 | Apple iMac G4 Desktop
My G4 1.25ghz with 1 gb ram plays abc video slow.
Hello, sorry you are having trouble,
There are so many variables when it comes to Video play back on a Mac..
Yea, 1.25 Ghz with 1 GB of Ram answers most questions, yea, it should play OK,
BUT:
  • Is the video on a CD or DVD ? well, these iMacs don't have a very fast optical drive.
  • How much room do you have on your internal hard Drive, if it's too full ( more than 80% full ) then you will suffer read/write performance.
  • Is the video on an external harddrive, is it a USB drive? the USB on the iMac G4 is USB 1.1, 11Mbit/sec, way too slow to play a big video smoothly.
  • Just what is the size of the video, is it like that for all of them or just one, might it be a HD video with high frame rates?
  • What version of the MacOS X do you have installed? If you installed Leopard 10.5 on the iMac G4, nothing will run smoothly,
  • Are you playing this video over a network? forget it it's got to be on the internal or a FireWire external disk otherwise it will stagger...
Well, there you go, I know, it's so easy to say Hey man, just get a new Mac and everything will be fine... But that machine is going on 6 years old now, Video technology has not stood still.....
Mar 24, 2009 | Apple iMac G4 Desktop
''imac g4 does not see dvd drive after Xferring files and setting
when booting in os x after the first boot chime immediately hold down keys <apple,option,o,f> all at the same time and allow computer to boot to open firmware once there type "reset-nvram" exactly like that but without quotation marks and press enter once it returns to command prompt type "reset-all"and press enter (you must have the "-" in between the commands) the computer should restart if not when the command prompt returns type "reboot" and hit enter ..... also you can check the drive status by going to "system profiler" in apple drop down menu--->about this mac-->more info or applications folder-->utilities folder--->system profiler then selct disk burning under hardware in the list on the left
Mar 18, 2009 | Apple iMac G4 Desktop
My iMac is not recognizing my CD/DVD-RW drive
Install your startup CD and restart the computer holding down the "C" if your computer starts off of it, the CD player is okay and you have a software problem, if does not start off the CD the CD/DVD needs to be replaced
Nov 28, 2008 | Apple iMac G4 Desktop
Imac g4 cd drive
It;'s not a great Idea flipping the mac over they have a special stand to put them on when working on them. But it should be able to cope with it. Your mac is relatively old now. With all the moving around it could have just given up the ghost.
They are quite tricky to work on with the hard drive sitting on top and the cables running over and down the side there is a stack of heat generated there. Just make sure you put ll the thermal back in. If it's not a miss seated connection it could be a number of things. Cable, heads. Trouble shooting is quite tricky. As it is a desktop, in a lot of cases it is cheaper to buy an external DVD reader/writer. They are faster now!
You should be able to install OK when it is in terminal mode. You could run disk utility but more than likely you'll have to run the installation again.
Sorry, not much help.
Sep 11, 2008 | Apple iMac G4 Desktop
IMac with DVD issue
have you tried a cleaning disc? the buildup of gak on the lense could have become too bad to read, or the drive is toast.
Aug 01, 2008 | FastMac (APP-5691) for iBook G4 & iMac G5...
Updating a slot loading iMac from OS8.6
Unfortunately, The disks may be DVD, not CD. You might be able to do the install by networking the iMac to the Macbook and using the laptop's drive to read the disk.
Feb 19, 2008 | Apple iMac G3, G4 USB Keyboard 9224078
Apple iMac G4 Desktop Logo
947 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
