Question about Brother FAX-8360P Plain Paper Laser
Transmitted pages are too dark, practically unreadable :
Hi :
Recipients of outgoing faxes regularly complain that pages recd by them are too dark. Also, there is a vertical dark line in each page. (When I copy a page, I see the same vertical line. My suspicion is that it is coming from a toggle switch near the scanner bar)
Is there any way to reduce improve the quality of transmission ? Curiously, pages that are originally fairly light transmit better.
The manual is silent on this type of problem . Can any one help, please.
Thx
GH
    Problem Solver:
  • 16 Answers
Lift the control panel up (the one with all the buttons) and you can see the surface of the scanner, a thin piece of glass going across the machine. carefully clean that and it may cure your problem (look for tippex, ink stains etc)
Posted on Aug 27, 2010
    Genius:
  • 2,120 Answers
I suspect your scanner unit is going bad or it is extremely dirty.
Making a copy gets same result as when you send.
Posted on Nov 01, 2008
When I send a fax, the recepient cannot see the writing on the document, they can see the date and the address that i am sending the fax from, but they cannot see the content of the letter. When a fax is...
It'll be your outgoing fax resolution settings. Should be in your software somewhere. Move all settings, ie contrast, darkness etc to approx 50% .
I would have thought that there would also be a practice fax option, perhaps amongst the set up procedures.
Jun 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Intellifax 4100 laser fax
Clean the roller with alcohol and then try. It will work fine.
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Recipients get black pages that are unreadable.
You have a bad thermal head, parts not available. Sorry.
Oct 06, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Faxes coming in print fine but outgoing faxes people are saying are coming out blank on their end
If outgoing faxes are turning up blank on the recipients end, you may be putting the paper to be faxed in backwards. Outgoing faxes should be sent face-down. If you are sending properly, either your scanner is failing (test it by copying a document) or the recipient is having fax issues on their end.
Jun 23, 2009 | HP 1020 Plain Paper Thermal transfer Fax
Black streaks on prints
Where the original page that you wish scanned/faxed there will be a device called a "scan part". This device "reads" the paper to be faxed/scanned as it passes. It usually is found very near where the paper to be faxed goes in.
If there is a spec of debris on this part it will cause a fine line straight down the document. If its dirty, the document will be too! Just give it a good cleaning and you should be fine.
Did this help? Click "FixYa" below!
Thanks
Len
May 29, 2009 | Brother IntelliFAX 4100 Laser Fax
The last time I got a fax, only the first four pages were OK....the rest were so dark, they were unreadable
Try making 10 copies of something.
The drum cleaning blade in your fax machine may be worn out.
Oct 20, 2008 | Brother Office Equipment & Supplies
No confirmation and can't fax any outgoing
There is a fax stuck in memory. Try unplufgging the machine for 30 secs.
Plug a regular into the wall jack to verify that you have a dial tone.
Aug 15, 2008 | Brother IntelliFAX 5750e Laser Fax
Outgoing faxes
Not good! It sounds like you have a bad scanner assembly. Make a copy of something and you probably will see the same result.
May 21, 2008 | Brother IntelliFax-4100e Fax
Copies and outgoing fax quality
your machine most likely has toner spills in it.
if you send faxes face side down follow these instructions ;
1- take out toner
2- look for thin glass strip on bottom inside the machine
3-wipe clean
if you make copies side up then do the same except look for glass strip on the upper side of machine
Nov 27, 2007 | Brother IntelliFAX 4100 Laser Fax
Document feeder jam?
So when you copy via docfeeder, everything comes out fine?
Look around where the paper exits the docfeeder...there should be some kind of black plastic flapping piece...the paper pushes it up as it goes through the machine.  If this is stuck up, the docfeeder might think that the paper is stuck inside the feeder.
Oct 27, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Brother FAX-8360P Plain Paper Laser Logo
445 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
