Question about Hotpoint DY46 Style Line Stainless Steel Electric Double Oven
Hotpoint oven smokes after one minute
I moved into an apt complex this past summer where the maintenance is just awful. I have not been able to use my oven. I cleaned it throughly and there are no signs of anything but it smokes. After having it on for one minute the whole apt is smoky and the smoke alarm is shouting off so it has not been used. Can someone tell me what might possibly be causing the smokling. I did tell the super who told me to clean it (of course I did for hours anyway) and that it was new but we have not been able to cook at all. Now with cooler weather coming and the Holidays, I really need an oven. Any suggestions as to what I may do? Thankyou. I truly appreciate any ideas on this. I am a female and not super handy but I sure do try :) thanks again!
  • Hotpoint Master
  • 3,463 Answers
Sounds like build up of fat and grease on element.
Only thing to do is leave it on and it should burn all the fat off.
Posted on Nov 28, 2008
SOURCE:
The fan in the main oven won't work unless you move it slightly by hand before turning the oven on. It then starts pretty slowly and speeds up. not sure if it can be resolved or do i need a new...
It sounds as though the fan is gummed up (a technical expression). Maybe a little fat has splashed on the fan and it's congealed. Try spraying the fan with a little WD40 (dab it off after about a minute) and run the oven until there is no lingering smell of the lubricant.
Dec 12, 2013 | Hotpoint DY46 Style Line Stainless Steel...
Whirlpool self cleaning oven super capacity 465
If there is a lot of grease it may be good to wipe the excess out. The excess grease could ignite if not it can sure smoke up the house.
Nov 12, 2013 | Ovens
Random intermittant crackling sound from Hotpoint electric oven
This could be insulation on the wiring or more importantly the connecting spot might be frying. In any event, disassemble it and check into it.
Feb 24, 2013 | Hotpoint Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
My hotpoint sy36 grill has stopped working. It went on, there was a bit of smoke and then just stopped. oven seems to be fine. any ideas?
Hello, suzanne
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and even farther back. It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this Informational site may not have your exact model or brand, this site will help you a lot. Here is a site link about everything you want to know about ovens and possibly yours, from
repair to trouble shooting it. Now go easy on me, I am just trying to help. If it does great if not, I am sorry.
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help , I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Apr 23, 2011 | Hotpoint SY36 Style Line Stainless Steel...
My Hotpoint electric oven no longer heats up. The top oven works but not the main one. How can I fix this?
HI, seen this before with the ge/hotpoint elec. ovens i worked on when i did apartment maintenance. One could be a bad control switch(knob u turn to turn on oven).turn on broiler and see if it comes on,if it does not that could be it.If it comes on it u might have to replace lower element,but could still be control switch not working for that section.But it will one or the other.
Mar 12, 2011 | Hotpoint Ovens
Hotpoint oven not heating up;broiler ok
the element is burned out, remove itand check it with a ohm meter. if it moves when you touch the leads to both sides its good if it don't its bad. ps i take them all the way out to check them. you must unplug the oven before repairs!
Jan 19, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Self clean for 4 hours -- do i need to leave my apt?
The first time you do a self clean it does smell weird and you do not need to do it for 4 hours change the setting to 2 or three hours. This uses allot of ellectricity to do the cleaning. I usually just use a oven clenaing product for light cleanup. If you have a pie that has spilled over or something then it works great. The Smell is a bit of ash and smoke from all the things that you are incinerating inside your oven.
Cheers
Al
Sep 11, 2009 | Bosch Ovens
Hotpoint BU62 double oven, no grill functioning
keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
Aug 26, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Stove smokes when i turn the oven on
on the oven's smooth surface you should use a razor blade and scrap off the plastic (when cooled).. if the plastic melted on the burner, you may need to replace that particular element from a local appliance part store. easy to do.
Apr 20, 2009 | GE JKS05 Electric Single Oven
Hotpoint DY46 Style Line Stainless Steel Electric Double Oven Logo
396 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
Steve Allison
Steve Allison
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
