Question about Vizio L37 Television
Brightness Jumps Up for 2-3 sec
After selecting channel 12, any channel i go to after this the brightness level is at maxium, then changes back to normal level after 2-3 sec. This happens on the "TV" setting, not "DTV" or "Digital HD". Any suggestions? I contacted tech support and they suggested the following:
Dear Vizio Customer,
I have reviewed email regards to your VIZIO TV, model #L37, here is some information for you:
1. Reset the TV:
1) Reset all settings:
a. Press the MENU button on your Remote Control, OSD displays;
b. Press button to display Setup page;
c. Press button to highlight Reset All settings;
d. Press button to start reset.
2) AC reset: Unplug the AC cord of TV for about 15 minutes and plug it back.
2. Please check if the buttons on the side of the panel work.
3. Rescan the channels:
Auto Search only functional in TV input, please press TV button on your remote control to ensure your TV is in TV input. And then rescan channels as follows:
a. Press MENU button, OSD(on screen display) displays.
b. Press button to display the TV page.
c. Press button to choose Cable or Air(Antenna) depending upon which equipment you have attached to the DTV / TV Input.
d. Press MENU button again.
e. Press button to highlight the Auto Search.
f. Press button to Auto Search for TV channels available. The TV will automatically search for analog and digital channels.
g. Wait for a while and don't press any button. When TV finish searching the channels, press EXIT to quit.
- i tried this, however after leaving the TV unplugged for 20 mins, the TV still contained the memory of my privious saved channels. so, i don't think what they suggested worked.
4 Suggested Answers
SOURCE: dtv frozen
I had a similar problem and the way to solve this is to reset the set from the remote.  Set TV to standby and press Info, menu, mute then power.  The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter.  TV will turn off.  When switched on it goes into Plug and Play mode to reset the analogue and digital tuner.  Allow a full reset then you should be ok.
Posted on Oct 19, 2007
SOURCE: No digital channels after running auto search
Same thing with my vizio vx37l tv. Did you fix the problem bpakja? If so please let me know how.
Posted on Dec 10, 2009
  • 96 Answers
SOURCE: Vizio 32" Froze, then no more picture or sound
how long did you leave it unpluged
Posted on Jun 04, 2012
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
Apr 17, 2016 | Princeton Digital VL173 Monitor
To change the brightness level you may try following the below steps which might help:
    (1)Click start.
    (2)Type power options and select the same.
    (3)At the bottom of power options move the Brightness control from left to right to increase/ decrease the level.
    Thanks and Regards.
    Kiran Kumar.
Jul 07, 2014 | Dell Vostro 1015 Laptop
How do i increase the screen brightness HP elitebook 8530p
Sounds like your keybinding/hotkey combo is not doing its job. (or your bulb in the display is going out)
You can open up Control Panel and adjust brightness from there.
Step 1 Click "Start ' Control Panel ' Hardware and Sound ' Power Options" to open the Power Options window.
Step 2 Click and drag the bottom "Screen Brightness" slider to the right to increase screen brightness and to the left to decrease it. Making this adjustment changes the brightness level only for the current power source; if you change power sources, the screen brightness may change again.
Step 3 Click "Change Plan Settings" on whichever power plan is currently selected.
Step 4 Click and drag the "Adjust Plan Brightness" slider to the right to increase brightness for each of the power sources, such as "On Battery" or "Plugged In." If you want high-precision numeric control, you need to access the advanced settings.
Step 5 Click "Change Advanced Power Settings."
Step 6 Click "+" next to "Display" and then "Display Brightness" to expand these options.
Step 7 Click "On Battery" and enter a percentage in the field provided. Choosing "100" will set the screen to maximum brightness; any other brightness will be a percentage of the maximum brightness. To increase the brightness, make sure the number you enter is higher than the current value.
Step 8 Click "Plugged In" and set its brightness percentage.
Step 9 Click "Apply" and then "OK" to close the Advanced Settings window.
Step 10 Click "Save Changes" to save any changes you made on the Edit Plan Settings page. If you only make changes in the Advanced Settings page, the Save Changes button will be grayed out. If that's the case, just click "Cancel."
Hope this helps!
Apr 28, 2014 | HP EliteBook 8530p Notebook
Brightness wont change
You need to install Acer Launch Manager, if it is already there than try this
Go to start and type msconfig
Now select '' normal startup and reboot'' or
Click on Start > Run > type "msconfig"
Select the Startup tab
Look for the following entry and make sure that it is checked.
I hope this will resolve your problem...
Apr 10, 2014 | Acer Aspire 5552-3691 - 24379
How do I adjust brightness level on reading page of my kindle app
Fixing the brightness of your screen is easy on the Kindle Fire, Kindle Fire HD and Kindle Paperwhite, all of which provide screen brightness controls. This feature is not available on the original Kindle, however, as the screen is not backlit.
Kindle Fire Step 1 Tap the "Quick Settings" icon in the upper right corner of your Kindle screen. The icon looks like a gear.
step 2
Select "Brightness" from the Settings menu. If you don't see it immediately, tap the "More" icon to access all of your settings options.
step 3
Use your finger to toggle the slider from left to right to increase or decrease the brightness of your screen.
Kindle Fire HD and HDX Step 1 Slide your finger downwards from the top of the screen to display the Quick Settings menu.
step 2
step 3
Toggle the slider to the left or the right to fix the screen brightness.
Kindle Paperwhite Step 1 Select the lightbulb icon on your Kindle screen. This icon is present when you're reading a book.
step 2
Move the vertical slider with your finger to achieve the ideal screen brightness.
step 3
Tap and hold the "+" sign to achieve maximum brightness. To achieve the lowest brightness possible, tap and hold the "-" sign.
Jan 05, 2014 | Samsung Galaxy Tab 8.9 WiFi 16GB Tablet
Magellan roadmate 2036 how to set my local time
1. From the
Main Menu screen, tap the Settings icon .
2. Tap
Setting Languages
1. Access the
System Settings menu (above).
2. Tap
3. Tap on the desired language.
4. Tap the back arrow .
5. The Magellan RoadMate receiver will reboot if you change the language.
Setting Auto Power
Auto power is the duration of time that the Magellan RoadMate receiver remains idle before turning off
1. Access the
2. Tap
Auto Power.
3. Tap on the desired duration.
Setting Brightness
1. Access the
2. Tap
3. Tap in the brightness slider to set the brightness of the display.
Dim on Battery Power option will prolong battery life by dimming the display while using internal battery
power. Check to turn this option on.
Setting the Time Format
1. Access the
2. Tap
Time Format.
3. Tap on 24 Hours or 12 hours with am/pm.
Selecting the Time Zone (daylight savings on/off)
1. Access the
2. Tap
Time Zone.
3. Check Auto Time Zone or select your time zone from one of the cities in the list.
Jun 27, 2011 | Magellan 2036 GPS Receiver
How do I adjust the brightness on my laptop? Its a Compaq Presario V2140US
1. Press down the Fn key at the lower left end of your Compaq Presario keyboard. Keep the button held down and tap the F7 key to decrease the screen brightness by one step.
2. Tap the F7 key again with the Fn key still depressed to further decrease the brightness by one step. Continue hitting the F7 key until you reach the minimum LCD screen brightness.
3. Hold down the Fn key and tap the F8 key to increase the Presario's LCD screen brightness by one step. Keep pressing the F8 key until you reach the maximum brightness for your screen
Mar 01, 2011 | Microsoft Compaq Presario C501nr Notebook
Theres no brightness setting in menu. it only has cc sleeptimer and exit. how do i change the brightness?
You can adjust the brightness control on your 19PR19 Philips Tv. For that you have to go to picture contol menu
Do it as follows
To adjust your TVs picture control, select a channel and follow these steps.
[1] Press the Menu Button on the remote control to display onscreen menu.
[2] Press Cursor up or Cursor Down button until the word Brightness is hilighted. For each press of Cursor Up or Cursor Down button you can go through Colour, Picture, Sharpness, Tint, Colour temp etc, depending on the adjustment you want to make.
[3] Press Cursor right or Cursor Left buttons to increase or decrese the selected option. Ok.
Nov 17, 2010 | Philips 19PR19 19" TV
Hi, my nokia N900 screen goes slightly duller after about 2 secs of being switched on, is this normal? Many thanks
its not normal Nokia 900 has problems. These problems are small and are not simple. But also, these problems are solvable. you should concern with nokia outlet it may problem of your screen power or resolution of lcd it can help you or you can follow the nokia user guide site or can follow this
Jun 02, 2010 | Nokia N900 Smartphone
Vizio L37 Television Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
