Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Pressed the wrong button when setting up new sharp acquos 46 in lcd tv.
We pressed the digital tv button instead of the analogue tv button when we were setting up the new sharp tv today and now we cant do anything with it! Its just a blank screen? We dont have digital tv. Is there anything we can do to rectify this?
  • Sharp Master
  • 5,568 Answers
You might try pulling the AC plug out and leaving it overnight. Since many sets are now using a little flash memory that does not require constant power to remember stored settings, this may not work.
Posted on Nov 01, 2008
I am having trouble recieving over the air digital signals. I have connected a 20 db amplified FM/UHF/VHF antenna to the cable/antenna coax connection, set the input to "TV", and set the TV to...
I believe you have probably selected the wrong TV mode. It seems that you have set the TV to analog mode. It is common for the digital tuning option to be greyed out in analog mode and only becomes available in digital mode. Look for a button on your Sharp remote labelled "DTV" or "DIGITAL" and press this, then open the menu and try the digital setup again. If you don't have one of these buttons, look for a button labelled "INPUT" or "SOURCE" and look for an input or mode called digital or DTV.
I will check on the exact method for your TV and post back with the details shortly.
Feb 10, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Brand New TV - remote doesnt work
Is it the original remote for this TV?
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera’s Lens (Digital Camera can detect IR), you should see flashing light on the camera’s screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Jul 03, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Philips 42pfl7762D-lcd blue screen, remote control
Hi! I have the probably same problem (since today) - all I know is that it is because the TV is set to digital instead of analogue, and it won't allow me to put it back into analogue mode - when I try that, i get the cross you mentioned. The strange thing is, that there are no menus visible at all. But the volume and screen output format buttons are workijng and show on the TV. Otherwise the screen is blue. Any solutions?
May 15, 2010 | Philips 42PFL5332D 42 in. LCD Television
My sharp tv displays 'please wait' but no picture. and my source input display menu will not come up. model sharp acquos 32 inch.
You will have to replace DIGITAL PCB ASSEMBLY to correct the problem, I assume, that your TV is lc32d40u?
Sep 26, 2009 | Sharp AQUOS LC-45D40U 45 in. LCD...
Aquos Screen Image Too Big.
I had the same problem, but it looked like my son pressed the view mode button on the remote. I set it back to Dot by Dot and it looks perfect again. Try it out.
Sep 13, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Cant work my freeview
The [A/D] button on the remote control switches between analogue and dgitial TV.
If this doesn't work you can restore the TV to factory settings as follows:
Press and hold the [Menu] button on the TV (NOT on the remote)
The picture / sound / features menu will appear.
Continue to hold until this menu clears.
Release the [Menu] button and wait for about 90 seconds.
The TV will go blank and eventually return to the original install menu.
Install the TV as you did from new.
This will clear ALL analogue and digital TV channels and install again from scratch.
This should be used if the TV ever freezes on digital, or if any of the channels appear in the wrong place or not at all.
May 07, 2008 | Televison & Video
Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Dec 25, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
DENON 1403
press the "input mode" button, ought to solve it
Dec 24, 2007 | Denon AVR-1403 Receiver
Frozen digital screen
Set TV to standby and press Info, menu, mute then power. The set should turn on with the service menu available scroll down until you select reset press right hand arrow next to enter and then enter. TV will turn off. When switched on it goes into Plug and Play mode to reset the analogue and digital tuner. Allow a full reset then you should be ok.
Dec 21, 2007 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
How to keep TV on digital?
It depends a little bit on your setup but sounds like you may have drifted from an external source to the television's internal tuner.
On my slightly different Aquos model my digital channels are "Ext 5" and "Ext 6".  There is a button next to the digits that is a square with an arrow pointing into the inside of the square.  This can be used to cycle through the external analogue and digital sources.
Push the button and then leave it for about 5 seconds as it can take a while before an image is displayed.  Keep pushing the button until the right digital channel is displayed.
Nov 13, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
181 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
