Ceramic cone destroyed - Heating & Cooling
    Novelist:
  • 124 Answers
Please try to be more specific . what type of device are we talking about? make model indoor outdoor? thanks
Posted on Nov 02, 2008
How do i fix the wires in the back of the sound bar if they are ripped
Tough question! WHERE are the wires ripped from? If it's directly at the speaker 'spider coil' at the speaker CONE, it's very difficult to repair but sometimes it can be done!
I have re-soldered speaker wires right at the speaker cone but FIRST I used a NEW EXACTO blade to carefully remove the enamel paint/coat from the wire end... please don't pull too hard or you will destroy the coil for good... and that's bad.
The coil shown below is toasted, but as you can see, the coil wire is quite small and delicate!
After soldering I added a DOT of epoxy fixing the new wire junction to the cone to assure that new connection/junction won't 'rattle' on the speaker as the speaker does it's job!
Dec 05, 2017 | The Audio Players & Recorders
What happens when a clutch bell fails on a nitro engine?
if you are talking cone clutch then if the bell section fails it will probably explode out through the bell housing and floor pan .the resultant unbalance will probably destroy the engine.
Dec 15, 2014 | Cars & Trucks
The cone set button on my Cress E27 kiln quit working, so I need a wiring diagram so I can determine if it is a loose or corroded wire.
Ceramic Glass Kilns Industrial Furnaces Kiln Furniture and Pyrometers... Scroll all the way to the bottom. Left side should be the proper pdfs. Instead of attaching the pdfs I included the link because you may find other helpful information for your kiln, just in case.
Mar 09, 2014 | Dirt Devil Vacuum. Jaguar Pet Bagless...
1993 harley davidson when u get around 3000 rpm i hear a rattle i think in the top end it is louder when i let off on the gas
What grade of gasoline are you running? I run only high octane fuel to prevent spark knock which is what you may be hearing.
On your Evolution engine, you have tappets, rocker arms, and pistons that could be source of your noise. However, most of these items will make a noise from idle RPM on up. At about 25 to 30 thousand miles, Evo engines have a nasty habit of losing tappet rollers. The make a very loud noise when they go bad. The roller locks up and usually destroys the camshaft as well.
Now there is one thing that could be making your noise at 3K and up. If you or someone else has put a set of "torque cones", "power cones", or "anti-reversion cones" in the exhaust pipes, these may be the source of your noise. You'll just have to try to narrow down the area that the noise is coming from.
Good Luck
steve
Aug 04, 2010 | 1993 Harley Davidson FXR Super Glide
I bought a 1950's farberware perc coffee pot. Since it is not heating we think we might follow directions on bottom. remove plate, hook next hole in fuse wheel ..We can do this but...Also there is a small...
Hi J lee. If you go on to eBay and search for Farberware coffee pot parts, you will see the filters you need. The 206 is a URN , You put the ceramic tube on the pump, now you put the cone spring on top of that, small part to the ceramic, then the coffee basket on top of that. I sell and repair Farberware pots through eBay and if you have any questions you can get me on my email callahanronald@att.net. Good luck. Ron
Jul 21, 2010 | Coffee Makers & Espresso Machines
I recently bought a TD-6 set, everything works
I have repaired one of these before.
On the version I repaired, there was a TINY trimpot accessable thru a hole that is semi-hidden. In the case I had, someone had actually destroyed the trimpot by forcing too big a screwdriver into the hole and smashing the trimpot.
It was relatively easy to open the unit and replace the broken trimpot...
WARNING, if that set has those "foam" cones under the snare type heads, expect trouble with them and the cones are NOT available anywhere for replacement. Essentially you have to MAKE your own now...
Mar 02, 2010 | Music
Gas dryer won't fire off. all safties are closed and the ceramic glow coil does light up.
This is likely the result of a bad radiant sensor (mounted on the burner cone).
Sep 07, 2009 | Maytag Dryers
Ipaq 1945 screen is light and rastered lines appear after a minute or so and is washed out. When turned on it is nice and bricht and easy to read. Is there a fix?
Did you replace the back up battery and assume the little thing under the paper do not remove tag was a screw? I did and destroyed the little ceramic variable whatever it is, so my screen does the same thing. If anyone has a schematic, I'd love to know what I destroyed and if it is obtainable.
Ron L
Aug 15, 2009 | HP iPAQ H1945 Pocket PC
Ceramic pot loosing luster
i like to use diluted vinegar on stubborn cleaning jobs. try this - it works on a lot of other problem stains.
Dec 19, 2007 | Rival 38601 Smart Pot 6-Quart
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
