Question about GE JVM1440 Microwave Oven
GE JVM1490 900 Watts
Check the ask me thread , ive left some stuff and on that link i left you can scroll up to a totally dead oven test but agin I'll be checking the theads
electech
  • jason Nov 01, 2008
    ok tomorrow
Thanks! I did see that info about the totally dead unit. That's a great troubleshooting guide!
I'm calling it a day for today.
Thanks again!
Posted on Nov 01, 2008
DEAD! No lights nothing.
Appliance is totally dead. No response to any key or lights ...
https://www.ifixit.com/.../Appliance+is+totally+dead.+No+response...
iFixitSep 19, 2013 - Replaced oven cavity thermal cutout - No joy. What could cause total loss of power?? - GE Microwave Oven Monogram Advantium 120.
Notes on the Troubleshooting and Repair of Microwave Ovens
repairfaq.cis.upenn.edu/sam/micfaq.htm
Feb 24, 2015 - On-line microwave oven repair database; The simplest problems; Repair ... Totally dead oven after repair; Dead controller; No response to any ...
Oct 15, 2015 | Microwave Ovens
The dial on our GE JVM1790WK01 microwave turns freely but does nothing. I checked the knob for damage, none found and the shaft turns freely with a slight bump as it goes around, but does nothing.
turntable problem? it's probably the motor itself. it's easily removed under the bottom panel. you'll need the pricey ge orig. part; as they use a odd 21volt motor. good luck.
Aug 06, 2011 | GE JVM1790 1000 Watts Convection /...
I have a GE microwave model JVM1851SH06 that is completly dead. I replaced the Fuse and power came back, but 30 sec in it was dead again. What should do next.
You need to first verify that your outlet is correct at 105 to 125 volts AC.
If so, then you may have a failing high voltage transformer (rare) or possibly a failing magnetron, etc.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
http://www.gallawa.com/microtech/xformer.html
May 26, 2010 | GE XL1800 1100 Watts Microwave Oven
GE JVM1650WB008 Microwave. Daughter used left
probably blew the magnetron or high voltage transformer DONT test either unless u discharge the capacitor possible shock risk that unit is still live even unplugged.... i wanna telll you these days that micros are disposable items because the parts are gonna cost more than just to buy a new one plus if any arching occured that same problem is gonna occur again if it did work so basicallly that miro is kapout... hope this helped
Jan 31, 2010 | GE JVM1650 1000 Watts Microwave Oven
Ge advantium 120 microwave oven completely dead
You have a bad cavity switch. I would guess it is the one behind the vent cover, toward the left side of unit. You would need to remove unit from wall. Remove outer housing to expose cavity switch. You can see it from vent cover, I would test all cavity switches before removing from wall. You should have a diagram of unit folded up behind vent cover towards right side of unit. This tells all workings of unit. Will also tell where all cavity switches are.
Dec 30, 2009 | GE Advantium 120 Convection/Microwave Oven
Ge jvm1650 microwave oven totally inoperative.
There will be a fuse, a cavity TCO (thermal cutout/thermostat) and a magnetron TCO.
These are the parts to check.
You can find helpful exploded view diagrams and order parts by entering your full model number here. (Don't forget the suffix).
Feb 02, 2009 | GE JVM1650 1000 Watts Microwave Oven
Ge jvm1650 microwave over totally inoperative. No lights
That's usually a blown fuse, cavity TCO or magnetron TCO.
Accessing some components for testing and possible replacement (such as the cavity TCO) will require you to remove the oven from the wall.
GE JVM1490 Microwave Troubleshooting
sorry i didn't know you came here but I left a link for the best of tests for your microwave
but here it is again http://repairfaq.ece.drexel.edu/sam/micfaq.htm#mictsthvd
please be very careful if you have to check the hv transforformer , but these test will help you find the problem , if you get stuck i'll be checking this thread for a few more hours , otherwise we will have to continue tomorrow
electech
Nov 01, 2008 | GE JVM1490 Convection/Microwave Oven
GE JVM1440 Microwave Oven Logo
62 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
