Question about Yamaha RX-V550 Receiver
Not getting sound from right speaker
I am only getting sound from both my left and right front speakers in the fm tuning mode (radio listening). When I switch to tv (dts mode) the right speaker goes silent. I can switch back to the fm mode and the speaker comes back on. I have done the speaker test and get sound from both front speakers. I am using the 2-channel stereo mode for everything as I have two fronts and a subwoofer. Any thoughts on this problem?
  • Drew DuRoff Sep 22, 2006
    Hey, just wanted to thank you. I had gone through just about everything to try and correct that problem. Your answer did the trick. I went through the rca cable connections and sure enough, one of the cables was not all the way seated. I think the cat got back there! Anyway, good job!
    Thanks again
    ericd555
    President:
  • 3,130 Answers
How do you have the audio hooked up from the TV set? If its s video or RCA plugs? If it is switch them around and see if it swaps channels that goes out . If it does then the output cable or the jack is bad. If your using an HDMI ir a scart cable. The cable or connections could be bad. Unplug it and reinsert it or while the units on mover it around and see if the audio comes back on.
Posted on Sep 22, 2006
Have a 1988 Chevy Cheyene p?u with a Am radio in it now. Want to install a factory AM/FM radio. AM has a solid wire going to radio. How do I hook up AM/FM with clip?
Following are colour codes for your radio curtesy of;
Source(s): GM dealer tech over 30 years. HyperGforce
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
The solid wire (casing) would enclose a number of thinner wires that may or may not include these colour codes.
You have to match up the wires and their functions in your new radio with these colour coded wires, have fun..........
Oct 16, 2017 | Car Audio & Video
I want to connect a stock delco radio from a 1997 buick lasaber into a 1997 Grand jeep Cherake the radio has cd/tape/am/fm/ need to know what coler wire goes where. serial man.no. stock no. is 16249434 ...
1997 Buick Lesabre Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Radio Ground Wire: Black/White
Stereo Radio Illumination Wire: Gray/Black
Stereo Radio Dimmer Wire: Brown/White
Stereo Radio Antenna Trigger Wire: Dark Green
Stereo Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 5 1/4? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6? x 9? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
May 12, 2011 | Car Audio & Video
I have an ONKYO TX-SR606 receiver and I am trying to listen to FM radio using more than just the center channels. I have gone through the setup screens for the tuner and only Analog choices are available....
In reality the correct way to listen to radio or any music source for that matter is in 2 channel stereo. What this means is that the front left and right will play and also the subwoofer. If you absolutely want all your speakers to play while listening to fm, than press the Multi channel button and set it to direct, or any other sound field that you may desire.
Good Luck
Jan 08, 2011 | Onkyo TX-SR606 Receiver
I need to find the diagram for the wires of the car stero AM/FM Cassette 1999 Ford Ranger XLT
1999 Ford Ranger Pickup Car Stereo Radio Wiring Diagram.
Car Radio Constant 12V+ Wire: Light Green
Car Radio Switched 12V+ Wire: Yellow/Black
Car Radio Illumination Wire: Light Blue/Red
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger N/A
Car Radio Amp Trigger Wire: Blue
Front Speakers Size: 6 1/2′
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): Dark Green/Orange
Right Front Speaker Wire (-): White/Light Green
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
pls rate
Aug 17, 2010 | Buck Ford Econline Van 1998-2006 Stereo...
When listening to the fm tuner on my yamaha htr 6060, will all 7 speakers still make sound? i' having trouble getting sound from the other speaker connections other than the L and R front connection.
analog fm is broadcast in stereo you would need to use a simulated surround setting to have sound come out of your rear and mid surround speakers.
your manual says the default setting for fm broadcast is:
Radio Listening TUNER MUSIC ENHANCER
7ch Enhancer
Select this SCENE template when you enjoy FM or AM
radio programs.
make sure you unit is not in straight mode try pushing the straight button on the front of the receiver let us know if more troubleshooting is needed.
Cheers!
Feb 15, 2010 | Yamaha HTR-6060
I have a 2001 Dodge Ram 1500 that I'm trying to up grade my radio form a A and fm cassette to a dual CD cassette . I need help with wiring because they are different colors.I have the new 16 pin harness...
2001 Dodge Ram 1500 Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Sep 09, 2009 | Durabrand Car CD Player and AM/FM...
Advent DVD player in vehicle - can't get sound through speakers
I just solved this problem on my Ford Edge 2010. Start the dvd. Hit the FM button on the remote. It will pop up an FM radio frequency in the top left corner of the screen. For example, ours is 88.7. Tune the car radio to that frequency and the sound should come through the speakers. Hope it works for you.
Mar 24, 2009 | Sony MV-900SDS Car DVD Player
Can't get clear sound when not in "bypass" mode on Denon Pro Logi
From the FM radio mode, from your remote press the speaker button to make sure just the front speakers are on, make sure surround is off and use the tone cotrol button on the right side of the amp to adjust the bass and treble. That should clear things up a bit
Feb 25, 2009 | Denon AVR-2802
Wiring diagram 1996 ford explorer premium sound radio f57f-19b165-ag
Here it is.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Sep 29, 2008 | 1996 Ford Explorer
Surround sound
It must be about the sound quality need of your amplifier. The sound processor simply needs to get clear signals from sources such as fm/am receiver, dvd/cd players etc. in order to manage'em to give you the optimum surround sound. If the fm receiver has an "FM MUTE" option, I recommend that you turn it on. By doing so, you'll receive only good quality fm stations, furthermore your amplifier will let you get surround sound. The second issue you mentioned has its own answer inside. Use a "new" cd player, you can get optical cables, digital coax cables to improve the performance if you like..
Jun 07, 2007 | Onkyo HT-SR800 System
Yamaha RX-V550 Receiver Logo
271 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
