Question about HP DeskJet 6540 InkJet Printer
Printer 6540 I would like to know how to connect my printer to my laptop. Also, what does the cord look like that I attach it to. Stacey Bryant
  • 33 Answers
First of all u need to assemble the printer and need to ensure that the printer has a steady green light on Power..
If any light blinks it means there is some problem with the printer..
To connect the printer with your Laptop u need an USB cable which has a rectangular connector at one end wich will be connected to the Laptop's USB Slot and the other end of that cable will have almost square connector wich will be connected to the printer...
Before connecting the printer U need to install the Software on the Laptop and connect the printer when system prompts..
remember the printer should be powered on while connecting to the system..
Posted on Nov 28, 2008
MY HP DESKJET 6540 is not printing. Just hooked it up to a toshiba laptop with usb cable, laptop sees it, asked for installation cd---done---it added a new printer to control panel and lights are on the...
The first thing that I would look at is to make sure the printer is set as the default printer. This is done in "Printer and Devices" in WIN 7 and Via the Control panel ---> "Printers and Faxes" in Vista and XP.
The default printer will have a little check mark by its icon. If its not there, highlight the newly installed printer and right click with the mouse. Then select "Set as Default Printer".
If this does not work try restarting the machine with the printer attached. After the computer has completely loaded the OS, try again.
If this doesn't help re-post with more info.
Feb 27, 2011 | HP DeskJet 6540 InkJet Printer
CAn my HP All in one printer 6540 connect wirelessly with my Mac osX
HP Deskjet 6540 will not support Wireless network connectivity.
Standard Connectivity:
Universal Serial Bus (USB) cable 2.0 compatible. The HP Deskjet 6540 printer includes two USB ports. One port is located at the back of the printer and one is located at the front for easy access.
Sep 24, 2010 | HP DeskJet 6540 InkJet Printer
My power light is flashing on my HP Deskjet 6540 printer what do I do?
jst turn off the printer and unplugg the printer from the computer and with the printer disconnected press and hold the power button of the printer for 20-30 seconds and connect it once again adn turn it on and check.
Jun 10, 2010 | HP DeskJet 6540 InkJet Printer
I have a HP Deskjet 6540printer and a HP laptop.What I have to buy to print wireless from my HP laptop' Thank you for your help
Attached is a link to the HP Deskjet 6540 Support page on HP.com. The manual has a section on networking. That section displays as below:
5 Connecting to the printer
• USB
• Front USB port (HP Deskjet 6540-50 series)
• Front USB port - printer software not installed
• Front USB port - printer software already installed
• Using the front USB port
• Networking
• Sharing the printer
• HP Jetdirect 175x
• HP Jetdirect 310x
• HP Jetdirect 380x
The link to the HP page is:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&product=357211&lc=en&jumpid=reg_R1002_USEN
I hpe you find this information helpful. If so, please leave positive feedback for me.
Thank You,
Brian
Jan 25, 2010 | HP Pavilion dv9000z Notebook
HP 6540 Lights flashing can't print
This indicates a paper jam or the printer is out of paper. Do not clear a paper jam from the front of the printer.
The printer might be out of paper
1. Place paper in the In tray.
2. Press the Resume button on the front of the printer.
There might be a paper jam
1. Press the Resume button. If the paper jam does not clear, then go to the next step.
2. Push the two latch handles on the rear access door toward each other, and then remove the door.
3. Remove any paper that is inside the printer by pulling it out from the back of the printer. If you are printing labels, verify that a label did not become detached from the label sheet while passing through the printer.
4. Replace the rear access door.
5. Press the Resume button.
If the Two-Sided Printing Accessory is attached to the printer, follow these steps to clear a paper jam from the Two-Sided Printing Accessory.
1. Turn off the printer.
2. Press the buttons on the left and right sides of the duplexer, and then remove it from the printer.
3. Remove any paper inside the printer.
4. Open the duplexer.
5. Remove any paper from inside the duplexer.
6. Close the duplexer, and then re-attach the duplexer to the printer.
If the Auto Two-Sided Print Accessory with Small Paper Tray is attached to the printer, follow these steps to clear a paper jam
2. Press the buttons on the left and right sides of the accessory, and then remove it from the printer.
3. Remove any paper that is inside the printer.
4. Lift the back lever on the accessory, and then unhook the Small Paper Tray
5. Tilt the Small Paper Tray forward and open the lower door of the accessory.
1. Tilt the Small Paper Tray
2. Open the lower door
6. Remove any paper that is inside the accessory.
7. Close the accessory, and then secure the back lever to close the accessory.
8. Re-attach the accessory to the printer.
Oct 03, 2009 | HP DeskJet 6540 InkJet Printer
Printer is connected but does not print
Hi
Thanks for using FixYa. Please check the following things first---
· The printer cover is closed and the rear access door or optional duplexer is attached.
· The printer is connected to the power source and turned on.
· The cable connections are secure and the cartridges are correctly installed.
· The paper or other media is correctly loaded in the in tray.
Now check the printer cable connection: If the printer cable is attached to a USB hub, a printing conflict might exist. Use one of the following methods to resolve the conflict:
· Attach the printer USB cable directly to your computer.
· When printing, do not use other USB devices that are attached to the hub.
Now verify if the printer is connected to the correct USB port: If the computer is configured to use both the back and front USB ports on the printer, then you might be printing to the wrong port. The computer has two versions of the printer driver: one for the front USB port and one for the back USB port. If you are connected to the back USB port, but select the printer driver that is associated with the front USB port, the printer will not print. In the application that you are printing from, click File and then click Print. The Print dialog box opens. The Print dialog box displays two versions of the printer driver. Select the version that is associated with the port to which you are printing. The issue will be resolved.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 12, 2009 | HP DeskJet 6540 InkJet Printer
Hp deskjet 6540
You can usually go to the HP website directly and download the printer directly.
Sep 10, 2008 | HP DeskJet 6540 InkJet Printer
Problem getting hp deskjet 6540 inkjet printer to print
shut down the printer and computer both then on only the pc and cancel allthe pending documents from it then again shut down your pc check allthe wires connected properly then on both printer and pc.it will work properly.feel free for further assistance.
Aug 08, 2008 | HP DeskJet 6540 InkJet Printer
Hp deskjet 6540 printer driver
Hello alex9
Click on this link to go to HP's site. From the list click on the operating system you are using. It will take you to the drivers download page. Select the one that is more convenient to you. Download it and save it in a specific folder in your computer. Afterwards, go to that folder, double click on the driver you just downloaded, follow installation instructions and you are ready to go. Hope this helps. Let me know
cancerags
Jan 01, 2008 | HP DeskJet 6540 InkJet Printer
HP DeskJet 6540 InkJet Printer Logo
82 people viewed this question
Ben Johnson
