Question about Dell Axim X50v Pocket PC
Unknown card in socket 1
4gb compact flash in socket 1, Removed to insert in computer. Upon reinserting into ppc I get this message. The card worked fine up to that point. Inserted another CF card and got the same message. Did a hard reset and stil get the same message asking for the name of the device driver
  • marky_mark89 Nov 16, 2008
    I have the exact same problem... Is there a way to format these CF cards for the axim? I have an axim x50v btw...
3 Suggested Answers
  • 903 Answers
SOURCE: Compact flash cards
You can try to do a softreset and try to read the cards again! Also cleaning the slot should also help...
Posted on Sep 08, 2005
  • 567 Answers
SOURCE: I inserted a Dane-Elec 4gb cf card into my Dell
Hi thanks for asking,you need to install the drivers for your device please go to http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R129273&SystemID=PDA_AXIM_X51&os=PPM&osl=en&deviceid=7638&devlib=0&typecnt=1&vercnt=3&formatcnt=1&libid=7&fileid=172105an and download the driver for your device.
Posted on Jul 07, 2010
After inserting the sandisk into my computer, I get an error message. It says I/O device error. What does this mean?
It usually means that your Input/Output device (e.g. Card Reader either internal or External) is not compatible with your Flash card which is a 'newer' high speed and high capacity medium (OR your Flash card is a new one and has not been formatted). You can check that your card reader is working by inserting a 'standard' (not ULTRA) working lower capacity card (1GB or smaller). Hope it helps: let me know hoe you go.
Apr 03, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
My memory stick has stopped working, nothing shows up when I insert it into the computer...I need some of the files which are stored on it, do you know how I can fix it?
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive this program may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
Nov 12, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
My computer which is running Windows XP pro 2002 does not recognize my San Disck cruzer 256 mb memory key. The light flashes upon inserting in to computer and then goes out and then I get message that CPU...
try to disconnect all usb devices and install it again to another port also try to install it on another PC if it workson another PC and yours not then try to remove ur O/S and install a good one like windows Xp SP2
Jun 15, 2009 | SanDisk 4GB microSD High Capacity Memory...
"Card Not Initialized"
yes take a bottle of air blaster commonly used fo computers and blow out the card bay then on your computer insert the compact flash card and click on it erase the disk do not format it at all then insert it into your camera. the camera will format it with what the camera uses.
Sep 06, 2008 | Fuji FinePix S7000 Digital Camera
Photo card inserted backwards error
Try a full NVM reset on the unit and check
Reset Steps are.
Unplug the power cord from the unit when there is still power in the All-In-One and press and hold the # and No 9 Button without releasing the buttons plugg the power cable back, it should come up with a message as reset
If the screen go's blank after you connect power cable, then release the keys and turn the power On, it will come up with a message as Full NVM Reset
Good Luck
May 27, 2008 | HP PSC 2210 All-In-One InkJet Printer
"For" Message
The camera is telling you to format the card. You can do this in the cameras playback menu. That should take care of the problem.
May 27, 2008 | Nikon D70s Digital Camera
Compact Flash Problems
Dynamite,
have you tried to reformat the CF card?  If you deleted the image through your computer and not with the camera, the computer may have removed more than what was needed...
SteveK
Oct 27, 2007 | SanDisk ULTRA II 4GB Compact Flash Card...
HP PSC 1610 All-In-One - Memory card Error
Pulling out the card without using the 'Safely remove Hardware feature' risks corrupting data on the card. Reformat the card in the camera. Also with compact flash it is a simple matter to wreck the some of the tiny pins in the card slot. Check out both these and come back
Sep 10, 2007 | HP PSC 1610 All-In-One InkJet Printer
Updates for the PCMCIA and Compact Flash Card controllers
Some MobilePro units have exhibited the following symptoms when using Compact Flash Cards or ATA PCMCIA Memory Cards: 1. Storage Card folder is not displayed when you insert a PCMCIA ATA card and/or a Compact Flash card. 2. Warning message "Unidentified PC Card Adapter". 3. Warning message "Storage Card Warning" displayed. To fix these issues: If you have a MobilePro 750C without a ROM upgrade, download the file MP75Pcm.exe from support.necsam.com. For a MobilePro 750C with upgraded ROM, use the file MP75RPcm.exe. After the files are extracted, follow the instructions in the Readme.txt file.
Sep 14, 2005 | NEC MobilePro 880
Sep 14, 2005 | NEC MobilePro 750
Dell Axim X50v Pocket PC Logo
80 people viewed this question
Alun Cox
