Question about Goldstar DH504EL Dehumidifier
GHD30 dehumidifier completely dead
I have a Goldstar GHD30 dehumidifier approximately 2 years old. It had recently been leaking a blue green fluid like substance from underneath. Now it seems completely dead. I've checked my circuit breaker, the outlet, the dehumidifier filter, coils evrything inside looks fine except nothing runs. The fan, condenser nothing runs. Could it have leaked freon? If so would this prevent the fan from working too? Could I have multiple issues? Is it worth having someone come out and look at it or do I just need to buy a new one? Thanks, Eric
  • gks_2402 May 14, 2009
    I have a GHD30 dehumidifier purchased from Home Depot April 2008. The unit was used for one summer and stored. It is now completely dead and will not do anything. I've cleaned the filters and the coils. The light came on briefly when the tray was out of the unit. I put the tray back in and it made a faint noise for about 3 seconds. I've got it apart now and can't see any disconnected wires. Kind of dissapointing since this is just one month out of warranty.
  • 828 Answers
If any machine is completely electrically dead it is a sign that there is no electrical voltage getting through to operate it. Using an electric meter it is a relatively easy task to find the point of differential voltages which would indicate where the open circuit is located. The blue green fluid found is from copper oxide and is not necessarily indicative of a refrigerant leak. Oil present would be an indicator of a refrigerant leak.
Posted on Nov 17, 2008
Have a Goldstar Dehumidifier GHD30. Approximately 2 years old refurbished. The fan will run on the lowest setting but the compressor does not start. When I turn the dial to a higher setting the breaker...
doesn't sound good sounds , the compressor is bad .. you might want to check if it has a gfic. i could be bad, i would cut it out and try it without before i replaced a gfic
Jul 25, 2011 | LG DH30 GoldStar Dehumidifier
Product Goldstar Dehumidifier GHD30: Machine runs when red button is depressed by hand. Return water bucket and machine stops. Set theromstat controller on max, and when button is depressed it works and...
Hi
You need to check that the bucket is clean and that the sensor for the water level in the bucket is clean.
An old toothbrush and some warm soapy water can sometimes achieve a great result.
Failing this you may need a new sensor, be careful and either draw or photo the old wiring route with your cell phone to make it easier to fit the new sensor
Hope this helps
Gordon
Apr 17, 2011 | Goldstar DH304 Dehumidifier
Won't come on
Definitely check the air filter, it has a sensor and will stop working if it's dirty. Easy to clean by running water through it.
Jun 09, 2010 | Goldstar DH304 Dehumidifier
Goldstar dehumidifier won't run
Sounds like this unit developed a freon leak and that will make it run hot like that...cheaper to replace it then to repair...
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 14, 2010 | Goldstar DH504EL Dehumidifier
Goldstar ghd30
Make sure condenser is clean.
Apr 10, 2010 | Goldstar DH304 Dehumidifier
Kicks on then shuts off
check for a dirty condensor coil its by where the air comes out of it
Apr 08, 2010 | Goldstar DH504EL Dehumidifier
I have a Goldstar GHD30 dehumidifer that I bought used last week. It's pulling 20-30 pints of water each day out of my basement so it appears to be working. The compressor only runs for 1-2 minutes at a...
yes cycles should be longer either that or the unit is keeping close to desired humidity. Also the unit is under sized 30 pint is for 400sqft. or 20 by 20 room. humidity should be 30/50 percent check your level desired room temp is 70 degrees but its a basemnt 60 works.
Jul 28, 2009 | Goldstar DH504EL Dehumidifier
I have a Goldstar GHD30 dehumidifier. I have not used it in awhile. I plugged it in to run it today and it does not turn on. I cleaned the screen and tried different outlets, nothing works. HELP!
Check the condensate collection bucket. If the bucket is not inserted correctly the dehumidifier might think the bucket is full and thus not turn on.
Aug 30, 2008 | Goldstar DH504EL Dehumidifier
Goldstar DH504EL Dehumidifier Logo
689 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
