Question about Honeywell Programmable Thermostat Heater
Locked screen on a vision pro 8000
The screen is locked on a vision pr 8000
  • 34 Answers
Select system, hold down the two boxes immediatly to the left and right of the center box for 3-5 seconds
Posted on Nov 12, 2008
I need the instruction manual for a Honeywell TH8321U1097 Vision Pro 8000 thermostat.
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1894EFS.pdf
Dec 09, 2017 | Honeywell Heating & Cooling
How to unlock screen
Change battery located on back of thermostat??
Go to google
Search for your model number 1234XX .pdf
Add .pdf in search parameter.
Honeywell posts most their thermostat manuals.
Open pdf file, and then Use Ctrl+F for search feature
Word-Search manual
To find model number on thermostat, remove from wall.
Model number appears on back.
Don't forget to replace battery while you have back exposed.
Dead battery can also cause lockout and malfunction
Apr 18, 2013 | Honeywell TB8220U1003 Commercial Vision...
Need Manual for honeywell vision pro 8000
Go to Honneywell website. Should be there. May take some time to locate it.
Nov 08, 2011 | Honeywell Programmable Thermostat Heater
Manual for vision pro 8000 tstat
http://yourhome.honeywell.com/home/Applications/FindOwnersManual.aspx
Dec 17, 2010 | Heating & Cooling
Honeywell TH8320u Vision Pro 8000 Digital keeps calling for heat
If the thermostat is not over shooting the temperature than don't worry about it.
These thermostats are very sensitive and will turn the heat back on even before the degrees drop on the display. Often they will shut down before the display changes also. You can change the sensitivity of the thermpstat if you read the directions and change the cycles per hour to a less number. There is an installers program in there that you need to push a combiunation of buttons to get too. The instructions tell you how to do that also.
Hopefully you did not throw away the instruction manual for your t-stat.. :-)
Heatman101
Dec 28, 2009 | Honeywell Programmable Thermostat Heater
Vision pro 8000 total lock screen
did you make sure that when you pushed the system button that either heat or cool was blinking before pressing the buttons left and right of center? Also you can pull the stat from the base mounted on the wall and remove the batteries, wait a few and put the batteries back in and it should revert back to initial factory settings
Jul 14, 2009 | Honeywell Programmable Thermostat Heater
GOODMAN CPLT36-1 WITH HONEYWELL VISION PRO STAT 8000
what is the trans former voltage needs to be 26- 28 v. and is the board fused max 3-5 amp fuse I know it is on of the two check all of your wiring. good luck Tom
Jul 11, 2009 | Heating & Cooling
Heating & Cooling Logo
1,032 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
