Question about Mintek MDP-1770 Portable DVD Player
Help! Thanks.
When I plug it in, the light goes on, but it won't play a DVD--the disc doesn't even turn.
  • callistere Nov 02, 2008
    I'm using the power supply that came with it. No, the screen doesn't come on. Just the power light. Thanks for your help.
    Problem Solver:
  • 20 Answers
Are you using the correct rated power supply for the DVD player, is it the official power supply that came with it. Sometimes problems like these occure when a replacement "universal" adapter is used and the voltage and current rating is incorrect for the item.
Also does the screen come on or is it just the power light which turns on?
Posted on Nov 01, 2008
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
My Sony dvp NS710H isn't playing most standard, well conditioned DVDs.
Hello
Just clean its laser pickup lens, by inserting a lens cleaning disc in to, and play it at least two times. If it doesn't help you, the laser pickup unit should be replaced. The lens cleaning disc can be bought from most of the electronic sparepart selling shops at your town, and won't cost more.
Feb 27, 2012 | Sony DVP-NS710H/B DVD Player
Compact Disc rewritable DVD player won't load or play
Check the data connector on the rear of the drive. If this doesn't work you may need a new drive, they are cheap and readily available.
Jan 19, 2012 | Lenovo Computers & Internet
Getting a C 13 70 disc is dirty message only for DVDs that I'e burned recently. I bought a new pack of blank DVDs, the same kind I've always used, but every movie I burn on these new ones, they...
Hello, welcome to Fixya!
Was this player playing previously? And how long have you been using this player? I suspect the lens of the player. Once the lens of the player becomes weak, it won't play discs any longer.
The first thing my mind goes to, is the lens. The lens id responsible for reading/loading data on discs. So if the lens is unable to read the disc, there is no way the player is going to play the disc.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or probably, a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Nov 03, 2011 | Sony DVP-SR200P DVD Player
Won't read d d keeps saying bad disk
Good luck.
Oct 05, 2011 | Curtis DVD1041 Player
We have a PD-800 dvd player. & it keeps saying "wrong disc". help
unplug for 2 minutes, then plug back in. This works,If you haven't done this already, try a different disc, preferably one it has played successfully before. If another disc works, then take a look at the working side of the disc that doesn't work and check for scratches or smudges. Or, if it's a recordable disc, it may just be a brand that your player can't handle. Every now and then, I even get a factory DVD that my player can't handle.
If this is happening with any disc, even ones it has played successfully, then we'll hope for dust on the laser lens. Get a lens cleaning disc and try it. If that doesn't work, you may have to replace the player.
Sep 15, 2011 | Protron Televison & Video
When i put in a dvd into my player, it says no disc, and won't play, when it does accept the disc, it doesn't play it, then a "C:13:00" starts blinking. I should be able to just put in a...
It's most likely dirty, though it could be failing. The lasers have an average life span of 3 years, under normal use.
Several companies make CD/DVD laser lens cleaners. You want the kind with optical quality brushes on the bottom side. You simply put it in, let is spin up and play, then take it out. It may not play the first couple times you put it in, but it will be cleaning the lens and pickups.
If that doesn't do it, I'd start looking at sales for a new player.
Jul 05, 2011 | Sony Televison & Video
About a thomson dth 8555x probleme
my thompson dvd decoder player doesn't play any disk...
it complain disc error
please help me out...
Feb 05, 2008 | Thomson DTH7500U DVD Player / HDD Recorder
LAPTOP DVD DRIVE WONT PLAY DVDS ANYMORE
Drive is on its way. Typical behaviour. Try air dusting lens but unlikely to fix it. Very easy diy repair and cheap. EBay the new disc drive or refurbished. Then go to youtube. Nearly all laptop drives are the same to replace no matTerry brand. You could even get a faster drive.
Mar 05, 2017 | Televison & Video
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Mintek MDP-1770 Portable DVD Player Logo
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
