Question about Protron PLTV-26 26 in. HD-Ready LCD Television
In need of plug in antenna
Plug in antenna
I hooked up my new Proscan TV to the antenna but it can't find any channels
You need to check the connection is tight from the antenna and also on the back of the tv. You may need to try another coaxial cable. Is your antenna powered, meaning does it have a power plug that needs to be plugged in? Is your tv an old crt television? You may need a converter box to be able to view digital channels. A signal booster may help you get more channels.
Your tv or antenna may be defective. You could try your antenna on another tv. If your other tv gets a signal, your tv's tuner could be bad. If the other tv goes not get a signal either your antenna could be bad. I hope this helps narrow down your problem.
Oct 22, 2016 | Proscan Televison & Video
I need the code to put a antenna on
never had to add any codes for an antenna here .
Mar 01, 2016 | Televison & Video
What do I need to correctly connect/setup my VEON 39" SR09110-B. I have plugged the power cord in and the antenna cord into the rv port on the back of the TV but the TV has no signal. Do I need to do
Your unit may need to know that it must read the antenna signals that are coming from the antenna. The unit might have a set-up feature in the TV's settings function for choosing either a cable (digital) or antenna (analog) signal.
Sep 19, 2014 | Televison & Video
Cant get radio to play stops on station wont pick up antaina hooked up
Check if the antenna male plug is completely plugged into the antenna port of the car stereo.If it is plugged well in the car radio but don't pick stations then your antenna cable is bad.You need to install a new set of antenna,available at any car audio supply.
Jan 30, 2011 | Sony Car Audio & Video
I have a 2002 alero. Need to know where to plug in the radio antenna.
THE OLDSMOBILE ALERO DONT HAVE A EXTERNAL ANTENNA MAST. THE OLDS ALERO HAVE WIRE GRID ANTENNA INCORPORATED INTO THE DEFOGGER GRID IN THE REAR WINDOW.THE GRID ANTENNA HAVE A REAR WINDOW ANTENNA MODULE MOUNTED BEHIND TOP OF THE REAR SEAT BACK. THE RADIO ANTENNA CABLE GOES TO ANTENNA MODULE LOCATED TOP OF THE REAR SEAT BACK.
Jan 02, 2011 | 1999 Oldsmobile Alero
Changing AM / Fm radio antenna on 2006 chevy silverado. bought new antenna and it came with short pigtail. where does it plug into. Thanks
Aftermarket antennas come with notoriously short leads. What you need to do is remove the stock antenna and compare lengths to the replacement. The difference is the length of extension you'll need to get from your local electronics supply or auto parts store. The stock antenna plugs into the back of the stereo itself.When you route the new lead, try to follow the original location as best as possible.
Good luck!!
Nov 16, 2010 | Car Audio & Video
Unit does not pick up satellites but recognizes when antenna is open
I have a unit like that. The antenna appears to be dead. It just searches forever and never finds anything. I use an external antenna that I got from eBay (brand is Gilsson) and it works fine. You just plug it in the external jack (after removing the little rubber plug) and it works even better than the built-in antenna.
Jul 01, 2009 | Garmin iQue 3600 GPS Receiver
I can recieve on my CB but cannot transmit
sounds like thats a regular antenna wire. cb radio normally have a pl259 plug. and you need a propper cb antenna not one that has am/fm plug. cb antennas require tuning using a SWR meter.
Mar 31, 2009 | 1987 Honda GL 1200 Aspencade Gold Wing
Sirius Antenna
There are several ways to tackle this problem, most of which would involve getting to the back of the radio, but before you do, make sure you have an "antenna extension cable". Then plug in the 'extension cable to the radio/sirius unit' leaving the other end to 'hang out' where you can then get access to the 'extension' cable. Then you can plug in the existing antenna when you're not using the camper or plug in new antenna that gets clear view of the satellite. Depending on your location and general direction of travel you may be able to use a 'home unit ' antenna on your dash as I do and it works very well. In my truck I often use a home antenna also, although I also have the large unit that bolts to the (tractor) truck mirror assembly.
The other solution is to find a CB repair place (often at truck stops) that is familiar with repairing, satelite antenna wire and pucks. Have them split the wire and place a male and female plug to accomodate the extisting antenna and the new antenna. This service will cost you about $30-50.00 They should find the parts needed at a satellite radio store that sells marine/business/home antennae systems. The parts are not all that common - or the CB fellow may connect male/female connectors that are unique to your truck situation - then any connectors will work but only on that truck of yours. -- Frank
Sep 15, 2008 | Audio Players & Recorders
Antenna
Wear the antenna headphones around your neck and use ear buds. Works like a charm!
Jun 04, 2008 | Delphi SKYFi3 Satellite Radio Receiver
Protron PLTV-26 26 in. HD-Ready LCD Television Logo
21 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
