My washer makes a wierd clinky sound during wash and rinse cycle and it has began to stop spinning the water will drain but clothes will be soaked. Also sometimes during spin cycle it will agitate instead of spinning
SOURCE: rinse cycle spinning... clothes still soaked
It sounds like your washer is not going through it's neutral drain. After agitation, your washer should pause and drain for around 90 seconds to pump out the water before spin. Check this out by starting a wash with a small screw driver holding the lid switch down. This will allow you to observe whether or not it's going through it's neutral drain. If not, it's a transmission problem. The trans is covered under warranty for 5 years. You may also want to check the pump to see if it's gunked up. Catriver..post back.
SOURCE: Maytag won't agitate during wash
sounds like you have a broken sety fo brake pads, just replaced a set today for same reason, open the lower acess panel and with a flashlight look into the bottom , your lookin for brake pads( theyre probably broken and laying under unit.)
SOURCE: I own a Maytag Performa
sounds like you have a tub seal problem, which took out the bearings, I take it one buzy mom does lots of laundry! Maybe time for a new washer.
SOURCE: the agitator on my Maytag
Sounds like you need a gear case. These require a special spring compressor to remove.
SOURCE: maytag washer not agitating and not spinning fully
Pr obably a coupling between the motor and gear box, Take motor off and coupling will come out, re place it and it should be fine
