Question about Sony Playstation 3 (PS3) Console
How do i hook up my ps3 to my dynex tv.
It dont show anything at all .. it says no single and its just blank.. im tryin to hook it to the hdmi.. i only have two wires..im i post to have the red white and yellow also
4 Suggested Answers
RescueTechLA
  • 2653 Answers
SOURCE: i was switching my ps3 from hdmi output to the
Easy to fix so don't worry ;)
While the PS3 is off (solid red led)
Hold down the power button until you hear the SECOND BEEP, quickly release.
This will reset the video settings back to default.
Posted on Feb 01, 2011
johnhercus26
  • 104 Answers
SOURCE: will not work on my tv
does ur tv have the correct colour bits at back/side for u to use this??also have u checked all the stations to see if ps3 is on any others as the leads all use seperate av stations if all this is correct it would appear your ps3 output signal board is broken if its under 1 year old sony will repair this under warrenty free of charge if its over a year old it costs about 40 from a coputer/systems repair shop to fix this
Posted on Oct 02, 2009
tomdean
  • 5 Answers
SOURCE: im tring to fix my
holding the eject while turning it on will reset the settings
Posted on Nov 14, 2010
Dynex HDTV says not supported when PS3 is connected via HDMI
Have you tried changing the video output settings on the PS3? It may just be on a setting that the TV does not support. For instance, if the poutput setting is 1080P, and the TV only supports up to 1080i, you would get a "not supported" signal. Hook the ps3 to a tv that it works on...turn it on, go to settings- display settings-output settings- select HDMI as the connector type- if it asks for 3D tv size...select the size- now you need to set the resolution...select all resolutions that the TV supports, since it is a dynex...it is likely a 720p TV. So I would start by selecting only 720p, and then hook the system to the Dynex TV and see if it works now. If it works, you can go back in and attempt to select 1080i or 1080p to see if they work... but again, being a Dynex, it is probably only a 720p TV... The PS3 is likely trying to output a 1080i or 1080p signal...which that TV doesn't support.
Mar 21, 2014 | Video Game Consoles & Games
Im tryin to hook up a ps3 and telus box for tv threw denon i get no sound im using to hdmi cords any one help
Your receiver may not be able to decode audio from HDMI. It may just act as an HDMI switch. Use a TOS link optical cable for each audio source.
Jan 05, 2011 | Denon AVR688
Tryin to play my ps3 through hdmi, but all im getting is a blue screen. but i tried it befor and it worked now it dont any suggestions on why?
Did you move your PS3 back to a regular tv set? If this is the case then you have to 'reset' your PS3 to play through the analog hook-ups.
This is easily redone by doing this
1, With the PS3 "OFF", Press and hold the power button, keep holding the button down till you hear 2 rapid beeps. IMMEDIATELY remove your finger from the power button (on the new slims continue to hold the button until the unit powers itself off).
2. Press the power button a second time and let the unit power down.
3. Power the PS3 back up, you should have playback through your analog hook-ups.
This little fandango will have to be repeated every time you relocate your game center on an HDTV and then back to a regular tv.
If this isn't the case, the first thing I would check is that your HDMI cable hadn't gone bad. Simply change that cable out with another and annotate the results. Then test the HDMI port with another playback device (blu-ray or up scaling dvd player) and see that the port isn't bad.
Other than these test hints, there may be little else to troubleshoot.
Hope one of these helped...
Oct 25, 2010 | Televison & Video
I keep getting a blank screen after updating my ps3 ver 3.50, after updating and installing the update the system restarts then it just stays blank, then my TV shows check video output, i can hear my ps3...
Unfortuently some updates just dont install right and some just dont flat out work at all so mabey wait for a letter version before updating would help
Oct 16, 2010 | Sony Playstation 3 (PS3) Console
Dynex tv works. bought ps3. when hooked up to
I would suggest you check if your PS3 is set up on going through the HDMI Cable.On your PS3's XMB scroll to settings -> Display Settings -> ANd from there go down to the one that says "Y Pb/Cb Pr/Cr Super-White (HDMI)" and hit X and select the option Yes... That sets the PS3 displaying through the HDMI
If you are already have done that I'm pretty sure you know you have to change the Input on your TV to HDMI... Take your remote and hit Input -> Scroll down to HDMI on the Input Source menu and hit Enter when you get to HDMI
If the AV on your PS3 works and not your HDMI sounds like Display Settings issue...
If you have done all that, that is strange if it still doesn't work.
There are some people that are having problems with the AV Cable with the PS3, I tried this and it really does work. I switched from HDMI on one tv to a AV Cable on another and when I did that neither TV would display content from my tv. The fix for this is resetting your PS3, like on a iDevice you hold the home button and lock button, for the PS3 you hold the Power off button and the Eject button for around 10 seconds. This resets your PS3 into default video settings. Until it Turns on, Beeps, and Turns off. This should work.
Jan 01, 2010 | Televison & Video
Will not work on my tv
Oct 02, 2009 | Sony Playstation 3 (PS3) Console
Ive had my PS3 hooked up using HDMI for years now but i bought a component cable because i have just bought a PVR and it can only record using component and not HDMI. The problem im getting is that when i...
Hook it up with the component cable and then hold the power button on the console until something comes up on screen. Make sure you have selected the component input on your tv or else you wont get anything anyway.
What holding the power button does is it resets the video settings to the lowest common denominator and then you can reconfigure it for the optimal picture quality of the component cables.
If that doesn't work double check the component connections on the back of the TV and just make sure they are where they should be and that no accidents were made while hooking it up.
Please post the results from these steps here so that I know what happened.
Jun 09, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3
Have both the AV cables and hdmi cables hooked up from the tv to the ps3. On the TV Menu goto the av station which is different from the HDMi station...From the ps3 menu screen gotot settings then to video and audio and select hdmi then back to the tv menu and select the hdmi station and the ps3 main menu should be seen and you are all set
Jul 11, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
PS3
You need to reset your video settings when you move to a regular TV. Just hold down the power button, it will beep twice and go back to stand by mode. They boot up again and your video setting should be back to normal ( for standard TV).
Bimmerhp
Dec 07, 2007 | Sony Playstation 3 (PS3) Console
HDMI Cable
if ur setting up the HDMI cable dont check all the resulusions just check the 1080i coz 1080p is to high for your TV thats why you have that blank screen for 30 sec.
Jul 28, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
324 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
